Internal modem not connecting
  • 7,627 Answers
Are you trying to use the Fax Modem? It would be helpful if we knew the Make, Model of Laptop and the OS you are using.
Posted on May 03, 2013
My dimension 3100 is not detecting a modem
Sir,
Respectfully please first check if there is a modem in the desktop PC since the dimension 3100 is not pre-equipped with a modem. you have to attach an internal modem manually on one or more PCI slots on the mother board.
the process is given here....
  • Turn off the computer. Unplug the power cord from the electrical outlet. Disconnect the power cord, attached peripheral devices and any other cables.
  • 2 Locate the cover release latch on top of the computer, near the back. Place the computer on its side, with the removable cover facing upwards. Slide the cover release latch back and lift the removable cover off of the computer. Set the removable cover aside.
  • Locate the PCI and PCI Express slots near the bottom of the system board. Select a slot that corresponds with your internal modem card. Open the card retention door on the back of the computer and remove the filler bracket for the card slot you will be using.
  • 4 Place the internal modem card into the appropriate card slot and press it firmly into place. Close the card retention door. Replace the removable cover and return the computer to an upright position.
  • 5 Connect one end of the telephone cord into the LINE port on your internal modem card; plug the remaining end into a telephone jack. If desired, connect a telephone to the internal modem card via the PHONE port.
  • 6 Reconnect the power cord and all previously disconnected cables. Plug the power cord into an available electrical outlet. Turn on the computer. If any installation software came packaged with the internal modem card, run the program and follow the onscreen directions. Your internal modem is now ready for use.
  • May 06, 2011 | Dell Dimension 3100 PC Desktop
    I know this is a stupid question...but does my laptop need to have an internal modem to connect to the internet
    well according to the specs i saw it already has a wireless lan card, an ethernet card, and a old school phone modem jack, so you should be good. are you having issues connecting to the internet via wifi?
    Nov 03, 2009 | Dell Latitude D600 Notebook
    Trying to connect to internet but screen says internal modem has no driver - it sees no modem
    If you're compuer is connected to a router or DSL/Cable modem through Ethernet connection, you don't need to have to use internal modem. Internal modem are just for dial up connection.
    If everytime you launch IE browser and it gives you that prompt, your browser may have set up to connect everytime to a dial up connection. Try to check these settings on your IE:
    1. Go to Start> Settings> Control Panel> Internet Options
    2. On Internet Options, go to Connections tab.
    3. Delete everything under Dial Up and Virtual Private Network Settings, Or just set it to 'Never Dial A Connection'.
    4. Click on LAN Settings button.
    5. On the next window, uncheck everything (particularly the proxy setting).
    6. Click OK all the way out.
    Oct 23, 2009 | HP Pavilion a1610n PC Desktop
    Internal modem is not working
    Are you sure it's a modem port and not a ethernet port. They look very similar and people confuse them easily. The ethernet port is slightly larger though. So we can verify we're talking about the correct thing, are you using dialup to connect to the internet? or are you connecting to a broadband router or dsl modem?
    in either case you should be able to get drivers on dell's website and copy them over to your laptop.
    Oct 07, 2009 | Dell Inspiron 2200 Notebook
    I've got an Everex 3400+ and when I plug my cable in from my cable modem into the internal modem it's not showing that it's connected. Is there a driver I need to download. can you recommend a network...
    Please dont connect a cable modem to an internal modem.
    These are not the same types of device.
    you need to connect from the cable modem to the ETHERNET port.
    They look similar but ethernet is slightly larger.
    Dont use a telephone cord for the ethernet connection it is the wrong one.
    Sep 14, 2009 | Everex GA3400 Refurbished AMD Desktop...
    Cant connect to xbox live need an ip address how do i get one
    When the SurfBoard modem is powered up and connects to the internet on the WAN interface, it automatically gets an IP address from your ISP. When another machine is powered up and is connected to the modem via a USB cable, it is automatically using the WAN IP address to communicate with the world. If it is connected via the Ethernet connection, the modem automatically issues it its own IP address for use on the internal network via DHCP. The modem's internal Ethernet connection is 192.168.0.1. The next machine powered on will normally get an IP address of 192.168.0.2.
    May 30, 2009 | Arris SURFboard® SB5101 Cable Modem
    Internet connection through Internal modem in Laptop
    Two solutions:
    First for the more experienced:
    find the modem on the underside of the laptop unscrew/ re-seat the modem, test, if it works great, if it doesn't try inserting foam, or paper between the modem and the "black case"... if you cant find the modem locate the manual for the laptop.
    second (and possiblely the best)
    Disable the onboard modem and replace it with a USB one
    Aug 28, 2008 | Compaq Presario 700 470024-192 Notebook
    Wireless connection
    3 Com U.S. Robotics 56k External modem
    INTRODUCTION
    Today, with the set standards of V.90, purchasing a modem is a much less confusing task and sometimes considered easy.
