Question about Nova Development Business Card Factory Deluxe 4
When I put the cd into the cd drive it did not start automatic. So I need your help to Installed it, so I can start making my Business Cards.
  • Nova Develop... Master
  • 2,878 Answers
Auto play may be deactivated. Just right click on the drive letter with CD inserted an choose auto play, setup, or even open the folder and run setup from there.
Posted on May 06, 2013
Where do I get the unlock code for Greeting Card Factory Deluxe 9 that I purchased for 49.95,?
1. Insert the disk
2. Goto the Start menu and click on MY COMPUTER
3. RIGHT-CLICK on the drive and then click or EXPLORE
This should open a folder for the disk. somewhere in there should be an .EXE file with SETUP in the title.
If the folder doesn't display the contents you may have a bad disk
More from the original author is needed: bought greetings card factory deluxe 9 on line have downloaded online...
Feb 20, 2015 | Computers & Internet
Yamaha CRW4260tx CD-RW drive Windows 8.1 driver
You're out of luck, Microsolutions went out of business long before the introduction of Windows 8.1. If this is a scsi drive, you will need the driver for the scsi card only. Once installed, the system will automatically pick up the drive during boot.
Jan 02, 2014 | Yamaha CRW 4260TX CD-RW Burner
Unable to install software on my computer I have windows Xp
mcdevito75 here, If your useing a cd the software may already be installed in the computer, click start the prgrams and see if software is already loaded. Lots of time the software you seek can be loaded directly form the software site on your computer.
Jun 23, 2010 | Avanquest Greeting Card Factory Deluxe 7.0...
Unable to install card studio 2009 has dvd-rom instead of cd-rom
Well, you have a couple of choices:
1) You can have a DVD installed in your computer. Usually around $50.
2) You can purchase a flash drive (thumb drive) of at least 4GB. Depending on the size of the files, you may need an 8GB. You can have a friend copy the entire DVD onto the flash drive. Then you can take the flash drive and copy the entire DVD from the flash drive to your computer and install the program or install directly from the flash drive. (It may auto start when you insert it into a USB port.)
If you install it from the flash drive you will probably have to insert it every time you run the program. If you copy the DVD to your hard drive you will not have to and it will run faster.
Thanks for using Fixya.
Nov 10, 2009 | Hallmark Card Studio 2009 Deluxe Full...
Can Windows 7 be installed on X05? I get ACPI incompatible BIOS and have updated to last known one. Please help!
The only issue i can see is if your your ram has not been updated since leaving the factory, you will notice from the tables W7 requires a min of 1GIG and your machine leaves the factory with 256mb(dependant on country possible) so check your ram. I run windows 7 on 2GB and its great, your machine will take 2GB. The Samsung X05 was released 2004 and the NVIDIA Geforce 4 should be fine. i would point out drivers and compatability but windows 7 so far is really good but driver support is crucial
hope this helps
Here is the requirements for Windows 7
Windows 7 minimum specs
  • 1GHz CPU
  • 1GB of RAM
  • 16GB of drive space
  • DirectX 9-capable graphics card or integrated chip (true of most releases 2002 and after)
  • BELOW YOUR MACHINE SPEC
  • MPN nx05tp8e0a/suk
    Key Features
    Laptop Type Thin and Light Laptop
    Use Corporate Business • Small Business • Business
    Processor Pentium M 1.5 GHz
    Installed Memory 256 MB (DDR SDRAM)
    Display 14.1 in. XGA TFT LCD
    Operating System Microsoft Windows XP Professional
    Mobile Technology Intel Centrino Mobile Technology
    Processor
    Processor Manufacturer Intel
    Processor Type Pentium M
    Processor Speed 1.5 GHz
    Motherboard
    Chipset Intel 855GM
    Bus Speed 400 MHz
    Memory
    Installed RAM 256 MB
    RAM Technology DDR SDRAM
    Max Supported RAM 2 GB
    RAM Speed 333 MHz
    Installed Cache Memory 2048 KB
    Hard Drive
    Hard Drive Capacity 30 GB
    Storage Controller Type Ultra ATA 100
    CD / DVD
    CD / DVD Type CD-RW/DVD-ROM
    Optical Drive Read Speed 24x (CD) • 8x (DVD)
    Optical Drive Write Speed 8x (CD)
    Optical Drive ReWrite Speed 8x (CD-RW)
    Display
    Display Tech XGA TFT LCD
    Screen Size 14.1 in.
