Chart plotter will not power up
My Simrad CA42 was working ok but has "Died" and will not power up again. I have checked the fuses in the power supply and the single fuse on the circuit board and all are ok. Power is reaching the circuit board via the lead. I have tried a master re-ser to no avail. The keys initially light for two seconds and then go out and there is no keypad tone. The screen remains completely blank although when the power is removed a slight response is seen. Does anyone have any idea's?
  • 12 Answers
SOURCE: no power at all
I am having the same promblem I think does your light flash on and off on power light, mine does I am going to trouble shoot the board on monday at my company I work for I am a tech at a company that repairs other lcds this big and bigger but not for vizio so if i find anything I will let you know if you want?
Posted on Oct 28, 2007
  • 157 Answers
SOURCE: Philips LCD TV 37PF5520D/10. TV will not switch on.
philips has a problem with bad caps(swollen)in power supply-try shopjimmys.com enter model number-scroll down til you find power supply-order it simple to put in.if they do not have it write down part number then google it to find one--you also can change the bad caps yuorself if you are handy with a soldering iron
Posted on Sep 11, 2009
SOURCE: LG 42PX4MVH PLASMA TV - Sound but no picture.
I have the same issue with my LG 42PC3DVA and I narrowed it down to the Y SUS board. After a little research there are a few items that are prone to go. The ceramic fuses (as you found), sometimes the capacitors on the Y SUS, Z SUS, and power supply go along with them You can tell because thy will be bulged at the top instead of flat. I replaced a few of my capacitors - they are only $0.89 each so it was MUCH cheaper than a board.
The other thing that is common on the Y SUS in particular are the FETs (also called MOSFET). They can be replaced if you are good with a soldering gun but they are static sensitive so be grounded. They are also a bit tricky to test so you may want to do some research on how to determine if this is the issue... or you can just replace the whole board.
Posted on Oct 28, 2009
SOURCE: flm323b power supply
Replace Q2 by 18N50, Q8 and Q9 by STP6NK60 and Z2 and Z4 by !n4739. I have the same problem and fix it.
Posted on Sep 30, 2010
gary_lowr331
SOURCE: HITACHI 37PD5200 E Plasma dead.
do not change fuse if blown as there must be othere issues with power board and you could damage more boards check capacitors for leaks thanks gary
Posted on Sep 19, 2012
Raymarine dsm300 Circuit breaker keeps tripping g when connected to chartplotter
either the cord to the chart plotter is faulty or the chart plotter itself is dead short
have an electrician do an insulation test and circuit test on the cord and plotter unit
Jan 08, 2017 | Raymarine Boating
My Ap16 Simrad control head died. Any idea of as to 1) where I might get it repaired and/or 2) where I might find a replacement?
Hi John
Boy, you're up against it on this one. The AP16 is a pretty old unit for sure. Here's the link to your owners manual.
I've come across one instance in my experience where although there was enough power showing to the control head, because of corrosion and broken wire strands, there simply was too much voltage drop and not enough current flow for the unit to function when it was turned on. After cutting back/fixing the soldered connections and reconnecting the cable, the unit was good to go.
I hope this information is able to help you out.
Good luck.
-Steve
http://www.simrad-yachting.com/Root/Operator%20Manual/SimradYachting/English/AP16_OM_EN_20221560F.pdf
You MIGHT get some joy contacting Simrad tech. at 1 800 628 4487
if you're in the US. If not, here's the link to their support page.
http://www.simrad-yachting.com/en-US/Contact-Us/
Dec 08, 2014 | Navico Simrad AP16 Autopilot for Inboard...
Where can i get memory battery for simrad ce30 chart plotter
There should be a model number printed/stamped onto the battery. Put this number into Google and yuo should have a list of sources. One of the local battery replacement places (like batteries Plus) can match it up or order one for you.
Jul 08, 2013 | Boating
Simrad ce30
my dads does the same, it is the memory battery from past experience
Apr 05, 2013 | Simrad Boating
My Raymarine C80 CHart plotter won't load.
Check to see if this is a power issue by connecting to shore power and fully charging your batteries overnight with instruments off. While still connected to shore power, with batteries fully charged, turn on C80 navigation system. If the loading screen comes on and does not reset, then try holding down the button immediately to the right of the red power button for at least 3 seconds to see if the system re-boots.
Apr 13, 2010 | Raymarine C80 GPS Receiver
Furuno 1850 has water in unit, only noticed
http://www.fixya.com/support/r3771170-phone_water_damage
Nov 06, 2009 | Furuno 1850WF Gps Fish Finder Combo...
The chart plotter worked perfect for 5 yeas,
I think you have a C- Map card (black colour)clean the contacts with a contactcleaner if it not works try the card somewhere else
The C-Map card have problems that they work for a while and than stops inside the card a some memorychips and they losing contact
Sep 27, 2009 | Raymarine A65 Combo GPS...
I cannot get a position on my Simrad CE33 chartplotter/sounder
Ensure that the external position to be OFF, refer to manual below. See interface display in [MENU],7,2
Try resetting the Chart Plotter to factory settings. Use the Delete Memory and Factory Preset options as described in section 9 of the user manual below:
M A N U A L Simrad CP33 Chartplotter
Sep 05, 2009 | Simrad CE44 GPS Receiver
Need instructions for simrad tp32
when hooked to a chartplotter, it will go to the waypoint that was marked as a goto on the plotter.
Mar 31, 2009 | Simrad Tp32 Autopilot Up To 39'
Raytheon rl70
I've had the same problem. before replacing the antenna, try to reset the antenna by removing power to the Raystar 120. Disconnect power by either turning off all batteries or disconnecting the red wire from the antenna at the point where it enters the junction box for the chartplotter. This action effectively removes all memory from the antenna and resets it to factory settings. There is a lithianium battery in GPS antenna that holds memory data in the antenna. Disconnecting the power to the antenna for a few seconds clears the memory.
This is exactly what I did and when I turned the chartplotter back on, my Raystar 120 immediately began working again.
May 05, 2008 | Raymarine RL70CRC GPS Receiver
Televison & Video Logo
Top Televison & Video Experts
