Question about Pool & Spa
I have a Hayward sp3400vsp 2 HP pump for my in ground pool.When I turn on the pump it tries to auto prime for about 5 minutes and then shuts off. The pump is less than one year old. Any susgestions?
  • 21 Answers
I have the same model pump. When I had it put in, the installer said that the auto prime function had some bugs in the software. He suggested changing the setting to 3 minute prime. You can change it in the configuration menu. I assume that your pump is actually priming and not running dry. Hope that helps. Please reply if you need more help. Good luck!
Posted on May 04, 2013
SOURCE: have hayward pool model 712 2 no idea how to start, prime, etc.
what I do isto take the top off the filter collectot just before the motor, insert your hose and fill the line from the strainer basket to the motor basket.let it runn for acouple of minutes.quikly take out hose and screw on basket cover,turn on motor and wait about one minute.you will see pool water start to volume to motor and filter.You will have to fix the shorting out of the motot first though.since I do not know how the unit is configured ,it's hard to say.
Posted on Apr 09, 2009
SOURCE: pool pump is very loud
loud pumps are most times caused by bad bearings and need to be replaced or better yet replace the whole pump new bearing cost about $100 to replace but not always easy to find someone to do hope this helps
Posted on May 13, 2009
  • 93 Answers
SOURCE: Hayward 1 hp super Pump just hums then shuts off.
turn shaft manually wiyh pliers if somthing is stuck in propeller this should clear it
Posted on Jun 07, 2009
  • 16 Answers
SOURCE: Jandy pool pump will not prime it is a Jandy plus HP model PHPM 2.0
make sure pool is full of water
check skimmer weir doors and make sure not stuck in up position
fill pump basket with water and try to prime
if that doesn't work
replace diffuser oring
http://www.jandy-downloads.com/pdfs/PHP_Manual.pdf
Posted on Jan 16, 2010
thepool
  • 78 Answers
SOURCE: Hayward Swimpro Sand filter shuts off after approx 2 minutes
It sounds like the pump is either overheating or the thermal protection switch that senses the overheating situation is defective. If nothing else changed like running on an extension cord, etc, a small motor repair shop can get you back up and running fairly inexpensively.
Posted on Apr 22, 2010
I have a Hayward sp3400vsp. The pump runs all night some times, the screen say is priming, it will shot off manually, and it wont do it all the time. help??
Sounds like the pump is sensing that there is a problem with water flow on the suction side.
Could be caused by air being sucked into the system. Do you notice air in the strainer chamber? Or bubbles coming from the inlets in the pool?
Could also be caused by something clogging or restricting the suction line.
May 31, 2014 | Hayward Industrial Products Hayward...
Have power to pump, but pump won't run
bad start up capacitor or motor replace whole pump
Apr 20, 2013 | Hayward Industrial Products Hayward...
I have a Hayward Power-Flo LX SP1515-Z2-EBK3 that is being used to pump water through 2-4x8 solar water heater panels. The pump intake is 1 1/2 inch, discharge out is also 1 1/2 inch. The pump is located...
I have a 3/4 hp hayward pumping thru solar panels, too. 1-1/2 discharge thru 50 ft of 2inch pipe, up 12 ft then thru (4) 4x12 panels. Mine is on 115 volts ac.
You have plenty of pump and when you run a pump with low flow, amperage is low. You are not tripping your breakers, it sounds like the pump is overheating. Is it hot to the touch when it shuts down?
Do you have an ammeter so you could check your amps?
What size wire is running the 60 ft to the pump?
I don't have any other ideas to share.
Gary
Sep 06, 2011 | Hayward Power Flo Lx
I HAVE A HAYWARD SUPER PUMP SELF PRIMING MODEL : C48L2N134B1 1 1/2 HP 115/230 VOLTS IT IS BROKEN AND I WANT TO KNOW WHAT MODEL I SHOULD BE BUYING TO REPLACE IT WITH. THE MODEL NUMBERS ARE DIFFERENT...
What is broken in your motor? Don't count it out until you have your pool place give it a check. If it is dead, get a 1 1/2 Hayward Super Pump just like the one you have.
Thanks for your interest in FixYa.com
Aug 11, 2010 | Hayward Super Pump 1 1/2 - Hp for In...
My Hayward Super II Pool Pump isn't priming. The
I think your impeller may be stuck OR your start capacitor has failed. Your pump is going off on over load because it cannot turn or cannot start.
May 14, 2010 | Hayward Pool Products Hayward Super II...
My Hayward Super II Pool Pump isn't priming. The motor will start, and hum for a few seconds but then it just shuts off. The motor will try again after a minute or two only to shut off again. The cycle...
Pull the six bolts on the back of the pump and pull the motor and pump housing back. remove the difuser and try spinning the impeller. If it wont spin you may need a new motor. If you pull the wires. You can find a motor shop in your phone book and they can rebuild it for you usually for about 100 bucks. Or replace it with new for a lot cheaper than what your talking. Good luck.
Mar 25, 2010 | Hayward Pool Products Hayward Super II...
Pump is leaking from the bottom what do I need to do to fix it? Only leaks when running, also looses prime when turned off.
The mechanical seal. We sell them for about $4 or you can get them locally. The superpump uses a 201 seal.
Jul 16, 2009 | Hayward Super Pump 1 1/2 - Hp for In...
Pool & Spa Logo
196 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
