Windows boot manager my laptop cant log in missing somethong inside
  • 32,281 Answers
To repair missing or corrupted system file/s, boot up with the Windows installation CD then -
Press R to repair when instructed.
Press 1 or Enter to repair the C:\Windows folder.
Then type chkdsk /r and then press Enter.
The repair process will take quite a long time.
Posted on May 04, 2013
  • 252 Answers
SOURCE: boot manager is missing and wont load windows 7
If your using a DVD to install the operating system, it could be either dirty (just needs a wipe) or the files on the disk are corrupt.
If you are getting this error while Windows 7 is starting up perhaps you can try doing a "repair". Boot off the DVD do a repair (not from the recovery console) and see if this helps.
Hope this helps.
Posted on Nov 09, 2009
  • 3278 Answers
SOURCE: My Samsung i5 laptop does
Hello.
It's possible that your Master Boot Record is corrupted. To fix:
1. When prompted, boot from the CD drive by pressing any key. If Windows loads automatically, you will first have to enter the BIOS setup and change the order of the boot devices to start with the CD drive.
2. Once the setup loads, you will see the option to press R to repair a Windows installation.
3. Once the Recovery Console loads up, you will have to type in a number that corresponds to your Windows installation. This is normally just 1. Press Enter and then type in the Administrator password (no password, just hit Enter, unless you changed the password).
4. Now at the prompt, type in fixmbr. Your damaged MBR will now be replaced with a new master boot record and your computer should now be able to boot properly. Also run the fixboot command to repair the boot sector with a new one.
Hope this helps.
Posted on Jan 27, 2011
hunter19_46m
  • 7482 Answers
SOURCE: i need to upgrade my
Hi nquyentina17...
Try some of these solutions
Start your computer in the Safe Mode.
To start in Safe Mode.
Turn your computer on.
Keep tapping F8 while the computer is starting up
When the computer starts select Safe Mode
1. Uninstall any softwear you may have put on the computer before the problem started.
2. Do a complete System Restore: Start>All Programs>Accessories>System Tools>System Restore.
This will bring your system back to a time before you installed the softwear or Microsoft installed drivers,etc.
Note: Just be sure to use a date in a darkened box, that is before your trouble start date.
When you have done the above, restart the computer and if your still having the problem, then the installed drivers,updates,softwear,etc might have
corrupted the Operating System.
If that happened then that means either repair or reinstall the operating system.
You will need to do the following:
1...Repairing the Operating System...
A...You will have to have the Operating Dics that came with the computer.
Note...If you do not have the disks that came with your computer or the ones you should have made when you first got your computer...then you will have to go to the manufacture's webpage and see if they have a recovery disk available for your computer, if they do not a recovery disks available then you can also try ebay to locate the recovery disks.
The original disks will have your product key number that came with the computer, you can also find it on the tower, or under the bottom of your laptop, or maybe the piece of paper that the CD orginally came in may have the number on it.
You can also download a small program and it will tell you your product key number.
Go to the following webpage to download your FREE key finder.
http://www.magicaljellybean.com/keyfinder/
B...You will now insert the disc into the CD/DVD player
C...Restart the computer
D...When the window opens that tells you to press "Any" key, you will press any key you want to press.
E...If you do not receive a message that says "press any key to boot from CD", then then the computer is not ready to boot from a cd.
To correct this problem you will have to go into your computer's Bios and change the computer to boot from a CD.
To get into the Bios, shut the computer off,restart, while the computer is starting up keep tapping F1 as the computer is starting up.
When you are in the Bios, select to boot by CD by moving the cursor with the direction arrows on the keyboard.
Once you have selected to boot by cd the exit and restart the computer...the disc is already in the cd/dvd player.
Your system will then boot from the cd.
F...After a minute or less it should ask you if you want to Quit Repair, or Continue.
You will select Repair this time, but you may have to come back here and select Install if the repair does not work.
It will ok the agreement document if it asks you too.
Tap F8 on your keyboard to pass it when ready.
It will ask you if you want to Install, Repair, Delete Partition, or Quit.
Select Repair
Inside the box there will be one or two partitions.
Choose the largest partition.
After you have chosen the largest partition, you will then press the "r" key to start the repair
After the repair is complete, then you will need to restart your computer.
G...Computer Restart
After the repair is complete, shut the computer down (the computer will shut down a few times during the installation of the operating system
that is normal).
Then restart your computer, when the computer restarts it will have a box to put your product key...put the product key in the box and click.
The computer should start up and run as if it was a new computer.
You do not need to re-register
You can now remove the disc.
If this fails to clear your problem then you may have a hardware problem.
It could be faulty ram
If you still have the same problem, then you have two choices.
1.Reinstall the entire Operating System and you may have to update some drivers.
This will require you to go back to the start of the repair info and select Install instead of Repair.
2..Take your machine in to have the hardware tested.
Keep in mind that if you do a complete reinstall of the Operating System you will lose all the information on the computer,such as pictures, programs, videos, everything you installed will be gone.
Please take time to rate me four thumbs up
Posted on Sep 10, 2011
SUNILVOIP
  • 243 Answers
Hey Edward E. Hammett,
Thanks for being here with me.
