Question about Perko Battery Selector Switches Ignition Protectedtype Standard
Do you have to disconnect the battery if you have a battery cutoff switch?
    Sergeant:
  • 415 Answers
A cutoff switch will disconnect loads that are connected to the battery. A battery selector switch can switch your load from one battery to the other , combine batteries together or disconnect all loads entirely.
When in the off position, the switch cuts off all power from the battery to any loads connected down stream from the switch.
Sometimes float switches and other devices are connected directly to the battery. Therefore the battery selector switch will not disconnect this load when switched to the off position.
Posted on Dec 16, 2013
My 2002 Nissan Xterra was flipped on its top,wasn't upside down very long and I'm thinking it should run.Is there an emergency fuel shutoff switch or a reset you have to do before it will restart
Most Vehicles DO NOT HAVE An Emergency fuel cutoff Switch . This was something ford did in the early 90s but now the computers can communicate and disable the fuel pump if necessary. Try disconnecting the battery for about 30 minutes or so. If it still won't start try listening for the fuel pump....it should run for a fee seconds when the key is turned on
Aug 14, 2016 | Nissan Cars & Trucks
How to program the ac
It sounds like you have either a low pressure cutoff switch that is faulty or connection at the switch/wiring. The computer will only see the fault while it is operating and it will only set the code after 2 consective faults. Make sure you have the system checked by a professional to make sure pressures are correct in the system first.
Sep 25, 2014 | 1999 Cadillac DeVille
Location of fuel pump cutoff switch for ford f250
Some models are behind plastic kick panel at passenger side area beside right leg..panel pops out if no screws are visible.others I have seen under hood at driver side firewall area behind master cylinder.It should have an identification sticker on or around switch..some have red button on switch.disconnect battery before removal if replacing.or troubleshooting.
May 13, 2014 | 2004 Ford F250
WHERE IS THE FUEL CUTOFF SWITCH ON THE 2007 HYUNDAI SONATA
No cutoff switch on Hyundai cars. Only Ford products.
The fuel pump and injectors get power from the engine control relay.
Feb 19, 2013 | 2007 Hyundai Sonata Limited Sedan
94 mercury grand marquis LS wont start. Turns over. Replaced relay, checked fuses, replaced fuel pump ( tho didnt need to- wired it to car battery and it does seem to work.) Will run with priming (starter...
Hello, There is a fuel cutoff switch in the drivers side of the trunk. It is referred to as the Inertia sensor. It will detect an impact and disconnect the power to the fuelpump.
If you look at the drivers side of the carpeted trunk there will be a slot in the carpet or a hole. All you need to do is push on the switch button and the system will reset. If you have air ride the Inertia switch is next to it.
Aug 03, 2011 | 1994 Mercury Grand Marquis
Pulled out the dash fuse to get the draw out of the battery, i have no dash gauges.what could be the problem
Replace the dash fuse. If the draw on the battery is a big deal, invest in a cutoff switch so that the battery is not being used when you don't want it to be.
http://www.amazon.com/BATTERY-CUTOFF-SWITCH-BOAT-RACECAR/dp/B001HSBW74
Your local auto parts store may or may not stock them.
May 29, 2011 | 1997 Jeep Grand Cherokee
I reset the fuel cutoff switch in a 91 ford escort and it still won't start so I disconnected the battery for 15 minutes and it still won't start. What else can I try and would a bad switch or fuel relay...
yes a bad fuel cut off switch could be the problem, it just has 2 wires all you have to do is jump them together if the switch is bad and the fuel pump will run. I think you should take a look at the timing belt more then likely that is the problem.
Nov 14, 2010 | 1991 Ford Escort
Keeps cutting off after restart
SINCE CAR WONT CRANK. NOW IS THE TIME TO REPLACE THE IGNITION SWITCH KEY LOCK CYLINDER ITS BROKEN THAT WHY THE CAR KEYS WOULDNT TURN OFF CAR.DISCONNECTING BATTERY CABLES WITH CAR RUNNIMG WILL.SHORT OUT ALTERNATOR AND PCM.IF IN CASE YOU HAD TO REMOVE BATTERY CABLE REMOVE THE GROUND NEGATIVE CABLE FIRST.MAKE SURE ALL ELECTRICAL COMPONENTS OFF LIKE RADIO. AC SYSTEM OFF.THIS WILL PREVENT LARGE ELECTRICAL ARC FROM BATTERY THIS IS ONE TIME PROCEDURE IN CASE ENGINE WONT SHUT OFF ITS A GAMBLE BECAUSE IT WILL TAKE OUT ALTERNATOR AND PCM.REPLACE THE SWITCH AND KEY LOCK CYLINDER DONT KEEP STARTING CAR BY DISCONNECTING THE BATTERY CABLE YOU WILL DAMAGE IGNITION ELECTRICAL SYSTEM.
Jul 31, 2010 | 1997 Oldsmobile Achieva
Car won't shut off
check the ignition switch for a short,get back to me if you need more help,please rate my fix as i strive to be the best. also check the rod that connects the key switch to the ignition swtich, could be stuck or out of adjustment, just another thought Thanks Ray
Apr 05, 2009 | 1992 Ford Escort 4 Door
Battery Cutoff Switch
Best source for reliable battery cut-off switches I know of would be any speed shop that deals with drag race cars. Most "doorslammer" race cars, (bracket cars through pro-stock) are required to have these switches mounted on the outside of trunk lid... Of course, you can mount them inside the trunk, or anywhere else you wish!
Dec 27, 2008 | 2003 BMW 325
Perko Battery Selector Switches Ignition Protectedtype Standard Logo
62 people viewed this question
Top Perko Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Perko Boating Expert? Answer questions, earn points and help others