    Display Max. Resolution 1024 x 768
    Video
    Graphic Processor NVIDIA GeForce4 440 Go
    Graphic Bus Interface AGP x4
    External Video Resolution 1920 x 1200
    Audio
    Audio Output Type Headphones • Sound card • Speaker(s) • SPDIF out
    Audio Input Type Microphone
    Operating System
    Platform PC
    Technical Features
    Expandability 1 x Type I/II PC Card Slot, 1 x Memory Stick Card Slot
    Expansion Ports 2 x USB 2.0, 1 x IEEE 1394a (FireWire), VGA out, RJ-11 (modem), RJ-45 (NIC), S-Video out
    Input Method Keyboard • Scroll Button • Touchpad
    Networking
    Networking Type Integrated 10/100 Network Card • Integrated Wireless LAN
    Data Link Protocol Ethernet • Fast Ethernet • IEEE 802.11b • IEEE 802.11g
    Modem
    Modem Type Fax / Modem
    Analog Modulation Protocol ITU V.90
    Battery
    Battery Run Time 2.2 Hours
    Battery Technology Lithium ion
    Dimensions
    Width 31.5 cm
    Depth 25.9 cm
    Height 2.4 cm
    Weight 2 kg
Nov 05, 2009 | Samsung X05 Notebook
I bought Greeting Card Factory version7 and can not install it because I don't have DVD. Please tell me how to get the CD verson (or what ever i need) I was pretty upset to find i couldn't install the soft...
The deluxe version comes automatically as a CD compatible disc. As far as I can tell, the normal version comes only on DVD. http://www.novadevelopment.com/products/Greeting_Card_Factory_Deluxe_7/default.aspx?gclid=CNiAqJ-BxJsCFR0SagodmmWhBA
Jul 07, 2009 | Nova Development Art Explosion Greeting...
I have the windows 2000, my sims 2 double deluxe is not starting
Its possible that the game is on a dvd and your computer only has a CD Rom drive. It should say on the front of the drive on your computer what it is.
Chipset is the video card inside the pc (Either ATI or Nvidia)
Mar 17, 2009 | EA - Electronic Arts The Sims Double...
Problem installing,deluxe version 7,greeting card
insert disk
click on MYCOMPUTER and then RIGHT-CLICK on the drive and then click or EXPLORE
This should open a folder for the disk. somewhere in there should be an EXE file with SETUP in the title.
if the folder doesn't display the contents you may have a bad disk
if it does and you cant find a setup program let me know.
is this the only disk you have had trouble with lately?
Dec 26, 2008 | Nova Development Art Explosion Greeting...
Install sound card and I lose the CD/DVD drive.
You may need updated drivers. Try downloading the latest drivers for your soundcard. If you are using Windows Vista make sure you download the vista drivers as most Windows XP drivers will not work with Vista. Hope this helps.
Dec 23, 2008 | LG GCC4522B CD-RW/DVD-ROM Combo Drive
Installatin problem xp
do you still have the other hard disk? Is xp installed there?
Then you can use the old disk as master and the new disk as slave disk.
Don't you have another hard drive? Then you just need your xp cd and put it in your cd drive. start computer and installation will automatically start. Make sure BIOS is set to boot from cd
if you need more help, just reply
Apr 04, 2008 | Computers & Internet
Nova Development Business Card Factory Deluxe 4 Logo
56 people viewed this question
Top Nova Development Computers & Internet Experts
David Payne
David Payne
Computer Links
John Hong
John Hong
Are you a Nova Development Computer and Internet Expert? Answer questions, earn points and help others
