Question about Makita 6349DWDE 18V 1/2" MXT Driver - Drill Kit
Power to brushes roter not turning - Makita 6349DWDE 18V 1/2" MXT Driver - Drill Kit
Had bed off got all the wireing crossed got to completely wire can you tell me how
Remove No 1 spark plug turn engine till compression felt. align mark on crankshaft pully with mark on timing cover , distributer roter now points to No 1 on cap. Firing order 6 cyl 153624 4 Cyl 1342. check which roter turns and connect cables as above
Jul 20, 2014 | Cars & Trucks
I feel a vibrating/pulsating feel in the whole truck when the brakes are applied. I have changed the front wheel bearings, rotors, brakes and calipers. Also had the rear calipers checked which were still...
Rear disk need turning, did you turn new roters when you replace them on the front I always did and found most new roters are not true. If it isn't a roter problem check front end parts for looseness such as idler arm
Mar 22, 2011 | Dodge Ram 1500 Cars & Trucks
After battery went dead my car won't start, it is turning and all my lights are working but there are no spark
You might want to look into checking the cam sensor and the distributor, dist cap, and roter. Make sure the cap has the contacts and it is not damaged. Make sure the roter spins while you are cranking the vehicle. Check your sensor and make sure it has power.
Feb 27, 2011 | Audi A6 Cars & Trucks
I have a 1995 nissan altima i have no spark in the spark plugs but have power running to the harnest that connects to the distributor.is the distributor messed up
The distributor has what is called a pick up coil which maybe unserviceable or the roter or roter cap may be fouled up or damaged...Hope this helps you out.
Oct 12, 2010 | 1995 Nissan Altima
Durango won't start. turns over fast and tries to
Thats what mine is doing right now.
This sucks alot but here are steps to take.
1. Check fuel pressure to make sure its not the fuel pump
Should have a valve on the fuel line to press make sure gas comes out when the key is in the ignition in the on position
if there is gas then...
2. check to see if you have spark coming out of your coil.
if there is replace distributor cap and roter, should not be more than 20 bucks, then try the ignition module (60sih dollars) then Crank sensor if its a 99 5.9 Liter
After that i am unsure those are the things that usually go wrong, it could also be the spark plug cables, if it just stopped working like mine did randomly i would check the distributor cap and roter then the sensors first though. Cause the chances of 8 sparkplug cables going out at once are slim
Also make sure the roter inside the distributor is turning.
As if its not turning that is the issue,...
Nov 16, 2009 | 1999 Dodge Durango
Heat is not working. A little roter fell off and I
Need new or good used heater box. Lots of labour to replace sorry!!!
Nov 03, 2009 | 2003 Ford Explorer
I INSTALLED A NEW BELT BUT THE ROTER BRUSH IS STILL NOT TURNING
It's possible that when you replaced the belt, you may have pinch it against part of the vacuum. Or, you may have put the brush in crooked.
Jim
Jun 08, 2009 | Kenmore Vacuums
1999 Dodge Ram 1500 Extended Cab 4x4
idle air control motor on back of throttle body maybe malfunctioning and not allowing it to idle
Oct 21, 2008 | 1998 Dodge Ram 1500 4WD
North Star 5500/ lost one leg of the 220v
Small generators like this almost always have 2 stator windings 180 degrees out pf phase, that's how it makes the 220.
At the back (maybe side) of the outlet box should be a molex type plug that has the wires from the stator, get an ohm meter and measure them (with the generator shut off of course). You should find that you've got 4 wires in the plug, 1 wire for each end of 2 coils. From one end to the other of each coil you should measure less than an ohm, between the coils there is usually no connection, but some models have the neutral ends of each coil connected together inside the generator housing.
It sounds to me like you've got one of the power windings open...
Carl
Oct 13, 2008 | Northstar Generator 9 Hp, 5500 Watt,...
Makita 6349DWDE 18V 1/2" MXT Driver - Drill Kit Logo
Top Makita Drills Experts
John Trevino
Are you a Makita Drill Expert? Answer questions, earn points and help others