Follow my tip here . i am sure you can do it. and if you succeed then review me.
Tip For Boot Manager Missing
Optional My Article Page just for Technocrats
Posted on Nov 25, 2011
jimjamjonny3
  • 42 Answers
SOURCE: how do I fix missing boot manager
There can be different causes for this problem:
If having reset the motherboard BIOS configuration, then check that the primary boot device is configured properly.
Posted on Mar 08, 2013
Iaccidentally locked my laptop and cant log on
Lost Windows password:
  • Login as Administrator. Try with no password (load safe mode if you don't see Administrator). Press F8 during boot to access Safe Mode. XP only.
  • Login as other user (if other user is available) and manage users. Must be an administrator.
  • Reformat computer.
  • Use 3rd party software to remove password. Like http://www.top-password.com/reset-windows-password.html
  • Free software option would be Hirens Boot CD. This one is command prompt only. http://www.hirensbootcd.org/ Must follow instructions exactly.
Dec 12, 2012 | Gateway Computers & Internet
Haveing problems with hp notebook 1100 boot mgr missing error while initializing NIC
Hi There,
I'm having trouble understanding what you mean by this - are you attempting to boot from LAN? Are you able to boot into windows at all?
What it sounds like is that your computer is either missing a boot manager, or you've assigned (in the bios) LAN boot as the priority boot device.
If that's the case, you can change the boot device priority back to internal hard disk in your BIOS (pressing F2 or F10 at startup splash screen)
If you're missing a boot manager for a windows installation, you can insert your windows installation disk and select "repair an existing installation" to repair your boot manager
Jun 06, 2012 | HP Computers & Internet
Says boot manager is missing
Try inserting the windows recovery disc and reboot the machine. At the language screen, bottom left, click repair your computer. At the recovery options screen, click on startup repair. This should recover the boot manager file. Reboot machine when completed.
Mar 22, 2012 | Acer Computers & Internet
Boot manager is missing
Nov 24, 2011 | Compaq Computers & Internet
When iam pressing the f4 it will show s boot manager is missing in samsung n150. how to create a recovery drive
try to run windows under f12 boot log restart computer push f2 now it will give you the option to change the boot formate with arrows on key board then restart computer push f12 then its going to be 2 option run the first then its going to ask you rerun windows rerun windows.
Feb 05, 2011 | Samsung N150 Netbook
Boot manager missing problem:
I successfully formatted my Toshiba Satelite laptop using the original recovery disks. However, when I try to restore it using the recovery disks, the systems gives an error message of BOOT MANAGER IS MISSING. The system doesn't recognize the recovery disks and I can not install (reinstall) the Windows Vista on the mechine.
Please help me.
Sep 15, 2010 | Computers & Internet
My notebook dont want to log on windows come up and ask normal but just start over again dont connect to windows
Hi, There is a possibility that the boot manager on the computer is corrupted or missing. What you can do is to do a repair install, it copy or install over the missing and corrupt files to make the computer work again.
Sep 06, 2010 | HP OmniBook XE4100 Notebook
Boot mgr is missing
Boot Manager is missing If the boot partition no longer can be found, then Vista will display the following error: BOOTMGR is missing. Press Ctrl+Alt+Del to restart
The Windows Boot Configuration Data file is missing required information
More Info MS KB 919529 More Info MS KB 927391 Check points for fixing missing boot-manager: Check that your boot device is configured properly Boot into Windows Recovery Environment (WinRE) and perform a "Startup Repair". Boot Manager is compressed If by accident having compressed the entire boot partition, then Vista will display the following error: BOOTMGR is compressed. Press Ctrl+Alt+Del to restart OR maybe try this first. Check points for fixing compressed boot-manager: Boot into Windows Recovery Environment (WinRE) and perform a "Startup Repair". If the above doesn't solve the problem then boot into WinRE again, but when selecting the Vista-installation, then press "Load Drivers" (Instead of "Next") and use the mini Windows Explorer to right-click the boot-drive and deselect "Compress this Drive" and choose Apply to sub-folders and files. If that also fails then boot into WinRE again, and go to the "Command Prompt" and execute these commands: compact /U C:\bootmgr compact /U C:\ntldr If you for some strange reason have lost your Vista DVD, then you can also use a Windows 2000 / XP install CD and enter the recovery console instead and execute the following commands: attrib -c c:\bootmgr attrib -c c:\ntldr
Try start up in Safe Mode press F8. Choose Safe Mode, when at the choice window, to select either Safe Mode Desktop, OR System Restore, chooses system restore and choose a time before you had the "Problem" and follow instructions. This should get you back.
Feb 21, 2010 | Acer Aspire 8920-6048 Notebook
Failure to log on
Can you enter windows anyway? Safe mode or something? If, try installing avast antivirus, and when it ask to after-restart system check, give yes.
If you cant enter windows, you can try to fix it with windows cd (changing boot in Bios to boot from cd). You can reinstall win, without loss of data too. But shortcuts will be missing. And another, you may use some rescue cd, if have one.
Mar 29, 2009 | HP Computers & Internet
Computers & Internet Logo
18 people viewed this question
David Payne
David Payne
