My JVC Compact component system is displaying upgrade disk what could be the problem?
When plugged in to the electric socket , the disc tray opens while it displays upgrade disk on the screen and nothing else functions.
  • 4234 Answers
SOURCE: Sharp BA2100 3 CD mini component system - NO DISC
This is a relatively common problem when the optics get dirty. If you can reach the lens, try cleaning it using a cotton swab and alcohol. Don't bother with the "cleaning discs" available as all they can do is bruch off the dust. These lenses sometimes get a smoke or dirt film on them that the brushes can not celan.
Keep us posted.
Dan
Posted on Sep 17, 2008
bijudada
  • 16 Answers
SOURCE: jvc mxdk3 radio displays upgrade
I have upgrade software. mail me (bijen486@hotmail.com)
Posted on Jun 21, 2009
  • 909 Answers
SOURCE: A power surge zapped my JVC MX-D661T compact
Open it up and check for internal fuses, if any in there, test with a wire, bulb and battery. The values (voltage and amperage) will be on the fuses or next to the fuse holders. Also look for any obvious burnt components like diodes( small bleck tripods) and capacitors(coloured "tubes" with a wire at each end) and resisters(like capacitors but with coloured stripes on). Obviously it will be cost dependent.
And most important UNPLUG BEFORE OPENING and be cautious as capacitors may be small but they can hold a very high voltage for a long time.
Posted on Aug 17, 2009
SOURCE: JVC STEREO DISPLAYS UPGRADE DISC
HOW CAN I GET JVC STEREO DISPLAYS UPGRADE DISC. PLS. HELP ME TO SLOVE MY JVC MX-DK3 PROBLEM
My email : damindabperera@yahoo.com THANK YOU
Posted on Feb 23, 2010
dunnbiker
  • 8546 Answers
SOURCE: My jvc compact component system
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Posted on Mar 21, 2011
Jvc stereo model mx-kc4 cd tray won't open make loud noise
sounds like theres something keeping it jammed in might be one of those pull hard and hope jobs :) good luck
Mar 24, 2012 | JVC MXKC4 360-Watt Compact Component Audio...
My JVC TH-G30 gives me a locked message when I try to open the load tray what should I do?
hello Setting the disc ejection lock
You can lock the disc tray to prevent the disc form
being ejected.
When the main unit is turned off, hold down the STOP
key at the front panel for 5 seconds
If you attempt to open the disc tray by pressing
OPEN/CLOSE key, the disc tray does not open and
“LOCKED” appears in the display window.
To cancel the disc ejection lock, hold down the STOP
key at the front panel for 5 seconds again when the
main unit is turned off.
“UNLOCKED” is displayed in the display window.
Note:
Before the main unit is turned off, DVD/CD function
should be selected.
Mar 29, 2010 | JVC TH-G30 Theater System
Need to set clock on jvc compact component stereo amp
How do I set the clock on my jvc compact disc audio system. model # KD-G110
Oct 21, 2009 | JVC MXKC4 360-Watt Compact Component Audio...
DVD player disc tray won't open
take a screw driver and open it up
maybe its a disc that stuck
if not working
probably cheaper to buy a new one
Apr 28, 2009 | Philips DVD793CH Multi-disc DVD Player
P-Error on JVC compact component system FS-GD7 when turned on
1. Unplug the JVC compact component power cord from the power outlet.
2. Unplug any connected devices.
3. Press and hold the JVC compact component power button for five seconds.
4. Plug the JVC compact component power cord back into the power outlet and turn on the JVC compact component
5. Open the menu to confirm that the JVC compact component is responding again.
6. Turn off the JVC compact componentand reconnect the devices.
7. Turn on the JVC compact component...
Jul 23, 2008 | Audio Players & Recorders
How to unlock the disc tray on my JVC compact component system MX-KB30
If your CD player dose not respond to normal commands, there is a problem with mechanism. Have serviced
May 10, 2008 | Audio Players & Recorders
JVC Compact Component System MX-D402T Problem
Hi ryv
The unit may need to be hard reset. Disconnect the unit at the wall and leave unplugged overnight and then try again in the morning, If this does not solve the condition, then it will need some repair work done to it by a JVC Auth service guy.
regards
Graeme
Apr 26, 2008 | Audio Players & Recorders
 Grubhead
Grubhead
