Question about Konica Minolta Bizhub Pro C6500 Color Copier Color Printer
Minolta c6500 m1 drawer will not pull out
Jammed a couple of times and cleared ok, then jammed again and m1 would not pull out to clear.
  • 52 Answers
SOURCE: "Can't Detect Genuine Toner Cartridge"
minolta printers work on "chips" if the chip atached to the cartridge is not original minolta you better change it.
Posted on Jun 18, 2009
dmbgo
  • 58 Answers
SOURCE: In Konica Minolta 2430dk, I had a media jam in the
The only solution is to take the fuser unit out of the printer, then you may be able to manually rotate the rollers to clear the jam. If there are any marks or scratches on the fuser rollers, you will need to replace the fuser unit, or you will get marks on your prints
Posted on Jun 21, 2009
firecontrol7
  • 6680 Answers
SOURCE: what does code 2454 mean on the konica minolta
Developing motor for the Black, working in conjunction with Toner Control Sensor.
Posted on Jul 31, 2009
indus3
  • 212 Answers
SOURCE: Konica Minolta Magicolor5440DL Error Code
error 0094h = 2nd image transfer pressure/retraction failure
basically it means that either a sensor or cable is not fitted supposedly and reseating could possibly solve the issue.
you can research the error code in the following service manual:
http://printer.konicaminolta.com/drivers/other/Manuals/5400/smfs_54.pdf
Posted on Mar 09, 2010
  • 132 Answers
SOURCE: Konica Minolta bizhub 180 printer
Open all covers and clean again. Look for small piece of paper somewhere on paper path.
Posted on Nov 16, 2010
Tray won't close after clearing paper jam.
Yes have a tech come out and repair it that is very expensive machine mite want a professional working on it.
Feb 08, 2016 | Konica Minolta C6500 C5500 C6501 C6000...
Error code 5102 on konica minolta c253
According to the service manual, Code: C5102 Code C5102 Description Transport motor's failure to turn
• The motor lock signal remains HIGH for a predetermined continuous period of time while the motor remains stationary. Remedy 1 Check the M1 connector for proper connection and correct as necessary. 2 Check M1 for proper drive coupling and correct as necessary. 3 Check the PRCB connector for proper connection and correct as necessary. 4 M1 operation check. 5 Change M1. 6 Change PRCB.
The technical sites say that there is probably a paper jam. If the jam is cleared but the error persists, the transport motor will probably need to be replaced. This motor has a pretty high failure rate. A qualified copier technician should be able to change it out in 30-60 minutes.
Aug 30, 2015 | Konica Minolta Office Equipment & Supplies
M1 m2 m4 screen messaege
Utility button then stop 00 stop 01. Then use arrows to clear data screen then clear counters. Has the drum and developer been replace do that before clearing the counters
Jan 12, 2014 | Minolta bizhub 180 Black and White Copier
I am getting e020 error switch main off and on again and again
e020 error is of the main fuser unit u can solve it by press *28* then goto copier then function then clear and clear err dc-con err-hist jam-hist and pull both 1st and 2nd drawer now restart and when the screen is ok again restart then on main screen insert both drawers ur err will be removed -tushar sharma tushar@easy.com -9403343433
Mar 22, 2011 | Canon imageRUNNER 600 Printer
Cannot close the M1 part of Minolta Di 450
M1 is a counter for maintenance need to get service mode access to clear the counter and clear the message.
Dec 30, 2010 | Minolta DiALTA Di183 Copier
I have message call service(M1) So how to clear? When I press Utility and then stop, 0,0, stop, 0,1 , nothing hepened... Please,Please,Please help me to solve this problem!!!
firstly press menu then press quick setting then twoo time press left arrow then again press quick setting then press left aroow and after this press right arrow service mode will open at ur machine select "Maintenance Counter" now in this option select, 0 and press ok.
Jun 28, 2010 | Konica Minolta bizhub 161f All-In-One...
Minolta Di3510 indicates paper tray jam. I check the tray and open all jam clear areas but find nothing. Close everthing back up indicator goes away and when system starts to print again the machine...
Paper feed clutch is bad. I see this all the time. You can get the machine running by opening slightly the drawer that the machine is trying to feed from. Delete the current job and let the machine use the other drawer until you get it repaired.
The feed clutches in this series are small electromagnetic clutches and they do fail from time to time. Part# 9322-1500-12. Don't pay more than around $60 for the clutch. Here is a pic.
Good Luck and Thank You for using Fixya.
Apr 19, 2010 | Office Equipment & Supplies
Error code M1 appears and how to clear it . M2 is ok easy to clear.
How to clear an M1 code.
Solution:
To clear an M1 code, go to Counter/Maintenance/Maintenance Set and press the Clear key.
hope that help
Oct 21, 2008 | Office Equipment & Supplies
How do I get fix a "carriage jam"?
I was able to run run a piece of photo paper through a couple of times and printer now seems to be working again. The theory was that running a heavy piece of paper through might help clear little piece of paper that was not visible. The photo paper is less likely to tear if it gets jammed too.
Apr 18, 2008 | HP Photosmart C7180 All-In-One InkJet...
Konica Minolta Bizhub Pro C6500 Color Copier Color Printer Logo
59 people viewed this question
Top Konica Minolta Computers & Internet Experts
Lawrence Oravetz
David Payne
David Payne
Tom Chichester
Are you a Konica Minolta Computer and Internet Expert? Answer questions, earn points and help others
