Question about Oregon Scientific Bar338pa Exactset Projection Clock With Cable-free
Projection issues Only about half the segments show on the projector for the time and temperature. Is there anyway to fix this?
This projector is projecting a red color throughout. What should I do to correct the color? It has been turned off for about an hour. Please advise. Thank you.
The EX240U uses a DLP imaging chip and a rapidly spinning six-segment color wheel (red, blue, green, white, yellow and cyan) to form the image. It is likely that the spinning color wheel has stopped with the red filter in front of the chip. I recommend opening the projector and see if you can coax the wheel to move and maybe it will spin once again. if not, it may be the wheel motor or the circuitry that affects the timing of the spin - either way, it will take a trip to the repair shop to fix.
Hope that helps.
Mar 05, 2015 | Mitsubishi EX240U Projector
Kodak carousel 760h projector
The problem you described is a timing issue with the Slide Change Mechanism. The timing changes (most often) due to wear. Because most Carousel 760H's are about 40 years old, this is the most likely cause. You should enlist the help of a trained technician to make this adjustment on your behalf.
Dec 24, 2013 | Office Equipment & Supplies
LC-XG200 bulbs where can I get one in the UK? At the moment my image looks blurred is that caused by the lamp or is some other issue?
In the first instance:
Adjust focus of the projector.
Make sure a projection screen is at least 4.1' (1.2m) from the projector.
Check Projection Lens to see if it needs cleaning.
NOTE : Moving a projector from a cool temperature location to a warm temperature location
may result in moisture condensation on Projection Lens. In such an event, leave a
projector OFF and wait until condensation disappears.
Apr 03, 2011 | Eiki LC XG200 Multimedia Projector
I saw an answer up above regarding the green hue on the projector, is there anyway to remedy this problem? This is really annoying to me and I would like to fix the issue. Thanks,
Three LCD block in the Panasonic projector PT-L735 green,blue and red and two polarizer use with each LCD (as show in picture below) when polarizers faded due to age or any other reason then screen show the color. In your cause the green polarizers faded and need to be replaced good_help_9.png
Jan 08, 2011 | Panasonic PT L735U Multimedia Projector
Sharp XG-P25X Projector
Hi Garrett Use this sequence initially.Try turning the projector and source machine off. Turn source machine on. Turn projector on. I can not recall without checking the manual but look for the menu where you can set the source resolution. Some projectors allow quite comprehensive selection and others very limited to zero choice.
This is not a lamp issue, but the digital signal processing.
Typically the Pixel Map processor is not processing the pixel coming in to be mapped to the correct pixel on the display block.
If a digital problem in could either be a circuit malfunction or software (IC rom issue) which really you will need to take to a local authorised service shop.
Re your XG-PG25X We are able to supply replacement lamp delivered next time you need one, as we ship internationally and also the same with our revolutionary ICE Digital Daytime projection screens. Cost $US339. includes freight. Excludes any local taxes.
http://www.youtube.com/watch?v=HvZ2DlVJ790 http://www.youtube.com/watch?v=qL_44xfK9y8 Regards Kevin Andreassend ICE AV Technology Ltd New Zealand http://www.digitaldaytime.com iceavtech@gmail.com +64-9-414 2348
Dec 05, 2008 | Sharp Conference Series XG-P25X Multimedia...
Left half image has greenish tint, other half fine XV Z9000U
I am having the same issue, did you ever get yours fixed and if so how please?
Shannon
Nov 25, 2008 | SharpVision XV-Z9000U Multimedia Projector
Unresponsive projecter
You need to replace the logic board.
Aug 05, 2008 | HP VP6310 Multimedia Projector
Toshiba TL-S30 projector, project one half of screen colored blue, one half clear
Is it a problem...or a setting in the projector asking u to check the color settings?
Try the manual fully... Also try the monitor with some analog input (other than PC)
Try to tell me.... whether my suggestion was useful???
Bye
Have a nice day.
Jan 07, 2008 | Sanyo PLV-WF10 Multimedia Projector
A terrible sound
It's the lamp. The same exact thing happened to me, my projector started making a loud whinning noise and the picture quality got really dim. At first i thought it was the fan too but after alittle online research i found out that that when the lamp bulb shatters it does this, so i went a got a replacement and it fixed all the problems. :)
Dec 10, 2007 | Optoma MovieTime DV10 Multimedia Projector
Oregon Scientific Bar338pa Exactset Projection Clock With Cable-free Logo
312 people viewed this question
Top Oregon Scientific Measuring Tools & Sensors Experts
Lawrence Oravetz
Timllfixit
Are you an Oregon Scientific Measuring Tool and Sensor Expert? Answer questions, earn points and help others
