Question about Saws
Problems with makita hr2230 drill
Power up to brushes but will not run
SOURCE: makita 6222D hole drill bit is stuck
When this happened to me I held the shaft of the drill bit tightly with my hand and reversed the direction of drive for an instant. It released at that point. It still does that occassionally though.
Posted on Feb 22, 2008
SOURCE: Makita drill 6349D
dont think its http://www.toolbarn.com/product/makita/6349DWDE/
Posted on Oct 05, 2008
meleemore
  • 19 Answers
SOURCE: Makita Percussion Drill HP2051F keyless chuck release problem
jacobs come out with this all metal keyless chuck(i think thats what you have) and if thats the case, there is no solution for this youll have to replace the hole chuck, being its new, it may be under warrenty
Posted on May 05, 2009
SOURCE: Why doesn't my HP 1501 Makita hammer drill work
The problem was the cord at the base of the drill. The wires were broken, cause by constant bending. After souldering the wires, the drill works perfectly.
Thanks.
Posted on Jul 29, 2009
dmftrucker
  • 1922 Answers
SOURCE: My makita drill is weak/ has no power.
did you check the battery under a load condition?as in check the voltage under drill operation,most batteries will check their normal top charge voltage when not being used,this is known as a surface charge,but under load the voltage may severly drop leading to burned or overheated armatures,have it load tested
Posted on Jan 02, 2010
Makita 6227dwe cordless drill can the brushes be replaced.
No, unfortunately this is brushes only come as part of the motor assembly Makita 6226DWE 3 8 Cordless Driver Drill Parts
Dec 24, 2016 | Makita Drills
Makita hr3851 won't hammer or drill
Try pulling out the brushes and blow some air in were the brushes go it may have gotten some trash in between the brush and the armature . they may need to be replaced, here is a pleace that will give you a breakdown and sell you the parts. http://www.ereplacementparts.com/makita-hr3851-rotary-hammer-parts-c-97_380_491.html
Jul 30, 2016 | Makita Drills
Makita troubleshooting
The BDF452HW has a carbon brush motor - and they do eat up brushes quickly. The brush set number is CB440 - they are replaceable by removing the 2 screws on the rear cap, the connectors snap over the brush holder - take care not to bend the brush holders when changing, they are just thin brass.
If the tool is 'ticking' or 'grinding' when it spins check the condition of the armature before you install new brushes - the copper commutator should not look burnt or have raised segments - this is also a common repair on this tool. Replacing the armature is a fairly inexpensive and easy fix - you must split the entire clamshell housing to access this - be sure to fit all the components securely back into their slots or you may tear all the fan blades off the armature when you try and run it.
Jul 27, 2014 | Makita BDF452HW 18V Cordless Lxt Lithium...
Makita BHP452ZW light works but no drill power
Your most likely problem is the switch (PN 650583-6). When they go bad they will let power go to the LED light but it won't get to the motor. With a multi-meter, check the power going into the switch and coming out to the motor. If 18 volts are getting through to the motor then you may have armature (PN 619198-8) issues.
Nov 26, 2013 | Makita BDF452HW 18V Cordless Lxt Lithium...
Power drill got wet, won't run
Pull the motor brushes out and clean them up also take points file to the brush holders if it has them to clean them up. Not sure which model tool you have so I just gave an educated guess.
Mar 25, 2012 | Makita Drills
How to diagnose makita 18v impact losing power. Already replaced battery
If the battery didn't take care of the problem check the brushes next. Take the two screws out of the back cover and check both brushes (Part Number 194427-5). They should be at least 1/4" long and evenly worn, if not replace them. If they're excessively burnt or chipped and broken, check the armature before replacing them. If the commutator is damaged it will only shorten the life of the new brushes.
Nov 04, 2010 | Makita 18V LXT Lithium - Ion Cordless...
My makita hmo860c breaker drill has stopped working power light is on ?
I purchase a rotory hammer on ebay and it was listed as a makita, i was trying to get a spare part for it from makita. I gave them the information that is printed on a lable on the side of the drill, 66015c, 850W 110V,26mm and to my suprise they told me that it was not one of their drills, I have a few of these drills still being sold on ebay as makita. is there anyway that anyone can help me with this query.
Aug 30, 2009 | Makita Hammering
Makita cordless dril Model # 6213D 12volt.
I used to pull these drills to bits for a living and all i can say is that if the brushes are intact and not too worn then it should run fine without cleaning the brushes. chances are that the motor has worn out.
Sep 13, 2008 | Makita 3/8" Dr. 14.4V Cordless Drill Kit
Saws Logo
37 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
