Question about Acer S202HL LCD Monitor
Acer flat screen monitor
Getting no signal message. checked cable, turned computer off and turned monitor on then computer back on, tried sequence several times still no signal. the monitor isn't ever a year old yet help
    New Friend:
Acer monitor v193hqv power supply regulater ic burn so iwant circuit or ic no part no ic 802 problem plse solution
Posted on May 03, 2013
Riziel
  • 116 Answers
SOURCE: monitor goes black
Sorry to have to tell you this, but this is common in LCD monitors. The reason that it is going black when it boots is for one of two reasons. You either have a bad power supply that powers your LCD or your LCD's backlight is blown. These can be repaired or you can purchase a new one. But if it goes black 9 times out of 10 is because the backlight is bad. These can be repaired!
Posted on Nov 26, 2007
SOURCE: ACER AL 1716
I had one with the same problem. All the capacitors in the power supply were fried. If you're good with electronics, you can pull it apart and replace them (about 8 bucks in parts) or take it to someone who is.
Posted on Nov 12, 2008
  • 47 Answers
SOURCE: Monitor comes up shows "acer" then says no signal and goes black
The interface between the monitor and the cable might need replacement. Please check it.
Posted on Jan 12, 2009
  • 408 Answers
SOURCE: why do I get a "No Signal" on my Acer x193w monitor?
sounds like a video card issue.  Check the screen on another computer.  If it is doing the same thing, it is the monitor.  If it doesn't, then you have a video card issue
Posted on Mar 06, 2009
SOURCE: Acer X223W monito won;t wake up after sleep.
I have a dual monitor system, both are the x223w. Same problem but only on the second monitor. Backlight shuts off.On/off light stays blue. I have to turn off the monitor and turn it back on. I returned it and Acer could not find any problem so I got it back. No problem for awhile and now a few times over the past couple days. Not good...
Posted on Jan 07, 2010
Dealing with a Planar PL1700-BK computer monitor. When power is supplied, the "no signal" box flashes, then the screen goes black. When hooked to laptop, screen shows desktop, then goes black.
Planar PL LCD Monitor Fix - MarsBox.com
marsbox.com > Blog > Howtos
Nov 3, 2008 - Planar PL LCD monitor has flashing power led with no image. ... You will know it worked if the monitor diplays "No Signal" message when ...
What is the method to reset the Planar 1910m monitor?
superuser.com/.../what-is-the-method-to-reset-the-planar-1910m-monitor
Apr 6, 2010 - My monitor (a Planar, apparently model number PL1910M) is not working. (It is flashing a green / orange sequence which I believe to be an error code. The sequence, in ... I wasn't even seeing a "no signal" message and I couldn't turn it off using the power button. ... Computer resets when put under load.
ViewSonic VX922 monitor - black screen - green power light flashes ...
www.tomshardware.com > Forum > Displays
Tom's Hardware Guide
Feb 1, 2008 - 50 posts - ‎27 authors
Repair ViewSonic VX924 LCD Monitor Blinking Green power Button ... cant switch back & forth to desktop out of some games without the monitor going .... Nothing else on the board looks bad, the power supply board is dark brown ... to this madness we are unfortunantly dealing with daily with our monitors.Missing: planar ‎pl1700
Jan 05, 2016 | Planar PL1700 17" Flat Panel LCD Monitor
Monitor no signal acer M1640
Check the cable at the back of the monitor and at the back of the computer. If the cables are in tight and you still get the no signal error message you either have a bad monitor or a bad video card in the computer.
Try plugging another monitor into the computer (borrow one from a friend, neighbor or family member if you don't have one). If the monitor does the same thing and shows a no signal message like your original monitor, then the Video Card in the computer is bad. If the monitors works, then your original monitor is bad.
May 02, 2012 | Computers & Internet
I just installed a Acer S211HL LCD monitor. All my connections are tight. I get a No Signal on screen and monitor goes off. what the proble?
If you get a no signal message then check your video card, if the monitor gets no power at all then try replacing the cable, try a different outlet, if none of those work then the monitor is defective.
Mar 04, 2011 | Acer Computers & Internet
Screen will not stay on, getting message no input signal
The message input signal means no signal is being feed to the monitor.
Check the cable use to connect the monitor to the video card.. fix and secure the connection.
If the computer is reading and you know its working, check the video card.
Turn off the CPU disconnect the video card from the motherboard and reconnect.
Try to open your CPU and see if it reacts with your monitor. If nothing happens replace your video card
May 18, 2010 | HP Vs17 17" LCD Flat Panel Monitor
My monitor will not go back on. There is a green light blinking
Hi ,
In order to isolate whether its the monitor or the compurter tower you can do a self test to check if the monitor is fine .Turn the computer off and then disconnect the cable for the monitor from the back panel of the computer tower.It will be a blue connector with screws on it .Undo the screws and then disconnect it then turn the computer on ,if the monitor is fine you should get a message that would say check input signal or you will have some kind of message on the screen that tells you that the data cable to the monitor is not connected.If u dont get any message that simply means that the monitor has gone bad and needs to be replaced...
hope this helps you .....all the best
May 12, 2010 | Acer AL1916W 19" LCD Monitor
ACER AL1716 - no signal Whenever i turn my monitor on i get the no signal message. Why is this?
make sure the monitor is turned on, if yes check the signal cable of your monitor
Dec 21, 2009 | Acer Computers & Internet
Black screen on my Acer 203wbd monitor. Keep getting No Signal message. Have checked all connections.
Try another monitor on your computer. If you get video with another monitor then you know that your original monitor is bad. If you don't get video with another monitor then you know its something with the computer.
If the computer is the problem. Try reseating the memory and CPU. and also make sure the computer has no dust or dirt in it. If you still can't get no video then the motherboard is bad and would need to be replaced.
May 31, 2009 | Acer Computers & Internet
No signal message on screen while working
what type of connection to the monitor are u using
Jan 02, 2018 | Acer X241Wsd Monitor
LCD projector no signal message
Usually means that the computer is not sending a signal out the the projector via the monitor cable. Most Windows based laptop computers allow you to connect to a second monitor by pressing the Fn + F7 or F8 key, once to allow just the projector, twice to allow both the projector and laptop screen and three times back to only the laptop.
Feb 18, 2008 | Office Equipment & Supplies
Acer S202HL LCD Monitor Logo
347 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
