Question about Microwave Ovens
Sharp carousel microwave model no.R6261 manual
Where to get and how to change the oven bulb
MicrowaveSvc
  • 9098 Answers
SOURCE: User's Manual of Sharp Microwave Oven Model R-9H56
Found this posted under Whirlpool instead of Sharp, but I'll be happy to answer it here.
While that one may not be available, we have one that may be close enough to work:
http://www.microwavedisplay.com/r9h66_r9h76_r9h84b_r9h94b_om.pdf
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Dec 17, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: R-4H84 Sharp Carousel II microwave oven stoped working
A microwave can be dead for many reasons.
The fuse is normally located on the floor of the chassis behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
Posted on Jun 23, 2008
SOURCE: Where is the light bulb in an old Sharp Carousel Microwave?
Microwave_svc's site is awesome! I was able to get all the help I needed for a similar Sharp Carousel microwave. My bulb was simply loose in the socket base causing intermittent bulb lighting. Microwave_svc's helpful links got me to the service manual and, along with a nice set of "tamper-proof" screw compatible TORX bits I bought at HarborFreight, I was easily able to get cover off, remove bulb socket, tighten bulb, re-install bulb socket, button unit back up, and, voila, the light now works without intermittent blinking. FIXYA!!!!
Many thanks to guru microwave_svc!!!!!!!
Posted on Oct 13, 2008
fieldy14
  • 456 Answers
SOURCE: Looking for instruction manual Sharp \carousel
if you google the model number and the brand you should be listed with a series of sites that supply manuals, service manuals, etc.
Posted on Aug 16, 2009
pgh_pa_guy
  • 2992 Answers
SOURCE: Built-in Sharp Carousel II Microwave Convection Oven died.
There are a couple of safety thermostats in the oven to shut down power if something overheats. One is on the magnetron tube (the microwave source), the other is on the cooking cavity. These sometimes go bad. There's also a power line fuse that may have failed, or become loose in its mounting clips. These can be tested with an ohmmeter; they should all measure very close to zero ohms if they're good.
Another possibility is that the control circuit board in the oven may have failed. I have worked on several Sharp ovens where the power transformer for the board has gone bad for no good reason. If the board goes bad the oven may appear to be dead as well.
Microwave servicing is best left to professionals. If you're thinking of keeping this one, take it to a service shop (or call for home service) and get an estimate. Then decide whether to repair or replace.
Hope this has helped a little. Thanks for using Fixya!
Posted on Feb 02, 2010
Testimonial: "Thank you. I will check it out and then decide whether to repair or replace."
What light bulbs are for a Sharp R-1502 carousel microwave?
Hi,I would try (www.espares.co.uk),you can put the model in and it should give you the right lamp for your microwave,all the best.
Feb 05, 2018 | GE Microwave Ovens
HOW DO i CHANGE THE BULB IN MY SHARP R-651ZM MICROWAVE OVEN
Changing the light bulb on your Sharp carousel microwave will allow you to have needed light inside the oven. Microwaves are not designed for consumers to change the light bulb due to manufacturer liability, but it can be done. Following the proper steps will ensure a successful installation. Step 1 Unplug the Sharp carousel microwave from the electrical outlet.
Step 2 Locate the screws around the outer cover of the Sharp carousel microwave and unscrew all the screws.
Step 3 Lift off the covering.
Step 4 Locate the bulb and unscrew. Screw in your new bulb.
Step 5 Replace the cover and screw back tightly. Once done, test your new bulb.
Oct 10, 2017 | Sharp Microwave Ovens
User manual for 1200 w carousel ser# 57088
Free Sharp Microwave Oven User Manuals ' ManualsOnline ...
kitchen.manualsonline.com > ... > Sharp > Kitchen Appliance Sharp
Products 1 - 50 of 359 - Sharp Microwave Oven 11452 User Guide. Pages: 0 Saves: 0 ... Sharp Operation Manual Microwave Oven R-308H, R-305H. Pages: 0 ...
Free Sharp Convection Oven User Manuals - Kitchen .
Nov 15, 2015 | Sharp Microwave Ovens
Get a replacement bulb for sharp carousel microwave table top oven .
A quick look at the manual doesn't specify the part #. It just says replace with the same type and not more than 30 watts. http://www.sharpusa.com/downloads/archives/product_manuals/mic_man_r1500_1501.pdf
Here is a link to an online parts place that you can enter with your model #:
Replacement Sharp parts Select from 266 models Microwaves
Dec 08, 2014 | Sharp Microwave Ovens
How do i change light bulb in sharp carousel R-320HQ microwave oven?
open cover and
change bulb
before open it turn off woven at last 30 minutes
Jan 30, 2011 | Sharp R-320HQ Microwave Oven
User Manual Needed for Sharp Carousel Microwave Model R-303CW
mcdevito75 here, Best Bet, contact Sharp online, try sharp microwave oven.com Or in any store that sells Sharp microwave ovens get contact info off that package.
Jul 07, 2010 | Sharp R-303CW Convection / Microwave Oven
Sharp Microwave Oven Model R-403kk-T
Are you talking about the light inside the microwave? The front vent I think will allow you to get to the bulb. Should be a couple of small scrrews holding the vent cover on, remove them take vent off. Start it up again and see if the light bulb wiring or socket is arcing
Sep 16, 2009 | Frigidaire FMV156EM Microwave Oven
Hi our Sahrp Carousel microwave LCD panle display is not working
You have to replace the control board. Sharp has had problems with the display boards for awhile. There is no bulb or fuse you can change.
Mar 15, 2009 | Sharp Microwave Ovens
Nov 21, 2007 | Sharp R-510HW Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
