Question about Lexmark Wheelwriter 1000 Typewriter
Roller The rubber roller stopped rolling. Whenever I press return, it do not return.
  • Lexmark Master
  • 3,594 Answers
If nothing happens no carrier movementor paper feed you probably have a bad keyboard.
If the carrier moves but no feed the index motot may need to be lubed.
If the roll moves but the paper dosen't you may have debris on the paper tray or bad lower fed rolls.
DickyO
Posted on May 20, 2013
Why does the roller on my commodore typewriter not roll on the ends but rolls with the handle?
We now only are used to return. There used to be a CR Carriage return and a LF line feed.
Look if your type writer does get both signals. Or is it really an old school mechanical thing, then it is working correct.
Jun 19, 2014 | Computers & Internet
The roll brush will not turn when on floor. Too much pressure stops brush. Changed belts and still not working
Turn the belt inside out. This problem stems from a design flaw in the mechanism that turns the hoover from bare floor to carpet. After taking it apart I realized that the spring that pushes the belt tight (to make roller spin) is not any where near strong enough to keep the brush rolling. My solution was to turn the belt inside out (there by essentially shortening the belt and allowing enough pressure to be applied to the roller to keep it spinning. Horrible design flaw. I am an engineer and find this pathetic. Hope this helps someone.
Jan 22, 2010 | Hoover U5780-900 Windtunnel Cyclonic...
Is the roller suppose to continously go around when running? Doesn't seem to change mat in carpet when going over it. Doesn't seem to be much suction..
That means that you need to replace the belt. The belt is what turns the roller brush, and when it is stretched or worn it doesn't. You can get replacement belts here:
Replacement Vacuum Belts
Jan 03, 2010 | Vacuums
HP 870Cse feeder/roller is dead
Take a very small amount of Goo Gone on a paper towel and roll it over the rollers. You can press and hold the top button to get the rollers moving. This will revitalize the rubber rollers. My printer is over ten years old and I do this about every two years and never get a misfeed.
Dec 08, 2009 | HP Deskjet 870cse Printer
Paper feed roller continuously rolling
The problem lies in the solenoid and or the frame that hold the solenoid so your feeder roller never stop rolling
Jun 08, 2009 | Sharp AL-1000 Laser Printer
Top roller stripped off rubber when had a jam
If you have just taken delivery, it must still be under waranty. The roller can get stripped so soon. Shld return it to supplier.
May 23, 2009 | Xerox DocuColor 12 Printer
Fantom twister wont work light is on
When you say, "just stopped", did the MOTOR stop operating and there's no sound from it at all? Or, is the motor still working or sounds like it does, and it stopped vacumning?
If the MOTOR stopped, most likely there is a short somewhere in the connection at the motor. Think 'repair shop'.
If the motor still runs and there's no VACUMN ACTION, think Roller Brush which operates by virtue of a rubber belt. Turn the machine on its side and turn it ON, keeping FINGERS !AWAY! from the roller area. If the Roller Brush is not moving it may be that the belt has slipped off or is broken or simply too loose to turn the Roller. Also sometimes debris such as strings, long hair, carpet strands/fibers will become wrapped around the roller especially next to the roller bearing/brace points, to the point of binding so tightly that the roller will no longer be able to actually roll which would now prevent it from 'Vacumning' or sweeping dirt and such up into the vortex of the vacumn chamber. In which case, !!UNPLUG!! the machine, use small scissors to cut away the material wrapped around the roller paying particular attention to the brace point areas.
Apr 20, 2009 | Fantom Vacums FM780 Twister 700LX Upright...
Canon PC 1060 will not SCAN
Cleaning the rubber rollers on the ADF may help it to pull the paper through; I did it on my 1060 and I think it helped. (This was suggested in another post some time ago.)
Press Additional Functions. Use arrow keys to find ADJUST/CLEAN; press SET. Use arrow keys to find CLEAN ADF ROLLER. Open the ADF. Press SET. Each time you press SET, the rollers will rotate a partial turn. With the corner of a soft cloth slightly moistened with isopropyl (rubbing) alcohol, wipe the black rubber rollers both on the bottom and top of the ADF. Push SET again and rub again, several times. (DO NOT use alcohol on the long white roller! Use a dry cloth only, if you want to clean it.) Push STOP/RESET when you're done.
Touch the rollers only after they stop--not while they are rotating!
No guarantees, but it may be worth a try.
Jan 18, 2009 | Canon PC-1060 Black and White Copier
Printer problem
Your transfer roller needs replacing.
Feb 22, 2008 | Lexmark T630 Laser Printer
Brush roller stopped rolling
My daughters is doing the same thing and the plastic at the ends of the brush bar melted just enough for it not to turn properly. You might want to chech that.
Nov 25, 2007 | Eureka 2961AVZ Bagless Upright Vacuum
Lexmark Wheelwriter 1000 Typewriter Logo
59 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
