Question about Bose Cd Changer C1 To M1-multi Room Cable/ Wire For Lifestyle 50- 8 Pin To 8 Pin
Bose multi room interface - Bose Cd Changer C1 To M1-multi Room Cable/ Wire For Lifestyle 50- 8 Pin To 8 Pin
2 Suggested Answers
otacon
  • 1944 Answers
SOURCE: Bose system (Lifestyle 50)
Did you try leaving it unplugged for a few hours?
Posted on Feb 24, 2008
I had Bose lifestyle V35, V20 try to link together. Bose link AL8 transmitter will not connect to receiver. both led is light solid green. Please help.
The commands for the Bose link system are actually going through the remote control system. In order to use the system you need not only a set of AL8 sender and receiver, but also a special remote control model RC48S2-40 these model numbers are slightly different for the US and for Europe. In addition you will need to activate the BoseLink connection through the system settings menu and you will need to tell the remote to which system it needs to talk. When you have done all that, there should not be any problem to "connect" the two systems. If this does not work, you may need some specialized help from a Bose specialist who understands this multi room set-up.
Nov 09, 2014 | Bose link AL8 wireless home-wide audio...
Feb 24, 2008 | Bose LifeStyle 50 System
Remote shows no response
I have just had a major problem trying to get the handheld (touch screen) music centre to communicate with the multi room interface. It took over a week to sort out by trial and error, but here is the solution :
1. Disconnect everything from the multi room interface apart from Room A and the CD player (blue connector).
2. Turn off the electricity supply at the wall (turning off any in line extension lead is not good enough - it needs to be at the wall socket). Leave turned off for at least 2/3 hours.
3. Turn back on and then leave it again for 2/3 hours.
4. Touch the music centre and you should find that it has now registered with the interface unit.
5. Connect the other rooms and input sources with the power switched on (contrary to instruction manual which advises you connect everything before powering up).
6. Test each input systematically as you connect them.
Hope this helps. I was on the verge of buying another multi room interface (I have 2 music centres and neither worked so assumed in was the interface at fault), at a cost of £200, so now glad I persevered with resetting the system !
Mar 03, 2014 | Bose LifeStyle 50 System
Lifestyle 50 not responding
Reconnect the Bose link connection at the Multi room interface and at the Acoustimass Module.If this doesn't help,change the remote control batteries.If the it still display "no response",it means either the interface or remote is bad
Jul 28, 2013 | Bose Lifestyle 40/50 Music Center Used...
I am having a Bose Cinamate Digital Home Theater. Original remote of this was lost and bought a new Bose Solo/cinemate system universal remote. It doesn't function with the interface. Will it real
If you can't get this to work, I suggest you try to return the remote and buy and harmony remote. For me it worked very well with everything including old audio amps and you can configure your own activities.
Oct 20, 2012 | Bose Cinemate Digital Home Theater System...
Replacement part for Bose Cinemate Interface
Replacement parts for Bose Cinemate Interface can be foudn at amazon, take a look here: Amazon com Bose Cinemate parts. I hope this helped. Cheers
Oct 29, 2011 | Bose Cinemate Digital Home Theater System...
901 bose to my denon 3805
Short answer from personal experience.
Get a separate power amp for the 901's. Connect the EQ between the pre-outs and the amp input. Run speaker assignment, levels, etc and have fun.
If you don't have the between-speaker room for proper reflection off the front wall you CAN turn them around and you won't believe the amount of air these things push! I have actually felt it ten feet away after explosions or crashing ocean wave sounds. Now THAT is multi-media.
Dec 20, 2010 | Bose 901 VI Main / Stereo Speaker
I am trying to install my deh-p6500 in my new truck, but the wireing plugs do not match up. What can i do?
The installation will depend on how you truck is equipped.
If you have On-Star without the Bose system you will need an interface like this.
If you have On-Star and the Bose system you will need an interface like this.
If you have neither On-Star not Bose than you will need a harness like this.
If you do not have On-Star but you have the Bose system than you need this.
This use of these interfaces/harnesses make the installation very clean and reliable. There is no easy way to retain On-Star without the use of the interface but you can hard wire the radio if your truck does not have it.
Nov 12, 2010 | Pioneer DEH-P6500 CD Player
I have a lifestyle system with surround sound at central location and two remote rooms connected through two additional amplifiers. The central location works perfectly well. Recently, I started getting...
Probably the connection in the main room to the wirless transmitter. The problem is definitely between the media centre and the wireless sender as it is not effecting the main zone and is effecting both second zones. Multi pin connections can bend very easily if pushing the connection further in does not solve it you may need to replace the pins. why not call Bose tech?
Feb 19, 2009 | Bose SoundDock Digital Music System for...
Bose Cd Changer C1 To M1-multi Room Cable/ Wire For Lifestyle 50- 8 Pin To 8 Pin Logo
54 people viewed this question
Top Bose Car Audio & Video Experts
xxxxxx xxx
Tina Robinson
David Burbee
David Burbee
Are you a Bose Car Audio and Video Expert? Answer questions, earn points and help others
