Question about Scuba Diving & Snorkeling
Have a full cylinder ,,have attached 2 different pressure gauges both read 0 ,,what am i doing wrong ?
jmassengill
  • 345 Answers
SOURCE: OIL PRESSURE LIGHT COMES ON AND PRESSURE GOES TO 0 ON GAUGE
Any time the oil pressure is 0 you take a chance of locking up the motor. The only way to know for sure is to put a pressure gauge in the oil pressure sending unit port on the engine and see what the pressure really is. At that point you will either have the peace of mind in the knowledge that the sending unit is really bad and needs replacement or you can then contact a repair shop and tell them what your testing has revealed. I wouldn't drive or run your truck while the oil pressure is at zero.
Good luck
Posted on Nov 10, 2008
  • 1114 Answers
SOURCE: oil pressure high
could be oil pressure switch in eng block ??engine light on? if so scan it for fault codes retreve and start looking for dealer explanation perhaps
Posted on Jan 03, 2009
  • 1201 Answers
SOURCE: 4.7 liter oil pressure gauge malfunctioning.
Check or replace the oil pressure sending unit.
Posted on Feb 25, 2009
  • 316 Answers
SOURCE: The oil pressure gauge keeps dropping down to 0 while i am driving
If you don't hear any ticking or knocking while the pressure gauge drops, the problem is probably a failing "oil pressure sensor". If you do hear a ticking or knocking, the problem is probably a failing "oil pump".
Posted on Jun 03, 2009
  • 60 Answers
SOURCE: daewoo racer 1995, petrol gauge
the easiest fix is to change the sending unit
Posted on Oct 22, 2009
I changed the oil, new oil pan, new oil pump. Drove the Jeep 14 miles and check gauge light came on and oil pressure dropped to 0. Could be sending unit?
no jeep stated
must we guess cars then guess engines?
ever heard of a pressure gauge?
when i do major engine works
I do 2 things, (all majors engine builders too)
fuel pump relay pulled.
sparks plugs pulled.
remove sender. attach gauge,
crank with no fuel ,
i get spec high pressure, with fresh 10w-40 in the sum.
no engine stated no spec,. stated.
then with valve cover off i crank it to see if I GET
top end oiling.
if not? you did it wrong! correct it NOW not at 85mph. and win,,, seems some 0-rings or gaskets mission on pump or pickup
but the sensor wire falling off, is light off
but if that wire is bare and shorts to chassis
the lamp glows, but seem odd that,
in all cases , I assume pressure is 0
and prove otherwise.
this jeep
Mar 15, 2017 | Jeep Cars & Trucks
Tank empty, gauge reads 1/4, tank full, gauge reads full, tank 1/4 full, gauge reads 1/2. Engine off, gauge reads below empty. Any ideas will be welcome.
The values differ in all types of cars. Older cars peg out at 90 ohms. Newer cars range between 0 and about 400 ohms. Dis-connect the connector at the sender. Ground the sender wire and the gage should read empty. un ground and it should read full. They use a ceramic resistor in the tank that usually go bad.
Jan 09, 2015 | Cars & Trucks
No power after 4000 rpms
This sounds like a fuel pump or fuel filter problem.
The 1988 Jetta has two fuel pumps. The "main" one under the car directly in front of the gas tank on the right hand side. The other fuel pum is in the tank. You can access that fuel pum by removing the round access panel in the trunk towards the back seat.
You'll need a fuel pressure gauge. You can usually borrow one from a large auto parts chain store.
FUEL DELIVERY & SYSTEM PRESSURES
System Pressure
Connect Pressure Gauge (VW 1318) between line from fuel distributor to cold start valve and
test port connection on lower chamber of fuel distributor, using Adapter Fittings (VW 1318/5).
Test port is sealed by a threaded plug. Bridge fuel pump relay with Jumper Switch (US 4480/3).
1.
Disconnect wiring from Differential Pressure Regulator (DPR). Open valve on pressure gauge
(points at cold start valve line when open) and activate fuel pump. System pressure must be 75-
82 psi (5.3-5.8 kg/cm2 ). If pressure reading is low and fuel pump delivery quantity is good,
replace pressure regulator.
2.
If pressure reading is high, disconnect fuel tank return line from DPR. Repeat test. If reading is
correct, check for plugged return line. If reading is incorrect with line open, replace DPR.
3.
Differential Control Pressure
Close valve on pressure gauge. Activate fuel pump with jumper switch. Leave DPR
disconnected. DPR reading should be 2.9-7.0 psi (.2-.5 kg/cm2 ) less than system pressure. If
pressure is incorrect, disconnect lower chamber return line and measure volume.
1.
Close open port to diaphragm pressure regulator. Activate fuel pump with jumper switch. Fuel
volume should be .14-.16 qts. (.13-.15L) for period of one minute. If volume is correct, replace
DPR. If volume is incorrect, replace fuel distributor.
2.
