Playing street fighter i can go in every diretion fine but when i jump back it will only register the walk back or jump up. i ordered some parts but dont even know if the will work
mine just started doing the same thing only right + down angle not working I suspect it needs new zener diodes on either the down or right directions or its just the chip that transcodes the input signals.mine just started doing the same thing only right + down angle not working I suspect it needs new zener diodes on either the down or right directions or its just the chip that transcodes the input signals.
You can't post conmments that contain an email address.
Mine doing the same thing its either a bad zener diode or the transcodeing chip is dead I will let ya know if I figure it out if not I will probably graft in a wired controller pad directly to the buttons.
There is one of 2 problems that you might have with this error. Ether you need to install/reinstall DIRECTX on your computer. You can download it from this link.
If this does not work then the problem is most likely the video card in your computer does not support the level of DIRECTX needed to play this game and you will need to upgrade your video card. If you look on the side of the game box it will tell you what the hardware requirements are to play this game.
Let me know if you have any more problems or questions
make sure there is the directx is installled and updated...
(you can install it from internet..)
also make sure your pc has graphics requirements for the game...
make sure the directx driver is active in device manager..
Video card might be broken, might be able to replace for about $110. If the game is Street Fighter 4, press start rapidly to skip intro and don't play Arcade mode. Can only save using auto-saves after challenges.
In the tachometer there is an integrated circuit that gives out of it 3 cables.The bike will not work without this IC plugged on the main clock's harness.
