Question about HP Computers & Internet
Laptop cd rom not working - HP Computers & Internet
Cd rom not working
cd rom will not play dvd
Jan 31, 2013 | Dell Vostro 1015 Laptop
Cd-rom in my daughter's laptop has stopped working. i have an identical laptop and swapped out the cd-rom drives but still does not work. I'm trying to download the drivers for the cd-rom drive but can't...
I believe we need drivers for CD ROM if both laptop are of same models. Can you plese insert the faulty CD ROM to your laptop and verify whether it is working or not. If yes, then you'll have take your daughter's laptop to service center. Could be a problem with mother board.
Please come back and give ratings to my solution if this turns to be helpful for you or also if you need more clarification.
Thnx
Mar 31, 2010 | Computers & Internet
My hp laptop cd rom is not detecting the cds. i want to formate my laptop.
Hi there, do not format now. Just try these.
Run the driver disk & install the CD/DVD driver. After finish the setup restart your pc or laptop. Hope that time your CD rom detecting the cds. But make sure, that your rom is working. Because if the cd rom is damaged then after formatting you can't install the operating system. May be your cd rom lens is damaged & that's why he can't read the cds or dvds. I suggest you Visit a service center & check the cd rom only. If you able to view the cd rom driver in side the my computer then, i am sure your vd rom lens is damaged.
Thanks & waiting for your feedback.
Feb 14, 2010 | HP Compaq nx6110 PC Laptop
I need help my cd rom on my dell laptop needs configured it is home vista
should i understand that your cd rom don't work? it's not important what operating system you have...if your cd rom don;t work...go on official site....and try to find FIRMWARE soft...if our system is xp or vista or 7 or linux... cd rom unit should work (no need to configured).you have another problem.
Oct 10, 2009 | Dell Inspiron 1545 Notebook
My laptop CD/DVD rom no working
how old your loptop because it possible cuase your life duration of your dvd/cd rom or it may cause of these issue try to test another kind of cd/dvd and the problem it the same maybe your optical lens in your cd/dvd rom dirty or damage try to clean it by using of insert the dvd/cd cleaner first your cd/dvd rom ok!...
Aug 21, 2009 | Computers & Internet
Cd rom not working
Its a Hardware problem . Your CD ROM trey or belt is damaged. another problem is your CD ROM Lens movement bar is broken or jam. plz check this. better You replace a new CD ROM , now Its price is very Low.
Thanks
Aug 14, 2009 | Acer Aspire 5920 AS5920 Notebook
Cannot open cd-rom drive!
The thing about cd/dvd drives in general is that they die and thats the case here even if you deleted anything of the operating system its self would notice that the cd drive was missing the driver and ask you about it since you havent stated that its safe to say that the drive is dead
Mar 13, 2009 | IBM ThinkPad T60 Notebook
CD-ROM has not worked.
It can use a DVD-Rom just make sure that the door is the same size as your old cd-rom so it will fit into the side of your laptop and also make sure that you remove the bracket from the back of the old cd-rom and reattach it to the back of the DVD-rom you want to put in your laptop so that way you can screw it into place
Feb 01, 2009 | Compaq Presario Notebook
Cd rom not working
Let’s determine if your CD-ROM drive or your Operating System Software ( ie...Windows XP) is the problem.
You will need a bootable CD, you can use your “Dell Resource” CD or any other bootable CD disk.
Power on the laptop and tap the F12 key to get to the “Boot Selection Menu”. Insert the DELL “Resource CD” into the CD-ROM drive. Select “Boot from CD/DVD drive” from the selection menu.
If the laptop boots from the CD drive then you Operating System Software is the problem.
If the laptop won’t boot from CD then your CD-ROM is defective and needs to be replaced.
Your responses are intended to improve the level of service provided. Please rate this solution.
Thank You.
Oct 18, 2008 | Dell Inspiron 1501 Notebook
My cd-rom drive is not working
look for the drivers for the cd rom of you laptop on the internet www.dell.com\support
May 29, 2008 | Dell Latitude D600 Notebook
Computers & Internet Logo
12 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
