Question about Chevrolet Vehicle Parts & Accessories
How to replace a crankshaft sensor in a 2000 chevrolet suburban 1500
  • Chevrolet Master
  • 5,680 Answers
You have to take off crankshaft pulley,is there.
Posted on May 09, 2013
4 wheel will not work. the selector switch will show it is in but front tires will not engage No messages on control center
Search Results
    4WD Transfer Case Position Sensor/Selector ... - RepairPal
    repairpal.com > Problems > Chevrolet > Tahoe
    Service 4WD Message May be Displayed on Chevrolet Tahoe. The 4WD transfer .... I had a similar problem with 4 wheel drive selector switch. When I select 4 ...
    repairpal.com > Problems > Chevrolet > Suburban 1500
    Service 4WD Message May be Displayed on Chevrolet Suburban 1500 ... When in 4 wheel , it will not in engage sometimes and message comes on to service 4 wheeldrive. ... I replaced the 4wd transfer switch in 2007 and now again it is not working, this would be the ... 2008 Chevrolet Suburban 1500- 4WD156,000Visitor.
    Chevrolet Tahoe Repair: Problems, Cost and Maintenance
    repairpal.com > Cars > Chevrolet
    Having problems with your Chevrolet Tahoe? Learn about common Chevrolet Tahoe problems, recalls and typical maintenance and repair costs. ... ABS Front WheelSpeed Sensors May Fail. Chevrolet Tahoe ... 2008 Chevrolet Tahoe.
Jan 21, 2016 | 2008 Chevrolet Tahoe LTZ
About how much is it to replace crankshaft sensor
I would question crank sensor they normally put management light on check breather pipes and gaskets first if it is the sensor it's about an hours labour plus price of the part good luck.
Aug 24, 2014 | 2000 Chevrolet Silverado 1500
Crankshaft Position Sensor location
It should be right below the harmonic balancer or crankshaft pulley on the engine block
Aug 04, 2014 | 2009 Chevrolet Suburban
Where is the crank shaft sensor on a 93 chevy truck 1500 4.3 liter
should be by the crankshaft pulley front bottom of engine
Jan 18, 2013 | 2000 Chevrolet Silverado 1500
Where is the cam shaft location sensor located on a 2005 gmc yukon
camshaft sensor located above crankshaft pulley, the camshaft sensor mounted on the front timing cover above the crankshaft pulley.
Sep 17, 2012 | 2005 GMC Yukon
2000 chevrolet silverado 1500 4.3l v6 misses at 2000 rpm and now wont start
It sounds like u have a cam correlation problem... Take ur cap off mark where ur rotor is pointing on the dist. Mark the firewall where the dist plug is pointing take the 10mm bolt out n look @ the dist gear and see how bad it's worn!! When u take the cap off some times they're so bad when u move the rotor u can tell the excessive play hope this helps!!!!
Dec 18, 2011 | 2000 Chevrolet Silverado 1500
How do you replace the crankshaft position sensor on a 1999 Chevy Suburban 1500?
That should be right behind the harmonic balancer in frt of the engine the crank sensor should bolt into the timing chain cover.remove bolt and with a twisting action pull sensor straight up.
Feb 10, 2010 | 1999 Chevrolet Suburban
Where is the crankshaft sensor located?
front of engine right next to harmonic balancer.
Jan 25, 2010 | 2003 Chevrolet Suburban 1500
Vehicle Parts & Accessories Logo
29 people viewed this question
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
