Question about Dell E2011H Monitor
Screen resolution desktop
My lcd is not changing its screen resolution it is stuck on 640x480 and the screen is blurry what do i do ?
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 40 Answers
Go to control panel from start menu. change resolution to 1280
Posted on May 09, 2013
Windows 7 screen goes to large resolution and needs reset on startup.
Turn on the PC. Press F8 at booting into windows 7. It will display  many options
Select the Enable low resolution video(640x480) then login to system.
then change the resolution as required
Right click on a empty space on the desktop and click on Screen Resolution.
Enable low resolution video (640 × 480)
Jun 08, 2011 | AOC 718Swag-1 LCD Monitor
How to get 1200 X800 resolution
It depends upon the notebook you use if it support the resoulution you want. You can change the resolution by display properties in control panel. Also 1280*800 is used only by widescreen desktop or laptops.
Mar 24, 2010 | Compaq Presario 700 470024-192 Notebook
I have samsung syncmaster 740nw how can i increase screen resolution to 1024x768?
you cannot set the resolution to 1024x768 but instead try 1280x720 or if you have graphics card try to set the resolution using its custom resolution by setting 1280x768.
It will surely solve your problem.
-ravi
Dec 31, 2009 | Samsung SyncMaster 740N 17" LCD Monitor
Icons are blurry
Did it happen all of a sudden? In other words, was it OK before?
Try going to screen preferences, settings, and look at the resolution slider - is it set to the native resolution of your monitor (1280x1024)? If not, correct and accept changes.
If the resolution is set OK, then multiple other things might have happened, but not knowing a bit more about the situation it's hard to advise anything...
Nov 08, 2009 | Samsung SyncMaster 931B 19" LCD Monitor
I've got a dell computer and i'm trying to swap the crt screen to a packard bell lcd screen and it wont display is there a driver i have to get or are they just not compatable
It probably a mismatch between resolution, colour depth and refresh rates. Before you disconnect the CRT change the resolution to 640x480 and 16 colours with a 60Hz refresh. Then connect the LCD and adjust the settings
Aug 29, 2009 | Dell Dimension 4600 PC Desktop
Can't view connected Dell Inspiron 9400 computer on Toshiba 37 AV52U TV
You need to change your computer display settings following your TV user manual.
Here follow the compatible display settings as on page 57-chapter 9 on manual.
Put resolution 640x480 and frequency 59,940Htz.
Here the user manual where you can find the same information on chapter 9.
See How to change display settings: screen resolution, screen
refresh
Do not forget to evaluate the solution.
Many thanks.
Mar 08, 2009 | Computers & Internet
Changing Screem Res to 1024x720
Hi LSmitten,
So your brother has laptop, and you can't change the screen resolution, I will take a guess that most likely the screen resolution right now is 800x600 or 640x480 which most games won't work with. The most likely culprit why you are not able to adjust the video resolution is that he hasn't installed the video driver of the laptop yet. You should install the video card driver for your laptop in other for you to change the resolution of your desktop. I suggest that you download the latest video driver from the computer manufacturer's website.
Also if he is using a older laptop, the LCD screen on a laptop has a set maximum resolution that you can use only. Older model laptops can only go as high as 800x600 upto 1024x768. Most of the new laptop nowadays have a minimum LCD panel of 1280x800 widescreen. Check the PC manual to see the max resolution the LCD can handle.
Hope this helps!
Peace! :)
Oct 20, 2008 | Computers & Internet
Dell E2011H Monitor Logo
76 people viewed this question
Alun Cox
