Question about Water Dispensing & Filtration
Culligan mark 50 water softener parts breakdown
My water softener system has worked great until now. It is an older system(mark50) but a goodie, I believe the problem is in the timer box. I have gone through it but the cycle is still continuous. I am wondering if I could just upgrade to a newer controller and utilize the rest of my system. If so what model will work? Thanks, John
    Champion:
    New Friend:
  • 217 Answers
My softener is a Culligan Mark 89. Water looks clear but is real salty. I bypassed the system and purged the lines to get rid of the taste.
Call Culligan for service. You have a serious problem as it sounds like your resin bed is not going through the backwash cycle before returning to operate mode.
Normally when your water softener goes through a recharge cycle, a solenoid operates to bypass the system while brine (extremely salty water) is drawn into the resin tank to perform the ion exchange process. This is a timed process. Once it completes then your softener switches into backwash mode where the resin bed is flushed with clear water. Finally at the end of the recharge cycle the softner switches back into normal operation.
This is not something that you can fix yourself. Contact Culligan immediately.
Nov 01, 2014 | Measuring Tools & Sensors
WHERE IS OUR SOFT WATER!? A few years back we had the Culligan man out to check our water because it was not soft (at the time, we had the Culligan Mark 100 model). After testing our water, the suggested...
The most frequent causes for intermittent hard water would be the gallon settings set too low causing the softener to run out of capacity or a meter that is not measuring the gallons. I would set the "hardness" setting on your culligan softener 30% higher than actual hardness. The softening resins they use are low in crosslink and very inefficient. Also make sure there are no toilets leaking causing hard water to "bleed" through softener. Iron filters require regular maintenance to clear oxidized iron from nozzles and the valve. Generally it is better to have the iron filter regenerate at least every 3 days to keep the bed refreshed.
RJ
Mar 01, 2012 | Culligan Sediment Water Filter
Need settings for a culligan Mark 49 softener
I have the mark 49 catalog...maybe I could help you? westyolandal@gmail.com
This whole thing is new to me....I am trying to figure out how to even use the thing?
May 25, 2010 | Culligan Sediment Water Filter
Culligan 01010091 (mark 89) softener will not auto
clean the drainage filter then it will work correctly again
Mar 05, 2010 | Culligan Sediment Water Filter
Proper Disposal of a Culligan Mark 50 Water Treatment Tank?
If you disassemble the valve completely (all metal parts) the valve itself is delrin plastic and is recyclable along with the brine tank. You may be able to scrap the softener tank. You will have to get all the resin and gravel out of it. Just tip it over take the inlet manifold out and drain the resin into a bucket, take the resin to culligan for disposal.
RJ
Jan 02, 2010 | Culligan Sediment Water Filter Heavy Duty
O-rings leak on a culligan mark 50 water conditioner
Neither a manual or parts are available for this this valve. It is obsolete.
RJ
Nov 22, 2009 | NRS Fleck 5600 - 64,000 Grain Timer Water...
Culligan Silver Water Softener - Continues to Run
Same problem, no answer... incredible how strong is the "culligan maffia"...
Jun 26, 2009 | Dishwashers
Have a 30yr. old mark 20 culligan water softner which still works
You should not have to adjust the brine setting. Just the days per week. The salt dosage is dependent on the capacity. If you cut back on the days used you will still need to use the same amount of sodium to regenerate the softener.
RJ
Apr 03, 2009 | Culligan Sediment Water Filter Heavy Duty
Water Dispensing & Filtration Logo
344 people viewed this question
Top Water Dispensing & Filtration Experts
ray gallant
Tom Chichester
Dwain Schmidt
Dwain Schmidt
Level 1 Expert
Are you a Water Dispensing and Filtration Expert? Answer questions, earn points and help others
