Philips 32PFL7603H/10---chassis q5282E.LB---alim DSP 182 -CP
What is the correct metric weight for 13 stone.
14 lb = 1 stone
so 13 stone = 182 lbs ( troy )
182 lbs = 67.929 kg
or in ave poy lbs
182 lbs = 82.5 kg
the difference is depending on which country you are in
Jun 07, 2017 | The Health & Beauty
Would like to have torque specs chart please?
Hi there, the following information are for a 2004 Grand Am 2.2L, I hope it helps:
Timing Chain, Sprockets, and/or Tensioner Replacement
Tighten the chain guide bolts to 10 N·m (89 lb in).
Tighten the chain tensioner bolts to 10 N·m (89 lb in).
Tighten the oil nozzle bolt to 10 N·m (89 lb in).
Timing chain tensioner guide bolt to 10 N·m (89 lb in).
Timing chain bolts to 10 N·m (89 lb in).
Chain guide plug to 90 N·m (66 lb ft).
Timing chain upper guide bolts to 10 N·m (89 lb in).
Timing chain tensioner to 75 N·m (55 lb ft).
Camshaft bolts to 85 N·m (63 lb ft) plus 30 degrees.
Intake Manifold Replacement
Manifold Nuts and Bolts: 10 N·m (89 lb in).
Aug 30, 2014 | 2004 Pontiac Grand Am
Philips 26pf9531 reboots
Firmware has to be updated.
Jun 28, 2013 | Televison & Video
I need remote controller for philips dsp 5500
i want philips home theater model no dsp 5500 remote controller
Aug 26, 2011 | Audio Players & Recorders
Hello my laptop philips freevents h12y i need audio driver win7
Hi shulalbvvc, "Go to this "Website!"
It shows 'all the Audio Drives for the "Philips Freevents H12Y!"
Scroll down to find:
Fill-in necessary information.
ie: Model #, Brand, and or Operating System...
"Select the [Drivers] you need from the "List."
"Download the Drivers!"
!Important: "Take a 'moment to rate the help', so I can get 'credit' for the work.
Thank you!" - paul7of9
Click here: http://www.search.philips.com/search/search?h=support&o=support&q=Audio+Drivers+Windows+7+philips+freevents+h12y&f=all&i=all&language=&l=us_en&s=all&n=10&d=&p=&p_fld=&p_val=&highlighted_param_entry=¶m_group=¶m_group_value=&first=&last=&next_start_hit=11&bannercount=0
Mar 16, 2011 | Computers & Internet
WHAT DOES ACCY &ALIM MEAN
ACCY stands for "Accessory" and ALIM stands for "Alarm Immobilizer".
Jul 30, 2010 | 1995 Ford Taurus
How to replace oil pan on a 1995 geo tracker 4 wheel drive
1 Raise and support
2 Remove front diff assembly from chassis
3 Drain oil
4 Remove clutch or torque converter housing lower plate
5 Remove oil pan
OIL PAN BOLTS 6.7 - 8.9 ft.lb
OIL PRESSURE SWITCH 10 ft.lb
Mar 11, 2010 | 1995 Geo Tracker
Torque specs for the cylinder head
2004 ENGINE
Engine Mechanical - 1.6L (L91) - Aveo
SPECIFICATIONS
FASTENER TIGHTENING SPECIFICATIONS
Fastener Tightening Specifications
Application
Specification
Metric English
A/C Compressor Mounting Bolts 27 N.m 20 lb ft
A/C Compressor Mounting Bracket Bolts 50 N.m 37 lb ft
Air Filter Housing Bolts 12 N.m 106 lb in
Alternator Adjusting Bolt 20 N.m 15 lb ft
Alternator Adjusting Bracket Retaining Bolt 20 N.m 15 lb ft
Auxiliary Catalytic Converter-to-Exhaust Manifold
Nuts and Bracket Bolts
40 N.m 30 lb ft
Camshaft Cap Bolts 16 N.m 12 lb ft
Camshaft Gear Bolt 67.5 N.m 49 lb ft
Camshaft Pressure Plate Bolts 10 N.m 89 lb in
Connecting Rod Bearing Cap Bolts 25 N.m+30°+15° 18 lb ft+30°+15°
Coolant Pump Retaining Bolts 10 N.m 89 lb in
Coolant Temperature Sensor 20 N.m 15 lb ft
Crankshaft Bearing Cap Bolts 50 N.m+45°+15° 37 lb ft+45°+15°
