Question about Nokia 1650 Cell Phone
350991/30/043994/9 mobaiel
Switch of no starit
After replacing pool pump # MPRA6F-148L no suction
The pump will only pump water, I assume after the work it's currently full of air?
Jun 05, 2013 | Sta Rite 1 HP StaRite Pump 15" inout...
When i turn the switch on the pump buzzes and wont start , then trips the breaker . Help .
Either the pump is seized or the motor start capacitor is open or blown. If you can spin the impeller with your finger it is most likely a start capacitor problem.
Aug 20, 2011 | Sta Rite 1 HP StaRite Pump 15" inout...
High Pressure: STARITE 1.5 hp pump designed to
It is a cartridge issue in my opinion. I dont recommend cartridges ... Sand is so much superior as a filter medial. If this is an option for you ... I recommend it. If not an option, you might be able to get a different type cartridge that will filter at a lower rate and not get as dirty as fast ...
Jul 31, 2010 | Sta Rite Max E Pro 1 12 Hp Up Rate...
I have a Starite pump but one of the wires is broke. I don't know where it belongs.I believe it's set up for a 220 line but would like to know if it could be changed to 115
On the pump tag there is a schematic of the electrical. one for low voltage and on for high voltage. look at the high voltage. the A and B terminals or for the wires in the motor. the lines in are for the white and black wires coming in from your power source.connect the lines in to the suggested terminals and it will power up.
The Pool Tech
Jul 14, 2010 | Sta Rite Starite Duraglas Inground Pool...
I turned my starite pump on and it just hummed for about 5 seconds then cut off. What could be wrong?
Your pump motor or impeller is seized. Disassemble the pump housing and check the impeller to see if it spins freely. If not then check for debris, if impeller appears to be free of debris, then check the shaft seal and motor. If the shaft seal is leaking water, then the motor bearing is likely rusted and will need to be replaced. There are 2 bearings, replace them both along with the shaft seal
Apr 11, 2010 | Pentair STARITE PUMP HOUSING / TANK BODY
Removing a staRite pump
a picture on how 2 remove sta rite , remember to prime the pump after any repair !.. the shaft seal used on this pump is a 100 or a 200 . i use pac seal mechanical shaft seals cost about 10$.. go kits are not required on 90 % of repairs $$
Apr 13, 2009 | Sta Rite GO-KIT-6 Sta-Rite P2RA DuraGlas /...
Low water flow
sounds like air is trapped in the system somewhere. that is why any pump will surge. check the lines going in to make sure it isn't sucking air somewhere along the way and make sure the discharge line is clear so it can pump out fully.
Jan 22, 2009 | Flotec Simer/Flotec/Omni 2105 Swimming...
Nokia 1650 Cell Phone Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
