Question about Miele W526 Front Load Washer
Novotronic Red light comes on 'excess detergent'?
2 Suggested Answers
  • 53 Answers
SOURCE: Miele novotronic premier 500 washing machine
put less detergent in
Posted on May 02, 2008
Miele 500 washing machine inlet light comes on and machine wont pump water out or spin
try leaning against door when pressing start . if it runs get the switch replaced
Jan 24, 2016 | Miele Novotronic Premier 500 Front Load...
Excess detergent light comes on for every wash
Hi. I have had the same problem. I've taken off the top (2 screws on the sides of the top, under little caps) & I noticed that a sound deadening felt pad had come unstuck from the back of the machine and was being chewed up by the belt - this could be stopping the spin & causing imbalance, hence the excess detergent light coming on. I removed the pad completely and tested it. It now spins beautifully! However the detergent light still came on so I removed the soap dispenser unit completely (not the tray, the entire assembly which lets the water in and mixes the soap powder) and all the adjoining pipes which were completely blocked. I couldn't get the long one off going right down to the bottom but I squeezed it in an upwards motion like milking a cow (!) and got loads of grunge out. Hopefully that's fixed it.
Aug 08, 2012 | Washing Machines
How do i open the filter door for a miele novotronic w526 washing machine?
There should be a plastic tool on the inside of the detergent drawer. It's a flat spatular type tool (mine is bright yellow). Then there is a spot on the little door where the tool fits in and you can use it to gently lever the door open.
Mar 11, 2012 | Miele Novotronic Premier 500 Front Load...
The check drain light on my Miele Novotronic W844 washing machine is flashing; I have drained water out from the drain pump/filter section behind the panel at the front then refilled water in the detergent...
Hi dear.Related to your explenation: It does have faulty pump but first checked the pump harness.That's important.If every thing seems OK then you can replace the pump.I hope that helps.Thanks.
Feb 13, 2011 | Washing Machines
Washer not draining and light flashes SUD
Try these steps if anything needs to be replaced or still not fixed the problem you need a qualified service technician to come out to your home hope this helps and good luck. SUD SUDS LOCK (Overdose of detergent detected during the wash cycle) The motor control unit senses a suds lock condition by analyzing the current draw on the drive motor. If "Sud" is displayed a potential suds lock is detected. This may signify a bad pump, an extra heavy load, excessive detergent, or excessive suds.
Potential Causes
• If too much detergent was used, run the unit through a Rinse/ Spin cycle then a Normal cycle without adding any detergent. This should clear the unit of the excess detergent.
• Check the drain hose and make sure it is not plugged or kinked
• Check Wire Harness connections to the Drain Pump, Pressure Switch, and Central Control Unit (CCU)
• Check / Clean Drain Pump Filter of foreign objects
• Check Drain Pump
• Check the Pressure Switch
• Check CCU
Replace failed component
Jan 06, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My miele machine tends to bleach my clothes.
I would run a few cycles with just water added to the bleach dispenser, clean it out, and see if that helps.
Nov 06, 2009 | Miele Novotronic Premier 500 Front Load...
Miele washer-dryer
you have activated the float switch in the base of the unit due to a water leak. this could be just excess detergent or an actual leak. if you tip the unit forward with some towels in front this will drain out the water. try running again with no detergent. if it doesn't show WPS after a couple of washes then you are ok. then change your detergent.
May 31, 2008 | Miele Novotronic Premier 500 Front Load...
Water not getting into washing machine miele novotronic w830
Thank you for advice! My Miele Novotronic W830 is 17y old, been working well, until yesterday. When taking water, much started spilling on floor under the left lower corner of the machine.
I opened the cover, found a loose hose under the detergent tray, did set it back in place and tightened the band.
First you better loosen the band, it slips more easily on the funnel.
In my photos you can see the screw is pointing to wrong direction to be able to use a screwdriver, but I did manage it with bare hands.
Be sure there is no power connected when opening the cover!
And don't drop anything inside, when opened the cover, it is a nasty place to get it back...8_26_2012_3_23_27_pm.jpg8_26_2012_3_24_22_pm.jpg8_26_2012_3_24_47_pm.jpg
May 10, 2008 | Washing Machines
Miele W526 Front Load Washer Logo
24 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