Close valve on pressure gauge. Install Test Harness (1315A/1) between DPR and vehicle
harness. Set multimeter to DCA 200 mA scale. Connect multimeter to test harness. Disconnect
wiring to coolant temperature sensor. Connect 15 k/ohm side of Test Resistor (VW 1490) to
sensor wiring.
3.
Turn on ignition and fuel pump. Differential pressure should be 10-17.5 psi (.7-1.2 kg/cm2 )
less than system pressure. DPR current should be 50-80 mA. If pressure is incorrect and current
is correct, replace DPR.
4.
If both pressure and current readings are incorrect, remove test harness from DPR. Ensure
resistance of DPR is 17.5-21.5 ohms. If reading is incorrect, replace DPR.
5.
If reading is correct, check ground from temperature sensor to cold start valve. If ground is
good, check power supply fuse. If fuse is okay, check terminals on ECU connector. If connector
is okay, replace ECU.
6.
Residual Pressure & Internal Leak Testing
Open valve on pressure gauge. Operate fuel pump for 30 seconds. Pressure can drop to a
minimum of 38 psi (2.7 kg/cm2 ) after 10 minutes. If pressure drops below specification, inspect
fuel pump check valve and all fuel fittings for leakage.
1.
NOTE: Pressure and leak testing does not include checking cold start
valve.
FUEL INJECTION SYSTEM - BOSCH CIS-E -1988 Volkswagen Jetta Page 1 of 3
http://www.ondemand5.com/mric/common/asp/printart.aspx 11/25/2011
If there are no leaks, check airflow sensor plate clearance. If plate clearance is correct, replace
diaphragm pressure regulator and repeat leak test. If pressure drop is not within specification,
replace fuel distributor "O" rings.
2.
Transfer Pump Delivery Volume
Check voltage supply to pumps. Connect Jumper Switch (US 4480/3) in place of fuel pump
relay, on relay panel. Remove fuel filler cap. Disconnect and plug off Black fuel line from
sending unit.
1.
Connect hose to sender port and place in measuring container. Turn on fuel pumps. Minimum
transfer pump delivery volume should be .42 qts. (.4L) in 10 seconds. Reconnect fuel line to
sender.
2.
Main Pump Delivery Volume
Check transfer pump (if equipped) and fuel filter. Disconnect fuel return line and place in
measuring container. Switch on fuel pump with jumper switch. Check fuel pump delivery
volume for 30 second period. Delivery rates are given with voltage reading at pump as volume
will change with different voltages.
1.
Minimum delivery volume for Fox, Quantum and Quantum Syncro models is .71 qts. (.68L) for
30 seconds with reading of 11.4 volts at fuel pump. Minimum delivery volume for other models
is .62 qts. (.59L) with 11.4 volts at fuel pump.
2.
Fuel Distributor
Check sensor plate adjusting lever and fuel distributor control piston for smooth operation.
Disconnect fuel injector lines at fuel injectors.
1.
Remove fuel pump relay and bridge fuel pump circuit. Use Jumper Switch (US 4480/3) in place
of fuel pump relay. When pressure has built up, turn off fuel pump. Move sensor plate from rest
position to end of travel.
2.
Uniform resistance should be felt during entire movement. No resistance should be felt on
quick return to rest position. Connect injector lines. Install fuel pump relay.
3.
Injector Quantity Comparison
Remove fuel pump relay, from relay panel, and install Jumper Switch (US 4480/3) in off
position in place of relay. Attach Fuel Quantity Analyzer (US 4480) to bumper and secure in
place. Remove injectors from cylinder head with fuel lines attached. Check and replace fuel
injector "O" rings as necessary.
1.
Check tightness of injector insert (2-piece inserts). If inserts are loose, remove and clean
threads. Use sealing compound when installing upper insert. Replace sealing washer that goes
against cylinder head below lower portion of insert. Lubricate injector "O" rings with gasoline
and install injectors, with fuel lines connected, into fuel quantity analyzer tubes.
2.
Ensure lines are not kinked or bent. Loosen fittings to align fuel lines and retighten. Remove
rubber boot from airflow sensor housing above sensor plate. Turn and lift setting screw and
adjusting slide of Sensor Plate Adjustable Holder (VW 1348/1) into upper position. This
simulates full throttle operation. See Fig. 11 .
3.
FUEL INJECTION SYSTEM - BOSCH CIS-E -1988 Volkswagen Jetta Page 2 of 3
Fig. 11: Sensor Plate Adjustable Holder (VW 1348/1)
Courtesy of AUDI OF AMERICA, INC.
Place sensor plate adjustable holder on airflow sensor housing with holder centered over plate.
Pointer on edge of holder base must point toward center of fuel distributor. Push adjusting slide
of holder down onto stop.
4.
Turn adjusting screw clockwise until magnetic end touches sensor plate retaining bolt. Activate
fuel pump with jumper switch. Turn adjusting screw of holder counterclockwise until any one
injector starts to deliver fuel. Turn off jumper switch and empty fuel quantity analyzer after
taking sample.
5.
Idle injection quantity is measured first. Lifting adjusting slide of holder to first stop simulates
idle position of sensor plate. Activate fuel pump until fuel level reaches 20 ml on scale of any
tube.
