Question about Sharp Aquos LC-37GD6U 37 in. LCD HDTV
The voulmn goes down to zero by itself and remains there for a few minutes. then i can use remote to raise volumn
    Problem Solver:
  • 9 Answers
Well, I'd make sure that there are no remotes in the vicinity or that their batteries are removed and then let the TV run to see if it still happens. If it still happens after the remotes have been removed from the equation, then you are probably dealing with a stuck button on the TV or a prankster.
Posted on Jun 26, 2013
My tv volume keeps lowering to zero remote control can raise it but then goes down again. ??
The TV has a chip inside it that controls the volume functions. It clearly has failed and will need replacing. If you can service the TV yourself and it is a modern type with just a few PC Boards. You can follow the speaker wires to one of the boards and replace it. Otherwise take it to the repair centre.
Aug 24, 2017 | Televison & Video
RCA Stav-3880 turn stereo on goes to full volumn
Take the batteries out of the remote control, then apply a piece of black tape over the IR sensor, Unplug the power, wait a few minutes, now power the unit back up, does the unit still have the same volume high symptom? If so, remove the tape and see if the unit responds to any other commands(other than volume) from the front panel. If it responds to the panel controls, the processor is most likely good. very seldom is the IR transistor bad, if it is no input command will work.
Feb 15, 2014 | RCA Optimus/Stav-3880 Rcvr Parts - Board -...
Tv volumn
Are you using another remote for the guide? Like the cable box remote? If that is the case then the remote could be sending a signal to the cable box that is the same as the signal used to adjust the volume on the television.
Apr 30, 2013 | Boston Acoustics TVee Model Two TV...
Descaling process counts down on the displat but no solution is running through the unit and thr counter stops on 1 min remaining
This is normal behavior, your machine is fine.
For example, the machine says "5 minutes remaining" and then it goes 5:00, 4:59, 4:58....etc all the way down to 4:01.Then it changes to "4 minutes remaining". Which is 4:00, 3:59, 3:58, etc.
So at "1 minute remaining" the machine is really at 1:00, then 0:59, then 0:58 and all the way down to 0:01.So, after the "1 minute remaining" goes away, the machine is actually done cleaning itself.
May 08, 2011 | Miele CVA 4066 Stainless Steel
Volume automatically decreased to zero and won't go back up.
Plug the audio out to check it isn't the speaker itself failing. I suspect it is the audio circuit section of the board. But a few times I have experienced the speaker unit circuit where the magnet is caused the problem. So using an external speaker helps to determine speaker vs circuit
Thanks for using FIXYA
Oct 11, 2009 | Samsung HP-R4252 42 in. Plasma HDTV
Volumn inop,remote inop
sounds like the vol down button has stuck try agitating it ..good luck farr64
Apr 29, 2009 | Symphonic ST420FF 20" TV
Tv reacts very slow
the problem is due to the crystal which sets the speed of the processor and it may be dry due to heat if that crystal is replaced or dry soldered the problem can be solved
Jun 27, 2007 | Philips 60P8341 60" Rear Projection...
Sharp Aquos LC-37GD6U 37 in. LCD HDTV Logo
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
