Question about Bosch Exxcel WFX 145S Front Load Washer
Manual f18 comes up with
  • Bosch Expert
  • 414 Answers
F18 is time out on drain, check the pump filter for foreign objects (coins etc-behind flap, bottom right of front kickplate) and also check for blockages on outlet hose (especially if connected via spigot, directly to sink U bend)
Posted on May 04, 2013
Setting up a formula. I am comparing amounts for the last 3 years of raises and want to figure 5 different ones this year.Example of what I am trying to do. =(F6:F18*1.12%+F6:F18) Can this be done?
in excel ?
=sum(f6:f18)*0.012+sum(f6:f18)
if each row has to be individually * 0.012 add a column and put in this column each row cell * 0.012. example new column G then g6=f6+f6*0.012
a screen print of what you are trying to do would give a clearer indication of exactly what you want to achieve ?
Mar 26, 2017 | The Computers & Internet
My miele dishwasher keeps taking water as soon as I close front door (even when program has not been started yet) after while it displays F18 fault and starts draining
Find out what the error code F18 represents. Owner's manual troubleshooting section is a good place to look or search for it on the internet.
Mar 07, 2016 | Miele Dishwashers
How to fix f18 fault
The f18 code that pops up in these models is related to the "contra-rotating" mode unique to this line. This mode is very tough on the gears and drum and they end up binding. The only "real" fix is a new drum assembly, which dyson has run out of for service parts. You can run the washer without using the contra-rotate mode and the unit will not act up. Other than replacing a no longer available part, some owners have found that by washing some oil-soaked articles (such as shop rags or towels drenched in motor oil), the offending parts binding issue can be lubricated away for quite some time. When the f18 error returns, they just wash some more oil into the problem area to make it disappear again.
Check out the facebook page for more info than you will need.
93867830652471/">Facebook logo facebook.com/groups/293867830652471/
Jan 04, 2015 | Dyson Washing Machines
Car won't start after cutting off?
that is a fuse for the power train control module. so the mudule is failing.
Dec 28, 2013 | 2003 Jaguar X-Type
F18 fuse keep on short circuiting
find what fuse 18 runs and check it for a dead short. If it is a fuel pump fuse check the fuel pump for seized or dead short.
Dec 28, 2013 | 2002 Jaguar X-Type
Error code F18
F18 error code means that the filter is blocked.
Look around for a propeller shaped part, it should be able to spin freely. If not, remove the debris so that it is unblocked.
Hope this helps (remember to rate and comment this answer).
May 14, 2011 | Bosch Axxis+ WFR 2460 Front Load Washer
Error message F18 what does that mean? i lost the manual... michael
F18 (usually!) means there's some issue with drainage. If the washer doesn't drain properly within a specific amount of time, you'll get the F18 error. A common fix is to remove the panel covering your drain and examine it for any sort of debris that may be obstructing it - plastic, lint, loose change, etc.
Mar 05, 2011 | Washing Machines
My washing maschine says F18. What does that mean?
If you let me know the Make of the machine, I can tell you exactly what F18 code is and what needs to be done to repair it.
Dec 31, 2010 | Washing Machines
Error code f18 WMF940P Washing machine has an two occasions come up with message F18 but when un-plugged and restarted the machine works, it has done this twice in 3 months and hotpoint tell me that if...
hello, this is a communication error between the main brain board of the machine inside at the bottom and the control board where you push the buttons to operate the machine. most likely a broken wire between the 2 need to do an electricl continuity test between these boards on the blue cables that connect them
Jul 20, 2010 | Hotpoint Washing Machines
Bosch Exxcel WFX 145S Front Load Washer Logo
112 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