6.
Check that all injectors have identical spray patterns that are even and cone-shaped. If not, raise
sensor plate up quickly to full lift position and release. Repeat idle quantity test. Compare
amounts of fuel delivered by all injectors with analyzer held level. Maximum difference in
delivery quantity between injectors is 3.0 ml of fuel.
7.
If fuel delivery quantity differs between high and low levels by more than 3.0 ml, interchange
injectors and repeat test. If difference of delivery quantity changes with injectors, replace
injectors. If difference of delivery quantity does not change with movement of injectors, either
fuel lines are pinched or fuel distributor is defective.
8.
Measure full throttle injection quantity. Empty analyzer into fuel tank and reinstall injectors in
analyzer. Lift adjusting slide of holder to last stop to simulate full throttle position of sensor
plate. Activate fuel pump with jumper switch until fuel level reaches 80 ml on scale of any tube
of analyzer.
9.
sensor plate up quickly to full lift position and release. Repeat full throttle quantity test.
Compare amounts of fuel delivered by all injectors with analyzer held level. Maximum
difference in delivery quantity between injectors is 8.0 ml of fuel.
10.
If fuel delivery quantity differs between high and low levels by more than 8.0 ml, interchange
11.
Check fuel injectors for leakage immediately after delivery quantity test is complete. Set sensor
plate in rest position. Activate fuel pump with jumper switch for 2 minutes. Injectors should not
drip. Replace injectors that drip.
See image. Fuel filter is probably located on the frame between the engine and fuel tank.
Jul 03, 2012 | 1988 Volkswagen Jetta
The oil pressure gage started registering 1/4 instead of it's normal 1/2 even at 1700 rpm. I FREAKED! Thoughts?
I have an oil pressure gauge that reads in analog, 0 to 150? something like that, any way, it moves like a tachometer, idle down around 10, revs up to 55, 60 when taking off and then settles down at 35 while cruising, I notice a change with heavier oil. Also, I know it will read 55 lbs pressure with 1 qt of oil in there, I tried it. So the pressure gauge has nothing to do with amount of oil in engine. As long as it is full, It should be ok, as long as it is reading pressure, but if the pressure drops off, shut it down and find out what happened, If it loses all the oil, the temp light should come on long before the oil light.
Dec 14, 2010 | 1997 Chevrolet K1500
There is had start and heating up of the engine number RJM 510253 Engine 4JX1 Chassis: USB 73GW7202143 I am in Zambia and I have tried everything I can but the problem is not going out
Try a compression check of every cylinder. A blown head gasket could be the result. 1. Remove the coil wire. 2. Remove a spark plug wire and plug. You should do 1 at a time. 3. Install a compression gauge. 4. Have a second person crank the engine until the gauge is at the appropriately rated pressure and write it down. 5. Do this with each cylinder. 6. Compare the readings on each cylinder. Every cylinder should be about the pressure. Of course engines with a lot of miles can normally have a little difference in pressure,but not too much. The one with the lowest reading could have a bad head gasket,resulting in overheating,and hard starting.
Oct 06, 2010 | Isuzu Trooper Cars & Trucks
My 1969 chevelle's gas gauge is stuck pass full.bad gauge or sending unit? how to tell?
According to what I read, test the gauge first. Hook power to where the white wire attaches. Hook a ground to the black wire connector. The gauge should rise to full. (May take a while). When on full, the tan wire connector to same ground. It should go to empty. If both work, gauge is good. To test sender, in the empty position, your ohm meter should read 0-2. 1/2 tank should read about 40, and full should read 84-88 ohms.
May 17, 2010 | Cars & Trucks
2002 Jeep Grand Cherokee 4.0L oil pressure gauge reading too high
if the gauge starts a 0 - goes to 1/2 , than full - sounds like gauge is OK - seems to me like the sending unit is bad - you could try removing the sender and trying to clean out the port with "brake clean", letting it dry than re-installing it. the pressure switch is still the least expensive place to start
Oct 27, 2009 | 2002 Jeep Grand Cherokee
Compression test results (I think I am doing something wrong)
sounds like you need a new head. valves may be bent.
Jun 05, 2009 | 1994 Chevrolet Cavalier
I'm looking for Elektra S1 Owner.s manual
if you have 2 gauges, one shows from 0 up to 3 bar second from 0 up to 16 bar.
  1. the gauge o - 3 shows steam pressure and it should be from 1.1 up to 1.5 bar
  2. if you have second gauge you look it during brewing coffee, it should be from 7 up to 9 bar(it shows the pressure of pump.
anyway becouse it is old machine you should compare the gauge with new one(ehamle for the steam attach to steam pipe one gauge and live valve open) than you will know if it is showing true values.
Nov 23, 2008 | Elektra Microcasa S1 Coffee Maker,...
Scuba Diving & Snorkeling Logo
74 people viewed this question
Top Scuba Diving & Snorkeling Experts
Bill Boyd
ray gallant
Are you a Scuba Diving and Snorkeling Expert? Answer questions, earn points and help others
