Question about Garden
Countax will not start
I have a countax 300h about 8 years out Will not start and a warning letter C is lit up any ideas what is wrong
  • 246 Answers
SOURCE: I have a Countax K14 ride on mower the cutter deck
Hello ianh_2007:
Usually this Problem is Caused by a Blown Fuse or a Bad PTO Ground.
1-The Following is a Basic File I Made for Checking the PTO (Blade Engagement).
>>The Most Common Cause for this Problem is the PTO Ground. >>A Quick Ground Check is to Use Another Wire and Ground the PTO at the Harness Connection Nearest the PTO.
>>Be Careful and Do Not Ground the HOT Wire. Use a Multimeter and Locate the Ground Wire.
>>Clean the PTO Ground and All the Connections for the PTO Wiring Harness.
>>If you have an Ohmmeter, Disconnect the Wiring Harness from the Front of the Clutch and Check the Resistance of the Clutch. You should have around 4 or 5 OHMs. If at or near Zero, the Coil has Shorted.
2- >>The Following is a Basic File I made for Setting the PTO Clearance. Any Input is Appreciated. **Some of the Newer PTOs cannot be Adjusted.
>>If you can Get a Blade Style Feeler Gauge between the PTO Magnet and Clutch, then Set the Clearance at .015in. The Newer PTOs have the Same Set Up as the Older PTOs, except there is No Adjustments.
>>I Suggest also that you Rig a 12 Volt Light for Testing the Current Flow to the PTO while Operating the Mower. If the Light Blinks During Operation, then you have a Bad Connection somewhere to the PTO Clutch.
>>If the Light Stays Steady and the PTO Still Kicks in and Out, then it is the Adjustment.
>>You can Also Try Turning the Spring Loaded Adjuster Nuts 1/4 Turn and Operate the Mower. Do Not Adjust Over 1/2 Turn.
>>If you have Adjusted to 1/2 Turn and the Problem is Still Present and you Know the Voltage to the PTO is Steady, then Replace the PTO.**
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 12, 2009
  • 168 Answers
SOURCE: blades not cutting checked all belts they are ok
Either the belts are worn making them too loose, or you may have a spindle issue there. Check the spindles to make sure they aren't seized. Also, check the blade center nuts to make sure they are tight. Good luck.
Posted on Oct 09, 2009
  • 4 Answers
SOURCE: is it possible to download the repair manual for a
Phone Countax Customer support on 01844 278800. Tell them what manual you require, the exact model/year are on a sticker inside the console below the dashboard usually. Record the serial numbers for the deck and PGC also, they both should have stickers too. Countax will send you out a copy of the correct manual for free. Good luck.
Posted on Jun 20, 2010
  • 4 Answers
SOURCE: require an electrical circuit diagram
Call Countax on 01844 278800, they're customer service is usually good at supplying this sort of info. Ask for a parts list and user manual while you're at it.
  • 4 Answers
SOURCE: where can I download Countax E36 user manual from
Call Countax customer support, they will send you one free. 01844 278800
Looking for a workshop service manual for a 2010 Countax c800h
It appears they do not make a separate manual. They seem to offer various procedures and optimizations that you can perform on their website and some basic troubleshooting in the operating manual.
A link to Published Service Procedures:
http://www.countaxtractorspares.co.uk/help/countax/service-bulletins
A Link to the Operators Manual (that you may already have):
https://www.manualslib.com/manual/1068349/Countax-C330-Mini.html#manual
Jan 31, 2018 | Ariens Garden
Where can I get a workshop manual for a Countax lawn mower/garden tractor?
I wish I could post the address to your mower, but there is not enough information. Start here:
Countax Tractors
or
https://support.ariens-uk.com/support/home
Dec 28, 2015 | Garden
How do I adjust the throttle/speed on my countax C800 ride on Mower
Making a throttle adjustment for the mower - YouTube
? 23:51
https://www.youtube.com/watch?v=gt0Tmo1p9cM
Apr 8, 2012 - Uploaded by VeeTheAmazingGreek
My old mower was all over the place when running. It would idlehigh then low. I came up with a way to ...Missing: countax ‎c800
[PDF]C SERIES - Pdfstream.manualsonline.com
Nov 23, 2015 | Garden
Countax C300H Garden Tractor Manual
Apr 04, 2012 | Garden
I need a wire diagram for a countax c400h
I am sorry but Fixya has no wiring diagrams for any product.
Mar 13, 2012 | Cars & Trucks
Where can I get a replacement cutting deck for a Countax K14 tractor mower?
Not sure of your geographic location but here is the contact data for Countax:
http://www.countax.co.uk/contact_us.htm Call them using the 0800 number on the linked page.
Parts link:
http://www.greenstripe.net/Parts-diagram/Diagram-405_Page-1.aspx
60 32726700 36 IBS DECK SHELL £300.11 view 60 32726601 38 IBS DECK SHELL £301.75 view 60 32726500 32766500_34 £302.82 view 60 32732500 48 DECK SHELL £265.49 view
If you not in the UK, I need to know your location please to locate other sources in your area.
Thanks for choosing FixYa,
Kelly
Aug 24, 2011 | Garden
My countax mower c300 keeps blowing the p c b board
hi, my countax k18 is needed for this season for my buisness, after about 10 or so minuits it cuts out on me, no deck attached And i havnt engaged or disengaged anything... any ideas?? its defo electric as it cuts out really quick....
Mar 25, 2011 | Garden
Is it possible to download the repair manual for a countax T1200 on line
May 14, 2010 | Garden
Where can I download Countax E36 user manual from ?
Oct 22, 2009 | Garden
Require an electrical circuit diagram for countax K18
Jul 29, 2009 | Garden
Garden Logo
12 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
