New printer driver and HP Pavilion Entertainment laptop
Laptop won't recognize printer C5550 driver so that I can print
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Office Equip... Master
  • 102,366 Answers
varsitythoo
SOURCE: My HP LaserJet 6L Won't Print on new HP/Vista PC
Use any printer parallel 25pin convertor to USB cable and connect it to pc or notebook
Connect both ends from pc to 6L printer
Go to website to choose the correct O/S driver for installation
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=14974&lang=en&cc=us&taskId=135&prodClassId=-1&prodTypeId=18972&prodSeriesId=25476
Use virtual USB port005 for printer 6L
Bi-directional option can be ticked
Click apply and ok
Unplug and replug the USB cable
Try printing a test page,
I have tried it, the vista download drivers works on vista, no problems in printing at all, advise from http://www.bebo.com/andythoo
Posted on Nov 21, 2008
  • 2072 Answers
SOURCE: Xerox 4150 prints from Macs but not from XP
Have you updated the machine firmware? At Xerox.com the machine firmware is there to download and install. Currently the firmeware is at level 10.100.45.018. Even if your machine is new you may have an older version of firmware.
That machine has had tons of firmware updates to it and uploading the machine to the newest level probably will resolve your problem.
There are some versions that fix 300 known problems at an update.
You have to follow the directions carefully, updating it can wipe out your LDAP settings if you use scan to E-mail etc.
If you have a maintenance agreement, or the machine is less than a year old, ( there is a one year on site warrantee on that machine for on site service) call 1-800-821-2797 and request a service call to update your firmware.
Those updates are really critical for that machine to operate properly.
Posted on Feb 12, 2009
Mrteaze
  • 101 Answers
SOURCE: HP C5280 all in one prints but does not scan
2 ways to scan from HP printers
First* try from "my computer" ... near the bottom of the page you should see "scanners" in there, try clicking that and follow prompts
Second* go to start/ programs/ HP/ HP Solution Center
all scanning choices should be on the left
Please don' forget to rate me : )
Posted on Oct 01, 2009
  • 53 Answers
SOURCE: my MAC says my HP C5550 All-In-One printer is off line
go to printer and fax and set it up as default printer
Posted on Oct 09, 2009
SOURCE: My HP Officejet 6500 Wireless
I also have the OfficeJet 6500 and had the same problem. The black text was printing using a mix of colored inks instead of the black ink, resulting in a grey, fuzzy text. I finally found a solution. In each application under Page Setup, there is an option called "Format for". Mine had been set to "Any Printer". I changed that to "Officejet 6500 E709n [830E4A]" and now it prints the black just fine. I have a Mac running 10.4.11. Hope this helps.
Posted on Jun 20, 2011
HP Pavilion Entertainment PC issues. Laptop loads with 4 of the same screen. Won't startup so I can check the settings. Any help would be greatly appreciated!!
i think u have problem with the cable that connect motherboard to the screen ... go to closer computer and laptop-repairing office
Feb 17, 2013 | Computers & Internet
Hp pavilion DV4 won't start up
It doesn't start at all. Can you see something on screen ? Have you tried to remove the battery and charger and press power buton for 30 seconds ? And put back the battery ? Try also to check RAM Memory
Oct 14, 2012 | HP Pavilion dv4-1280us Notebook
My computer won't play CD/DVDs anymore. It's like there isn't a driver?
Most HP CD players eject. Turn upside down release. Pop out and reseat the whole player.
Sep 30, 2012 | HP Pavilion dv4-4270us Entertainment...
My HP Deskjet F380 all in one printer will copy but won't print
Switch off the printer,un install existing drivers(not to delete), restart the computer, switch on the printer, check whether system is recognized the printer?.. if not,try with another usb cable, no luck? problem with Logic card if available replace it or else go for new printer..
If system is recognized the printer, switch off the printer, run the driver CD.. connect USB cable when dialog box appears, do rest of the installation process. Shoot test page....Best off luck..
Aug 01, 2012 | HP DeskJet F380 All-In-One Printer
My hp pavilion dv6707us notebook does not recognize the dvd drive
HiReinstall the drivers you can find them in HP official page.
Good luck.
Aug 31, 2011 | HP Pavilion Dv6707us Entertainment...
My HP DV9740Us entertainment laptop will only recognize one external hard drive at a time! If i plug in another via usb it won't pick it up in My computer but the computer makes the sound as if it did...
If these drives are internally powered by the USB hub, two devices will not be recognised. ie: you can have as many pendrives as you like and they will be seen, because they draw little power from the hub, however, a larger external hard drive requires more power (some of these in fact have two usb connectors to power them). which is why your laptop will only recognise one drive at a time:
Solution: If you can get an externally powered usb drive, this should work.Another and possibly cheaper way would be to get an externally powered USB hub, which would solve the problem
Jul 28, 2011 | HP Pavilion DV9740US Laptop
My MAC says my HP C5550 All-In-One printer is off line
Oct 09, 2009 | HP DeskJet F380 All-In-One Printer
Compatibility between HP Quickdock 2.0 Docking Station KN745AA and HP TouchSmart tx2-1020us laptop for external monitor viewing
Your tx2-1020us is not compatible with the KN745AA as this device is only compatible with the following:
  • HP Pavilion dv2700 Entertainment Notebook PC series
  • HP Pavilion dv6700 Entertainment Notebook PC series
  • HP Pavilion dv9700 Entertainment Notebook PC series
  • HP Pavilion dv2600 Entertainment Notebook PC series
  • HP Pavilion dv4-1000 Entertainment Notebook PC series
  • HP Pavilion dv5-1000 Entertainment Notebook PC series
  • HP Pavilion dv5-1100 Entertainment Notebook PC series
  • HP Pavilion dv6-1000 Entertainment Notebook PC series
  • HP Pavilion dv6-1100 Entertainment Notebook PC series
  • HP Pavilion dv6600 Entertainment Notebook PC series
  • HP Pavilion dv6800 Entertainment Notebook PC series
  • HP Pavilion dv6900 Entertainment Notebook PC series
  • HP Pavilion dv7-1000 Entertainment Notebook PC series
  • HP Pavilion dv7-1200 Entertainment Notebook PC series
  • HP Pavilion dv7-2000 Entertainment Notebook PC series
You can find the compatibility chart by clicking here
You can find the compatibility information for the ES631AA by clicking here
To resolve your issue you should purchase one of the following:
To dock your notebook you need the HP QuickDock KN744AA#ABA or
You could get HP Notebook Media Docking Station
May 15, 2009 | Computers & Internet
Samsung CLX-3160FN won't print from my HP Pavilion Media Center M7467C
I have a brand new HP pavilion, but it wont print from my HP deskjet. If i am lucky i get the first p[age and a couple of lines on page 2. My new laptop (ACER) is quite happy to print using the same cable. printer etc. Conclusion...HP pav is defective. Am I wrong?
May 01, 2008 | Samsung CLX 3160fn All-In-One Printer
23 people viewed this question
jasbo
jasbo
