Question about HP Pavilion MX75 17" CRT Monitor
Pavilion MX75 monitor clicking.
My monitor keeps clicking and changes the settings on its own. I keep going back and changing the settings, but the monitor has a mind of its own. Any help would be greatly appreciated. Thank you, Linda
  • HP Master
  • 12,061 Answers
What has happened is the automatic screen size & resolution detection circuitry is going/gone faulty. You usually hear this sound ONLY when ya change screen resolutions, ie: when say ya change from 800x600 to 1024x768 or the like. With 2nd monitors so inexpensive these days repair is often NOT warranted.. so perhaps it is time to upgrade to another. However if ya choose to have it repaired obtain a "Quote" and an explanation B4 ya proceed.
Posted on Aug 09, 2007
SOURCE:
Samsung screen flicker
Have you recently changed the resolution/refresh rate? This is usually set automaticallly by windows by check anyway.
Right click the desktop and select Screen Resolution
Change the slider/dropdown to the (recommended) selection and click apply. Click keep changes if it appears.
Still having issues then go back into Screen Resolution and click the "advanced settings" blue link on the bottom right.
Click on the "Monitor" tab and select the highest refresh rate you can and click ok. again click "keep settings" if it appears.
Dec 23, 2012 | Samsung X Computers & Internet
My monitor keeps going to sleep dont know how to wake it up
click on the power button to wake it up. then go to control panel and click on power options to change the settings for your power management.
Jul 02, 2010 | HP Pavilion a1540n PC Desktop
How to fix start switch on hp mx75
It shows that the switch of your monitor is malfunctioning, it is having partial contact, that is why it works atimes.
I advice you replace the switch so as to get maximum effective use of your monitor.
Take care
Apr 29, 2010 | HP Pavilion MX75 17" CRT Monitor
Mx75 monitor turns off when I awaken my computer
right click on desktop select properties(screen saver ) select monitor button in that select turn monitor never.(configure carefully)
Nov 24, 2009 | HP Pavilion MX75 17" CRT Monitor
Monitor keeps going of then coming back on in 5
right click on desktop.go to properties.in properties go to the screen saver tab.under the screen saver tab u will see something called power.click on power.change the settings of the monitor there.let me know if it works
Sep 05, 2009 | Computers & Internet
Keeps turning off
Make sure the VGA cable is plugged in all the way and screwed down. These units were made in 2002 so it may just be too old to go on. A repair would probably cost more than a new or used flat screen LCD.
Aug 20, 2009 | HP Pavilion MX75 17" CRT Monitor
Can you tell me where USB port is located in HP pavilion MX75
USB ports are located on the back and also on the front on newer desktop PCs. These are on the computer tower - not the monitor as your posting is categorized. They are rectangular slots with four copper contacts inside.
Jan 30, 2009 | HP Pavilion MX75 17" CRT Monitor
Possilbe to reset monitor?
This document pertains to MX50, MX70, MX75 and MX90 CRT monitors.
NOTE: To reset the monitor to factory settings:
  1. Turn off the monitor by pressing the POWER button.
  2. Press and hold the plus (+) button and then
  3. Whith the Plus (+) button pressed, press the power button to turn on the monitor.
  4. Release both buttons.
Jan 01, 2009 | HP Pavilion MX70 17" CRT Monitor
Monitor turning on and off
try to get a second monitor that you know works and plug it into the computer. This will tell you if it is the monitor or the connection to the computer. If everything appears ok with the new monitor then you have to get a new one which is probably the case
Sorry for the news. Next time there is a big thunderstorm unplug everything and make sure that your computer is plugged into a surge protector at all times. This will save a lot of money and headaches
Jul 05, 2008 | HP Pavilion MX75 17" CRT Monitor
Monitor
try to set setting at desktop setting.Set to a hiher resolution 1024 by 768 resolution.
Apr 20, 2008 | HP Pavilion MX75 17" CRT Monitor
Open Questions:
See all HP Pavilion MX75 17" CRT Monitor Questions
HP Pavilion MX75 17" CRT Monitor Logo
66 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