    Before purchasing a modem, take the below into consideration. Today, with the popularity of the Internet and multimedia over the Internet, broadband is becoming widely available. If available in your area, you may want to consider purchasing a broadband solution, such as DSL available through a phone or third-party company, Cable available through your local cable provider, Satellite available through a third-party, or through a large ISP such as MSN or AOL.
    If a broadband connection is not available in your area, below are some recommendations to consider when purchasing a computer modem.
    STANDARDS
    Originally, when the 56k connection was introduced, there was not a set standard between two major modem manufacturers, causing there to be two different technologies, X2 and KFlex. Each of these technologies allowed for a modem to connect at higher speeds, but only if the Internet Provider supported the technology. Because of the difficulties and issues with these two different technologies, one technology emerged out of the two, called V.90. This technology will allow users of any brand of modem to connect at higher speeds.
    Today all modems (purchased new) are V.90 and this is no longer a concern. Additional information and history about each of these technologies can be found on our Modem Standard page.
    INTERFACE
    Interface can be an important when considering purchasing a modem. It is important that your computer has the available connections and resources when purchasing a modem.
    PCI / ISA (Internal) – PCI / ISA modems are modems that are found in most computers today. These modems are installed internally into the computer with an available connection on the back of the modem for the phone line.
    When purchasing this type of modem it is important that you verify your computer has the available connection for this modem within the computer (PCI or ISA). In addition, verify that your computer has the available resources. You can sometimes have difficulties installing a modem if a serial device, such as a Serial mouse or Serial PDA, is connected to the computer.
    Serial (External) – A serial modem connects to the serial port located on the back of the computer. These modems are generally easy to install; however, they can cost more than an internal modem as you pay additional money for the plastic cover.
    When purchasing this type of modem it is important that you verify your computer has an available serial connection on the back of the computer; devices such as a serial mouse may already be utilizing your serial port. Some computers may have two serial ports; if this is the case and only one serial port is currently being utilized, verify that the second port can be enabled or is already enabled in CMOS.
    PC Card (PCMCIA) – Solution used with portable computers, PC Card modems are fairly cheap and relatively easy to install in the computer.
    If a modem is already present in your portable computer but you wish to upgrade or the internal modem has gone bad, it is important that you verify the pre-existing modem can be disabled before installing the new modem.
    USB – A new solution, USB allows a user to install up to 127 devices on the computer and is available for PC and Mac. Before purchasing this solution, verify that your computer has a USB connection. If no USB connection is available, an additional card will need to be installed in the computer.
    CONNECTION
    The connection can differ depending upon the type of modem purchased with the computer.
    Internal / External / USB modem – Today, all modems have a RJ-11 connection, which is a standard phone connection, on the modem. If important to you, verify that the modem has two available RJ-11 connections. One of these connections will connect the modem to the phone and the other can be used for an office phone. This can be very useful for a home or office computer that may need a phone next to it.
    PC Card modem – When purchasing a PC Card modem, the connection can be a very important factor consideration. Below we have listed the pros and cons of each of these connection types.
    Dongle – A commonly found solution for PC Card modems, but a very burdensome solution. The Dongle is an additional cord that connects from the PC Card to a small opening for a RJ-11 connection. While a good thought, we find that these connections get lost often. The pro of this solution is a very sturdy connection and a solution that will allow only a Type II slot to be used, allowing and additional slot free for another card.
    Standard – Standard connection, like a desktop modem, allows for a phone line to be connected directly to the modem. This solution allows for no additional cables. The con to this solution is that these cards will generally occupy your complete PCMCIA slot, although Xircom offers a solution that will not.
    Xjack – An excellent solution for Portable computers, the Xjack by 3COM allows users a similar connection to the standard connection without the use of any additional accessories or lost space. The con to this solution is that the Xjack can be damaged very easily.
    Good Luck ! Read and follow instructions/Please dont for get to Vote/Thank You.
    Dec 25, 2007 | Medion MD-40954 Notebook
    Modem
    To access the ports you mean via the control panel.  If it is an internal modem then XP would automatically install it as a hardware providing it is connected to the motherboard.  I detected you saying that you rebuilt the PC.  Have you slotted an internal modem into one of the periferal slots or did it use an external modem.  Did you know you dont need a modem to logon to the net unless your dialing up? But if you use broadband most use an external modem that connects fast ethernet connection.  But I suppose you know this after all you rebuilt the machine.
    Oct 10, 2007 | Toshiba Satellite A10-S167 Notebook
    Computers & Internet Logo
    13 people viewed this question
    David Payne
    David Payne
