Question about Car Audio & Video
Pioneer deh p480mp..not able to get radio to turn on. I have power to harness. Good ground just seems as if no power to face plate...contacts appear to be clean any suggestions?
  • 54 Answers
Hi jeff, recheck the power wiring again namely the yellow,red and black wires. when the harness is wired and then connected to the unit you will notice that the cd eject motor will run for a few seconds. this is a good sign that the unit is correcly wired up. make sure that both the re and yellow wires receives +12v once the vehicle is started. if this does not help then the rest of the problem lay inside ur unit. cheers.
Posted on May 05, 2013
Eagleeyes
  • 199 Answers
SOURCE: Ribbon cable between the face plate and mother board need part #
www.carradiospares.co.uk
mark
Posted on Nov 25, 2008
  • 124 Answers
SOURCE: how do i turn aux on my pioneer deh-7600mp radio
Shut it off then hold the function button, cycle through till you find your option to turn it on, the turn the radio back on and use you source button to change to CD, TUNER, and AUX
Posted on Dec 27, 2008
  • 7 Answers
SOURCE: Car Radio just stoped working.
My same model did this too. The wiring harness may have gone bad. Try direct wiring the stereo or replacing the wiring harness if you can get one. This fixed the problem for me.
Posted on Jun 28, 2009
MNfisherman
  • 11896 Answers
SOURCE: Another one with Faceplate buttons not working?
The capacitors in these plates tend to burn out quickly for being so hot and lack of air cooling circulation. You can test all connection pins on the deck and faceplate with an ohmmeter in ohm setting to see which pins is not sending 25-30 ohms or 5 volts of power
Posted on Oct 23, 2009
  • 68 Answers
SOURCE: wiring diagram for pioneer deh-p41
Yellow for memory.
Red for power acc.
Black for ground.
Blue for remote turn on(amps and accessories).
Gray pair is for right front speakers, solid for positive,striped for negative.
White pair for Left front, again solid is pos, striped is neg.
Violet or purple for right rear, same with solid or striped.
Green pair for left rear, same solid/stripe configuration.
Posted on Nov 17, 2009
How do i set clock on pioneer DEH-P480MP
Press function button repeatedly until clock appears on the screen. Press the left right arrows to select what you want to adjust, hour or minute and then press up and down arrows to adjust it. You can find these instructions in the user manual, page 37.
Mar 07, 2011 | Pioneer Premier DEH-P480MP CD Player
How do you make an aux port work on Pioneer Premier DEH-P480MP CD Player
turn off the unit. after it powers down hold the function key and a menu pops up. from there just hit the function key untill you find aux and then turn it on.
Jan 29, 2011 | Pioneer Premier DEH-P480MP CD Player
How do I set the clock on my Pioneer DEH-P480MP CD Player
Press function button repeatedly until clock appears on the display of your Pioneer DEH-P480MP. Press the left right arrows to select what you want to adjust, hour or minute and then press up and down arrows to adjust it. You can find these instructions in the user manual, page 37.
Nov 27, 2010 | Pioneer Premier DEH-P480MP CD Player
WHEN I PLUG MY STEREO TO MY CAR AS SOON I PRESS VOLUME KEY THE STEREO GOES OFF AND THEN BACK ON NEED HELP
You have to check the radio harness and see if the connections are correct or if you have a grounding problem or some short. Check the face plate for any damage to the connectors were it meets the main deck were the radio face sits in.
Good luck.
Jun 12, 2010 | Pioneer DEH-P6800MP CD Player
Display not working
I have the same problem. There's a little ribbon cable behind the contacts for the faceplate. It gets folded as the face plate motors in and out and eventually breaks like mine did. I'm fixing it tonight and then I will disable the motorization. Followed by NEVER BUYING A PIONEER AGAIN. I reccomend you do the same.
Aug 05, 2009 | Pioneer DEH-P780MP CD Player
How to put my car radio on mp3 mode
guy's hit the nail writh on the head.I just saw that there was a few guys wuth the same problem and fixed it at FIXYA. Thanks alot MAX.
May 16, 2009 | Pioneer Premier DEH-P480MP CD Player
DEH-P9600MP not working
make sure our face plate goes in good snap in take a q-tip clean contact from radio to face plate hope its that cheers
Jan 19, 2008 | Pioneer DEH-P9600MP CD Player
Car Audio & Video Logo
27 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
