Question about Hasbro Playskool Weebles Musical Treehouse
Parts the belt that carries the weebles up to the slide does not work
    Problem Solver:
  • 11 Answers
I think you just have to remove it for the safety of the child
Posted on Nov 08, 2013
Mr christmas gold label tornado rollercoaster 2003 belt i broken cars will not work
MrChristmas.com website does NOT carry replacement parts or advise on how you can get parts or repair. For a few items they have replacement bulbs and ac adapters, but NO BELTS. "Sunset America Corp / Suntronics Components Corp" on FaceBook has some parts, but do no yet carry the special notched belts that move the cars up the ramp. Looks like they are working on possibly making some in the future.
Sep 17, 2015 | Coffee Makers & Espresso Machines
Front end wobble
weebles wobble but they dont fall down ...... ( you didn't give enough details if you want help with a problem )
Oct 19, 2013 | Kenmore Vacuums
Machine won't spin.
Sounds like the belt needs replace. You can order parts threw Sears or probably Lowes. Its a relatively simple job. 30-60 minute job. Sears carries appliance parts of all sorts. You'll be amazed at what you can find at Sears. You'll have to ask in appliances. But they do carry appliance parts . Remove housing cover and get a better look at the inside. You'll see that it's probably your belt has popped or your motor is gone out. If it's your motor, your probably in for a long job. Either way, there is many stores that carry appliance parts. Just take the modal number down and the make of the washer, and you can pretty much go by that.
Apr 24, 2011 | Whirlpool LSR5132PQ Top Load Washer
I would like to know what inspections/maintenence should be performed on drill presses, say monthly and than yearly. I want my machine to stay in tip top shape.
Depending on how much the Drill Press is used will determine the maintenance required.
For light to moderate usage a monthly clean and lubrication of turning / sliding parts with a general inspection of drive belts and pulleys will be sufficient. Heavier usage will require more frequent cleaning, lubrication and inspection.
Yearly maintenance will be the same as the monthly check with possible replacement of the drive belt if showing signs of wear or deterioration such as cracking and checking bearings of drive motor for signs of wear or noisy operation. If possible, an electrical safety check should also be carried out at this time by a suitably qualified person.
Feb 16, 2011 | Craftsman 12" Drill Press (21914)
Vcr and tv does not work due belt broke. I tried to find part for that.
Have you tried the vcr/tv repair shops, they usually carry a lot of different sizes of belts. Radio Shack might be a possibility, liquidation stores.
Dec 31, 2010 | Zenith Televison & Video
I have a problem a model of creative design Weeble Labis, inc.model no.VFO220 and lost the driver cd .... you can help me to install?
Try downloadng from the Creative website
http://support.creative.com/Products/Products.aspx?catid=218
Nov 20, 2009 | Creative Labs WebCam Live!
Belt drive
do you mean a drive belt? like a serpintine belt? first find the belt tensioner, use a socket that will fit on the bolt. attach a breaker bar to socket. lift tensioner up, when belt loosens slide belt off of one pulley. slowly release tensioner. remove belt. now is the tricky part. install new belt leaving that last pulley for last. use breaker bar again to lift tensioner, slide belt onto last pulley. slowly release tensioner. check all pulleys to make sure belt is on properly. when ready start engine to see if belt will work properly.
Oct 08, 2009 | Cars & Trucks
How to fit carry cot to car
I assume you are referring to the Matrix Pro Car Seat that lays flat? You can fit this in two different ways. To fit it sitting upright, make sure it is in the most upright position and facing the back of the car. Pass the lap belt underneath the car seat itself, through the blue catches, then plug it in. The long part of the seat belt goes around the back of the car seat through the blue catch nearest you. Pull it all really tight and it should be more secure. To fit the car seat laying flat, this depends on your car. It needs to use two 3 point seat belts. 2 point seat belts don't work. Plug in both seat belts, and pull the lap belt part through the silver catch on both side. Pull as tight as you can. To make car seat fitting more secure, try placing a slip mat like the Sunshine Kids Grip It or Super Mat underneath to hold it in place. These are all crash tested and safe.
Sep 12, 2009 | Baby Gear
Water runs down window into doors ,1995 olds ceria,can't locate replace parts,called window sweeps,belt mouldings,,window sliders
Yes you have a tough issue to resolve. If you have access to a local auto salvage yard you could look there for chevy celebrity, buick century, as they were build on the same body style so any of those models would have the same belt moulding. Also E-bay or craigs list are great places to locate parts. I do not know if GM service parts would carry these parts any more as they only have to carry them for 7 model years after the last vehicle run. Good luck.
May 10, 2009 | 1995 Oldsmobile Cutlass Ciera
Hasbro Playskool Weebles Musical Treehouse Logo
47 people viewed this question
Top Hasbro Toys Experts
thegtw
Antony
Are you a Hasbro Toy Expert? Answer questions, earn points and help others