Crankshaft Position Sensor Retaining Bolt 10 N.m 89 lb in
Crankshaft Pulley Bolt 95 N.m+30°+15° 70 lb ft+30°+15°
Cylinder Head Bolts - Camshaft Support Housing
and Cylinder Head Mounting Bolts
25 N.m+60°+60°
+60°+15°
18 lb ft+60°+60°
+60°+10°
Electronic Ignition System Ignition Coil Mounting
Bolts
10 N.m 89 lb in
Engine Mount Bracket Retaining Bolt 65 N.m 48 lb ft
Engine Mount Bracket-to-Engine Mount Retaining
Bolts
60 N.m 44 lb ft
Engine Mount Retaining Nuts 40 N.m 30 lb ft
Exhaust Flexible Pipe Bracket Bolts 40 N.m 30 lb ft
Exhaust Gas Recirculation Valve Adapter Bolts 25 N.m 18 lb ft
Exhaust Manifold Heat Shield Bolts 15 N.m 11 lb ft
Exhaust Manifold Nuts 25 N.m 18 lb ft
Flexible Plate Bolts 60 N.m 44 lb ft
Flexible Plate Inspection Cover Bolts 10 N.m 89 lb in
Flywheel Bolts 35 N.m+30°+15° 26 lb ft+30°+15°
Flywheel Inspection Cover Bolts 12 N.m 106 lb in
Front Muffler-to-Main Catalytic Converter Nuts 30 N.m 22 lb ft
Fuel Rail Retaining Bolts 25 N.m 18 lb ft
MITCHELL 1 ARTICLE - 2004 ENGINE Engine Mechanical - 1.6L (L91) - Aveo Page 1 of 330
http://www.eautorepair.net/app/PrintItems.asp?S0=2097152&S1=0&SG=%7BEEDCF... 3/30/2009
ENGINE MECHANICAL SPECIFICATIONS
Engine Mechanical Specifications
Intake Manifold Retaining Nuts 25 N.m 18 lb ft
Intake Manifold Support Bracket Lower Bolt-to-
Engine Block 40 N.m 30 lb ft
Intake Manifold Support Bracket Upper Bolts 25 N.m 18 lb ft
Lower Timing Belt Cover Bolts 10 N.m 89 lb in
Oil Pan Retaining Bolts 10 N.m 89 lb in
Oil Pressure Switch 40 N.m 30 lb ft
Oil Pump Retaining Bolts 10 N.m 89 lb in
Oil Pump/Pickup Tube and Support Bracket Bolts 10 N.m 89 lb in
Oil Pump Safety Relief Valve Bolt 36 N.m 22 lb ft
Oil Pump Rear Cover Bolts 6 N.m 53 lb in
Power Steering Pump Mounting Bolts 25 N.m 18 lb ft
Power Steering Pump Pulley Bolts 25 N.m 18 lb ft
Rear Timing Belt Cover Bolts 10 N.m 89 lb in
Spark Plug Cover Bolts 3 N.m 27 lb in
Spark Plugs 25 N.m 18 lb ft
Thermostat Housing Mounting Bolts 20 N.m 15 lb ft
Throttle Cable Bracket Bolts 8 N.m 71 lb in
Timing Belt Automatic Tensioner Bolt 25 N.m 18 lb ft
Timing Belt Idler Pulley Bolt 40 N.m 30 lb in
Transaxle Bell Housing Bolts 75 N.m 55 lb ft
Transaxle Brace Bolts 40 N.m 30 lb ft
Transaxle Torque Converter Bolts 65 N.m 48 lb ft
Upper Timing Belt Cover Bolts 10 N.m 89 lb in
Valve Cover Bolts 10 N.m 89 lb in
Application
Specification
Metric English
General Data
 Engine Type 4 Cylinder - In-Line
 Displacement 1598 cm3 97.51 in3
 Bore Stroke 79.0x81.5 mm 3.1x3.21 in
 Compression Ratio 9.5:1
 Firing Order 1-3-4-2
 Maximum Power - At 6200 RPM 77 kw/103.3 hp
 Maximum Torque - At 3400 RPM 145 N.m 106.9 lb ft
Cylinder Bore
 Diameter 79 mm 3.1 in
 Out of Round - Maximum 0.0065 mm 0.00025 in
 Taper - Maximum 0.0065 mm 0.00025 in
Piston
MITCHELL 1 ARTICLE - 2004 ENGINE Engine Mechanical - 1.6L (L91) - Aveo Page 2 of 330
Jan 07, 2009 | 2004 Chevrolet Aveo
Picture of assebly for chicago pneumatic demolition tools
Parts / Diagram here http://www.toolsrenewed.com/AirToolPrints/CP/CP-1230%20Breaker.pdf
You might post again describing the problem that you are having with the hammer. Enjoy
Dec 10, 2008 | Chicago Pneumatic Demolition Tool - 60 lb....
Televison & Video Logo
114 people viewed this question
Top Televison & Video Experts
Electro Med Services...
