Question about Saeco VIA Venezia
Machine will not brew espresso
I have recently purchased a Via Venezia, the first time I used it the water did not push through it like videos I seen on you tube and then stopped working all together. Being a used machine and probably sat unused for a while I assumed it needed a cleaning witch I did and it still did not work. I removed the cover and the filer holder assembly and monitored the process. The system still did not work and the only thing that I noticed is it looked like the pressure was slipping past the pump. I could see steam on the suction side of the pump. It the pump pooched?
4 Suggested Answers
EsWorld
  • 1618 Answers
SOURCE: Saeco Via Venezia leaks water from front top overhang.
That is not normal, this tells me that the pump has too much pressure that it is forcing water through the brew unit, or the expansion valve(if your model has one was not set properly). Is there a high pitch noise when the pump is running. If yes then it is the expansion, if no then the springs and the valve pins in the brew valve(small white plastic piece behind the brew unit) needs to be replaced.
Posted on May 22, 2009
  • 80 Answers
SOURCE: wont brew coffee or steam
check steam valve sometimes valve make problem or steam wand is plugged
Posted on Aug 02, 2009
  • 500 Answers
SOURCE: My machine won't brew. It
Hi hfish100,
I believe your Saeco Coffee Maker needs a brew head cleaning. It can get clogged with coffee residue and oils. Or it could be a bent injector valve or gate valve. Try the following:
- Remove the brew unit. Hold the handle, now the left top side is the "brew head". There will be an outlet pipe that exits the front side, towards the door (L-Shaped). Remove the 2 screws holding it to the top, while holding the L-Shaped pipe. Once they are removed, lift the l brew unit assembly off (be wary, there is an O-ring, spring and rubber seal/disk at the end) Then remove the brew screen, by holding the screen with your finger and twisting the thumbscrew (with your finger not a key)
Under the screen is 2 holes (1 big one in the center, and a small one to the side)
- Put the brew unit upside down over a towel, insert a toothpick or a paperclip into the small hole and force anything out the other side. Use the toothpick/paperclip from this side to prevent damage to the seat on the other side.
- Clean the unit and then reassemble. Put the brew unit on towel right side up, now drop the crystal ball in first. Then the spring small on the crystal ball, followed by the O-Ring over the spring, then place the manifold on top of that with the pipe towards the machine. Re-fit your screws, and tighten them.
- Re-Install screen, and tighten with your fingers (Remember! Your fingers). The screen just needs to be flush with the bottom of the brew head.
If done correctly this should solve your problem.
Kind Regards
JEDEMEYER1
* If this solution helped you, please accept it
Posted on Aug 18, 2011
Is it worth it to get the machine fixed if the heating element no longer works?
Saeco Via Venezia - YouTube
? 3:10
www.youtube.com/watch?v=8L8vdfMOx2g
Nov 24, 2011 - Uploaded by TheSTiGUi
I dusted off my old Saeco Via Venezia, and wanted t. ... Quick run down of my incomplete modified Saeco Via Venezia Espresso Machine ... a start temperature of ~95deg C (obviously depends on boiler water temperature etc.) ...
Jul 28, 2015 | Saeco VIA Venezia
How do I properly descale my via venezia espresso machine?
I believe the proper way is to run a vinegar water solution through the machine several times, I don't like to mess around so I use Lime away descaler, run it through both the steamer and the shot dispenser but not letting it get really hot while doing it. then I run several batches of cold clear water through the machine to rinse it.
Jun 14, 2010 | Saeco VIA Venezia
Brew button turning off
The thermostat is cycling. This is normal as the unit has a small boiler. It is trying to maintain the temperature. It is a good idea to run some water (brew) through the portafilter before you put you coffee in to make you espresso. This will heat the portafilter, so you espresso is hot, and you get the good creama.
Dec 22, 2009 | Saeco VIA Venezia
My machine seems to heat up, it runs like it is drawing water into the boiler and it will froth but it does not brew espresso now. What could be the problem?
Hi
If water comes out the head with out the portifilter in then its you portafilter or your grinds are too fine. If its not coming out the head then your pipe in the brew head are plugged with scale.
Nov 25, 2009 | Saeco VIA Venezia
My Saeco Via Venezia espresso maker broke; the screw that holds the metal filter into the machine will not remain there. What can I do?
HI
There is a large screw in the brew head that your screw screws into. You need to replace the big screw and you should be good to go.
Nov 12, 2009 | Saeco VIA Venezia
Wont brew coffee or steam
Aug 02, 2009 | Saeco VIA Venezia
Saeco espresso machine Isn't pulling water at all
Can you brew a coffee? If not then the problem is the pump might be blocked.
Jun 22, 2009 | Saeco VIA Venezia
May 22, 2009 | Saeco VIA Venezia
Water won't come out like its blocked
Water won't come out when you brew coffee or use the steam wand?
If its when you are using the steam/hot water valve the parnello might be clogged.
If it is when you are using the brew head, then try backwashing the machine with espresso machine cleaner(Purocaff or Cleancaff).
The pump could also be blocked, or the spring in the pump might be damaged, open machine and check pump.
May 15, 2009 | Saeco VIA Venezia
Coffee not pouring through portafilter
if your grounds are tamped down too tight, the steam can't get through it.
Dec 30, 2008 | Saeco VIA Venezia
Saeco VIA Venezia Logo
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
