Question about Sharp EL-2192Rll Calculator
Changed both ribbons on calculator now printing garbage
Changed both the black and red ribbon on my EL2192RII calculator which I have done before. Now it is printing garbage. The display is correct but I is printing odd numbers and symbol. Example I enter 123 + and it prints . (2 spaces) $ or # cant tell which then 2 or 3 spaces behind. When I feed up the paper to look at it prints 7 6 7 in a vertical row. Help?
  • 186 Answers
SOURCE: The ribbon is no longer printing on the tape.
are you sure it uses a ribbon? Or does it use an ink roller. If it uses a ribbon it should reverse by it self. Make sure it is installed properly, there is not a ribbon reverse switch it should do it automatically. if its installed right.
Posted on Jun 17, 2007
SOURCE: Replacing inking roller/ribbon?
i had a problem with this as well and found a user manual online. I thought the whole thing came out but it doesn't. If you pull up on the little red thing on right and then the black one on the right you have it. Imagine that! That's all that you change. Then just put some new ones in and your good to go.
Posted on Apr 10, 2009
SharpCSR
  • 11 Answers
SOURCE: Where do I feed my paper into the Sharp El-1801P calculator
Hello, my name is Curtis, I am a Sharp Customer Servicer Rep. Normally the calculator would have a thin slot on the back, where you would feed the paper through, then once you press the paper in till it hits an inner wall, you would press the feed key which is on the upper left side of the calculator. If there are any problems doing this please call our technical support line at 1-800-237-4277, I am very glad to hear you like the calculator though!!!
Posted on Jun 30, 2009
SOURCE: Have a Sharp Compet CS-2790 calculator. How do I change the
I work for the state and cannot incur a charge. Sorry for posting my question. The problem is still not fixed. Was trying to help someone else that has the calculator.
Posted on Oct 08, 2009
  • 16 Answers
SOURCE: CALCULATOR MIS-FUNCTION .
unfortunately the printer is out of time or the selector pawls got bent. would be cheaper to buy a new one than fix this.
Posted on Apr 28, 2010
How do you change ink on a canon p20-dh calculator
For accounting offices and stores, calculators that produce a printed paper are indispensable. Canon's desktop or commercial printing calculators use ribbon tape, and you'll need to change the ribbon when it is used up. All Canon desktop and commercial printing calculators use the same method for changing the ribbon.
  • Turn off the calculator.
  • Pull up on the tab on the far side of the printer cover to remove the cover.
  • Pinch together the ribbon lock (the arrow shows you the direction to pinch). Lift the ribbon spools off the shafts and discard them.
  • Separate the new ribbon spools. Guide the ribbon tape around the four guiding pegs and set the spools on the shafts. The spools should be peg side down.
  • Rotate the spools so the peg at the bottom of the spool goes into the hole of the spool holder. Release the ribbon locks.
  • Rotate the spools to make the ribbon taut, keeping the ribbon positioned around the guide pegs.
  • Replace the printer cover and turn the calculator on.
How to Change the Ribbon in Canon Calculator eHow
Feb 06, 2016 | Canon Office Equipment & Supplies
HOW DO I CHANGE THE INK IN THIS OLD CALCULATOR? THE RED IS COMPLETELY GONE AND THE BLACK IS VERY LIGHT
What model is the calculator and if it's a inker type then you have to replace the ink roller. If it's the ribbon type then you have you replace the ribbon. You can pick those inker or ribbon from Edmonton Cash Register Co. Ltd. or send us a email to order
Apr 10, 2015 | Casio HR 100TM Portable Printing...
Sharp EL-1197PIII Calculator won't print using the blank ink. Ribbon is correctly installed.
I still have to believe that your ribbon is not quite seated properly on this. I would check that again. If this is not a "cartridge" then Check to see if it is upside down.
Jan 15, 2015 | Sharp EL-1197PIII Calculator 12-Digit...
Why does my Canon MP49D calculator print light?
Could it be you are using old ribbons? Are you using the correct ribbons?
did you put in the ribbon correct and is the ribbon transported, while it is printing, or is it stuck in the calculator. Just some questions to check out.
May 06, 2014 | Canon Office Equipment & Supplies
Only prints in red
may have print ribbon installed upside down. what happens if you try printing a negative number? if that number prints in black, try turning ink ribbon over
Jan 02, 2014 | Canon MP49D Calculator
Replacement ribbon for canon mp-11dx calculator
I did replace the ribbon correctly. I used a universal replacement. the black part of the ribbon in on the top and the red at the bottom but I am not able to print clearly on the tape. What would be my problem?
Sep 23, 2012 | Canon MP-11DX Calculator
The ribbon will only print red ink
While in the D position or PD position, N Count
is OFF. In the N Count N position every
Plus, Minus, Equals Plus, Equals Minus,
Memory Plus or Memory Minus key depression
is counted. The Accumulator and its N Count
or the GT N Count can be printed by
depression of the Subtotal or Total key. When
either Memory Subtotal or Memory Total is
depressed, Memory N Count will print. N Count
is always printed in red, left justified. If the
Equals key is depressed immediately after the
Subtotal Total, Memory Subtotal, or Memory
Total the average of the entries is printed.
When the N Count prints on the 7150, an audit
symbol will print to the left of the N Count.
The audit NA will identify the Accumulator
register N Count, NG will identify the GT
register N Count and NM will identify the
Memory N Count.
Apr 23, 2012 | Monroe 7130 Calculator
How do you change the ribbon
Hi mkline519,
The new ink roller types are EA-781R-BK (Black) and, EA-781R-RD (Red).
To change the ink rollers.
1). Set the power switch to off.
2). Remove the printer cover. The little paper guard or, flap on top.
3). Remove ink rollers by turning each one counterclockwise and, pulling upwards. With the calculator facing you. Red is on the left and, black is on the right.
4). Install the new ink rollers in there correct position's. Simply press them in one at a time and, make sure they are secure.
5).Put the print cover back on.
If calculator prints blurry, the rollers may not be not secure. If you have any questions about this calculator simply post a comment and, I'll respond quickly.
Jan 13, 2011 | Sharp EL-2192Rll Calculator
I have a TA Adler-Royal 1123 PD nova printing calculator. (It is very old.) The numbers printed on the tape are very faint. Do I need a new ribbon or something else? Is there such a thing as an ink...
You need a new ribbon.
Older or much older desk top calculators used a small sized ribbon such as the old typewriters used except that the reels were about 1 inch across. Often they were divided into a red and black side.
It the calculator had all of the numbers strike the paper at the same instant, then it would use an
ribbon.
Here is a link to an Amazon.com page that sells the correct ribbon for your calculator.
http://www.amazon.com/s/ref=nb_sb_noss?url=search-alias%3Daps&field-keywords=1123+PD+&x=17&y=17
Here is a picture
Hope this helps,
Best Regards,
Mark
Dec 29, 2010 | Vacuums
Sharp EL-2192Rll Calculator Logo
59 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
