Aqualtis AQM8D 49U f5 - Washing Machines
How can I replace the lower counterweight?
You may bave to take the top off and then the rear panel depnding on what model you have. O be;ieve the front does not come off?
GOOD LUCK
Jun 15, 2015 | Washing Machines
Lavadora secadora ariston aqualtis aqm8d error f13
F13: NTC wiring harness disconnected from the dryer system
1. Check the efficiency of the terminals on the CNA connector board
2. Check NTC wiring harness
3. Check the wiring harness continuity of the CNA / NTC connectors
4. Replace NTC
5. Replace terminal board
Dado
Apr 08, 2014 | Ariston Technologies AWD 129 NA Washer/...
Ariston aqualtis aqlf9d
PLEASE URGENT!! I have the same washing machine WMW-5812.ER when i press the power on it does not start up why? Please help children getting back to school this week....pleaseee....
Jan 04, 2014 | Washing Machines
I have a hotpoint aqualtis aqxgf 149 pm washing machine and it keeps flashing up with f-o5
Pressure Switch jammed on full
Possible pump block, check pump etc. for blockage
Check pressure switch, wiring and module connections
Also in the first instance check the drain pump filter for any blockage or, if there isn't a drain pump filter fitted the pump will need to be removed and inspected for any blockages. If you have any further questions message me back. Please also remember when our chat has fully concluded to rank how this opinion has helped in your appliance situation it allows me to continue helping others in similar situations in the future Thanks Rick
Aug 09, 2011 | Washing Machines
I HAVE IBM 8305-49U. Can this machine support IDE to SATA
IBM Netvista 8305-49U supports ATA-100 Enhanced Local Bus IDE controller. Sata is not supported. However, IDE to Sata converter can be used.
CreativeTECH
Jan 18, 2011 | IBM Computers & Internet
Hotpoint Aqualtis - F5 was flashing on screen and all the icons ? Can you identify problem as I dont have a manual
Draining blockage. Lift the machine, you'll find a black tube under it. Carefully remove the tube, remove any garment that may have blocked it, clean the white ball thoroughly and pay attention to put it back exactly where it was. Put the parts back where they belong and try again. Good luck!
Jan 13, 2011 | Washing Machines
Says F5 on display, wont empty.
just had F5 blockage warning on hotpoint aqualtis. Removed front panel on the bottom and unscrewed filter, cleaned and replaced. checked all outlet pipe was clear. Laid washing machine on to its back and removed black pipe from pump and checked and finally removed the other end of the pipe that joins to the drum. large ball acts a valve and a missing sock was found in the drum end! replaced all parts and washing machine works a treat! before the f5 warning the machine leaked from the door on a couple of occasions, no problem since and may have been a build up of water finding its only way out.
Jul 12, 2010 | Hotpoint Washing Machines
Hotpoint aqualtis giving H20 error, looks like fill problem, but cannot see anything stopping the water flowing into the machine.
i have hotpoint aqualtis, it washes & empties but then starts flashing when ready to rinse. any suggestions?
Dec 04, 2009 | Washing Machines
Trouble shooting the hotpoint aqualtis aqxxf149pi flashing f08
my hotpint aqualtis aqxxf149pi make a funny grinding noise when it spins help please?
Jun 25, 2009 | Hotpoint Washing Machines
Aqualtis AQGD 169 S F12 problem Please help :-(
ok, I have just had the 'blocked pump message and after much playing around I have solved it.
Pull the machine out and take the drain out and place in a bucket. Then tilt the machine on its side about 30 to 45 degrees so you can get a hand underneath. At the front there is a black rubber pipe-squeeze this a few times and then run the machine on a pump cycle. Put water in machine (i used a bucket) and repeat. You should get the foul smelling gunk out of the pump. I did this about 4 times and finally the water comes out clean and you should be ok.
Regards and good luck,
Matt
Jul 01, 2008 | Hotpoint Aquarius WD640 Front Load...
Washing Machines Logo
150 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
