Cash register beeps
My Royal 583cx makes a beeping noise and display a message "Free 653L" The message clears when pressing the clear key, but reappears again with a beeping noise when the next plu is entered...please help!
Maanita
  • 1142 Answers
SOURCE: casio cash register not working
error code 1 on your cash register is due to Mode switch position changed before finalization
you can fix this error by Returning the mode switch to its original setting (does not beep) and finalize the operation
Posted on Jan 23, 2008
jdrrwoods
  • 82 Answers
SOURCE: royal 325cx cash register
http://www.howtomendit.com/questions.php?id=121&page=3
Posted on Feb 08, 2008
flexion1
  • 737 Answers
SOURCE: XE-A102 cash register
Hi. You have set the register to program mode. Turn the key back to Z/PGM, then press SUBTOTAL (you might have to press it twice).
It may print a list. This is normal. Then turn back to reg mode, and you should be back in business.
Mark
Posted on Jul 12, 2008
flexion1
  • 737 Answers
SOURCE: I cannot change the price for an item on CASIO TE-2400 register
Hi. I'm afraid this is not a 'basic requirement' of a cash register. You are working with a very complicated area of cash registers that only the medium to high end machines can even do. If you are getting stuck already, then you will not be able to work out the more complex batch processing areas of scanning either.
Your dealer should have setup the majority of this for you before you left their store (especially the keyboard layout issue and keysheet for the keyboard), then you would normally receive extensive training if you are going to be making program changes yourself in future.
You will need to learn about the difference between flat PLUs and scanning PLUs, 'Not found PLUs' like you have run into so far, then deletion techniques, PLU status programming, manual entry using OBR method etc. The book is only a guide to what you should have learnt during training. You really need to go back to the dealer and get a training session. They should be able to sort out all of these problems for you. It will take a one on one demo to fully train the ins and outs of full scanning systems.
Mark
Posted on Nov 17, 2008
sodeep
  • 3267 Answers
SOURCE: CASH REGISTER CASIO CE 3115 DISPLAY E 03 AND ALARM
This ino might help: Cleaning ERRORS: ______________________________
1.- Turn the Mode lock to OFF
2.- Press down the RECEIPT FEED button
3.- Turn the key to PROGRAM
4.- Lift up RECEIPT FEED button (FFFFFFFFFF)
appears on the display panel
5.- Press SUBTOTAL (wait for receipt to issue)
6.- Turn Mode Switch back to REG and use as Normal.
Also another bit goes like this:
RESET: _______________________________________
1.- Insert the OW key and turn to OFF
2.- Hold down the JOURNAL FEED button and turn the key to PROGRAM mode
3.- Release the JOURNAL FEED button. The display should shows "00000000".
4.- Turn the key to OFF
5.- Turn to REG1. The display shows "INIT" and "0.00"
6.- Press the number 10801 and then press SUBTOTAL. Initialisation is completed when the printer stops operation. The display shows: "_ 0.00"
Hope this helps in restting to factory settings................................sodeep
Posted on May 12, 2009
Sharp XE*A20S error code 7-15P
It sounds like you are seeing the time display. Turn the key to REG mode and try pressing CL (clear). If it doesn't beep, get the keyboard checked by a technician
May 12, 2015 | Sharp XE-A202 Cash Register
How can I clear a transaction and start over, when I keep getting an error message and beeping?
I would try to input an amount to see if it clears, if you still have manual that came with it there is a number that you can call for help
Mar 09, 2015 | Retail Supplies
I have a Royal 9155SC register. The display shows 0.00 and no key is working with continuous beeping. Please help.
Half Sysem Clear
a. Turn the key to the "PRG" position.
b. Unplug the cash register from the power source (pause
for 10 seconds) and replug the cash register.
c. Continue with normal operations.
Full System Clear
!!! THIS WILL ERASE ALL PROGRAMMING AND DATA!!!
a. Turn the key to the "PRG" Position.
b. Unplug the cash register from the power source and wait
at least 15 seconds.
c. While holding down the [CLEAR] key, replug the cash
register.
d. Re-program the cash register.
e. Continue with normal operations.
Oct 28, 2014 | Royal Office Equipment & Supplies
My sam4s er-180t cash register wont respond it just beeps and comes up with E00
try to do an 'initial clear'
turn power switch on right side of reg to OFF pos
turn control lock to P position
press and hold SBTL key and turn power switch to ON pos
should print 'Initial clear ok'
might need to repeat a couple of times
Jun 22, 2014 | Sam4s ER-180T Cash Register
Cashregester loked
Make sure it has a new roll of paper, then turn it off and on. Try to use it in Reg. If it doesnt work, then turn the key to the other positions and see if it works in another key position. If it does, press clear, then cash. If it still doesnt work, come back with more info. Does it display any error message?
Jan 28, 2014 | Sharp XE-A402 Electronic Cash Register
Cash register PE ondisplay and nothing will work
It means printer error. Usually after a paper jam. Clear any paper out and try turning off and on at the wall. ***************************************************************************** *****************************************************************************
All of these manuals can be downloaded at: http://the-checkout-tech.com/
royal 110cx User royal 115cx User royal 130cx User royal 425cx User royal 435dx User royal Alpha-580 User Programming royal Alpha-583cx User Programming royal Alpha-600 User Programming royal Alpha-600sc User Programming royal Alpha-601 User Programming royal Alpha-710ml User Programming royal Alpha-9155sc User Programming royal Alpha-9180sc User Programming royal TS4240 User Programming
Mar 02, 2010 | Office Equipment & Supplies
Casio cash register model # PCR-202
E01 usually shows if you change the key position without clearing out register. Try going to each mode and pressing subtotal and then cash until the drawer opens. See if that helps.
Mar 30, 2008 | Office Equipment & Supplies
Computers & Internet Logo
214 people viewed this question
David Payne
David Payne
