Question about Toshiba 62HMX84 62" Rear Projection HDTV
Toshiba cx36f84 screen went black
It was working good changed the chanel went black red power light just blinks
  • GehlichS Nov 09, 2007
    Under the counter t.v. screen went black after changing the channel. Worked fine up until then. Sound works, just no picture
New bulb needed
Posted on Jan 04, 2008
SOURCE:
I have toshiba 50hm67 replaced lamp...tv worked, then quit working again, and giving blinking yellow lamp error light when turn on...after a few moments tv tries to turn off and back on
OK. I have this same issue. I replaced my bulb a month or so ago. TV worked fine. Then one morning I turned it on and it was on for a good while, till it went to a black screen w/ sound only. Lights were going through the reboot process as designed for 8 attempts before it went to the solid red light. From the red light, if I unplug and plug back in, the tv will come on for a given amount of time, which varies, and then cut to the black screen. A repairman told me that it sounds like the digital board is bad. He wanted $150 for the board and $100 labor. I cannot find anywhere where the board would be located or where I can purchase a replacement.
Jun 15, 2011 | Toshiba 50HM67 50" HDTV
I’m having a problem with my Toshiba 42HL196. Once or twice the red LED was flashing and I held the power button in for a bit and it started working again. Today I was having cable installed and after a...
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Mar 13, 2017 | Toshiba 42HL196 42 in. LCD HDTV
My Toshiba 50H81 screen black, no sound & power light blinking
sounds as if your power supply needs to be repaired. the capacitors over heat and crown or leak.
Jan 01, 2010 | Toshiba 50H81 50" Rear Projection...
Red power light continuously blinking. no picture no sound.
It could be the lamp went out and needs replacement. The Toshiba website states when this happens to unplug the televison for 10 minutes then plug back in. If that does not work then try another power outlet. If that does not work then call for service
Sep 12, 2009 | Toshiba 57H81 57" Rear Projection...
Toshiba 42HP95 Plasma tv
http://www.fixya.com/support/t101749-tv_turned_itself_off_turn_back
Worked for me, was ez, and I am a huge skeptic and not very "TV technical."
Dec 23, 2008 | Toshiba 42HP95 Television
Toshiba cinema series convergence problem
If you wish to get some details; visit the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/ Convergence adjustment procedure to many brands of projection TVs are given in detail.
Jul 10, 2017 | Toshiba CX36F84 TV
Toshiba dlp 46 inch red light keeps blinking
42 inch Toshiba DLP. Was watching a movie and the screen went dark. The red light started to flash and kept flashing. any ideas
Jun 26, 2008 | Toshiba 46H84 46" Rear Projection...
Blinking led light on Toshiba
wow i must be another one with this toshiba common problem bug. Has anyone even remotely helped on this site?
Feb 27, 2008 | Toshiba TP50F50/51 50" Rear Projection...
Toshiba 62HMX84 62" Rear Projection HDTV Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
