Question about Panasonic SD-2501WXC Automatic Breadmaker with Nut & Raisin Dispenser & Gluten Free Program
Warm up time
How long does it take to warm up the Panasonic SD-2501? New machine today!
    Genius:
  • Panasonic Master
  • 1,280 Answers
Many bread machines don't start kneading right away. That is especially true for the whole wheat cycle. Some bread machines take up to 1/2 hour of gentle warm-up of the heating element before the machine begins to mix and knead. Also, I have written a novella of myth, suspense, and
mystery........ just Google my full author name:
Daryl Wayland Nash
The story is set in a small town near Taos, New Mexico. The famous Taos hum has stopped. The local populace is unaware this ancient
geological phenomena serves as the time clock for a dark inhuman terror. The cessation of the hum triggers their
emergence. They have returned to seek prey for a terrifying purpose. Their prey is us. Little Emily Wilson knows that. Her mother is missing. No bad language, no Human-on-human
violence, but a suspenseful informative story of myth and mystery! I'm the
author. Daryl Wayland Nash on Amazon
Posted on May 03, 2013
The light and time work but the bread machine does move.
If this is your first time using the machine be aware that some machines warm the ingredients for up to 31 minutes before any mixing begins.
Dec 07, 2011 | Panasonic SD-YD205 Bread Maker
Bread makers is showing on display that it is on however the machine is not mixing the bread or heating up. Is this a bad burner or perhaps do I just need to tighten the burner?
Panasonic bread makers go through a lengthy wait period while they gently warm up before the kneading process begins. Give your machine about 45 minutes. It should have started kneading by then. Panasonics are just made that way.
Aug 20, 2011 | Panasonic SD-YD205 Bread Maker
I have a panasonic nn 2501, .You can set the time, hit start, the time will run , but the microwave does not run. What is up? Door safety switch? Thanks, VIC
you are setting the time on the microwave clock , your press the wrong button ,you can try just putting in the number of mins and press start, or theres cook then time and start. if helpful plz rate..
Jan 19, 2011 | Panasonic NN-S251 Microwave Oven
The dough doesn't seem to be mixed properly. I can see the yeast particles, the dough is tough and not-elastic. Doesn't seem to have risen. When I put it in a warm place to rise, it seems to rise a...
Hi, It could be that the paddle is sticking or the belt is slipping. This would cause the ingredients not to be mixed properly. Take the empty pan and paddle out of the machine and see if you can spin it freely by hand. It shouldn't stick. If it does stick then the sealed bearing is frozen and a new bread pan is needed. If everytrhing is fine, then check the belts. Belts and motor are located in base of the machine. Unplug machine before working on the belts. Hank
Nov 11, 2010 | Panasonic SD-YD250 Bread Maker
The paddle on my panasonic breadmaker has stopped turning. Without the pan the mechanism revolves but once the pan is in place the paddle does not move.
If you take the pan out of the machine and can't turn the paddle freely by hand, then the sealed bearing is frozen. You can try putting warm water in the pan and soaking it. After a few tries if it does not free up then the sealed bearing is broken and bread pan needs to be replaced. Good Luck..Hank
Feb 06, 2010 | Panasonic SD-YD205 Bread Maker
My new estate washer with 4 water selections actually only has 2, hot and cold. The warm water setting fills with lukewarm water for a while then shoots in cold water for a while and back and forth. In the...
Yes, this is normal. All newer washer have auto temp control fills. This is to meet energy saving requirements. The less hot water used the more energy saved. Most hot settings on washers give out basically lukewarm water. The detergent made today is made to work well with cooler temperature water, so things will still come out clean.
Feb 01, 2010 | Whirlpool Estate TAWS750PQ 27-Inch Washer
When making dough, should it come out warm at the end of the process?
Yes, warm but not too warm that you can't lift it out to knead it. I beleive that the heat is part of the rising process for the dough. If you make it by hand you need to leave it to rise in a warm spot.
Apr 15, 2009 | Kitchen Appliances - Others
My printer takes a long time to warm up between uses.
Only the way to solve this problem is to change new flourescent lamp. I have encounterd it before and solved by changing flourescent lamp. But to change the lamp is a bit complicated job.
Nov 12, 2007 | HP LaserJet 3330 All-In-One Printer
Panasonic SD-2501WXC Automatic Breadmaker with Nut & Raisin Dispenser & Gluten Free Program Logo
190 people viewed this question
Top Panasonic Kitchen Appliances - Others Experts
Irene Tulloch
Oloyede Monsuru
Are you a Panasonic Kitchen Appliances - Other Expert? Answer questions, earn points and help others
