Question about Saws
Need manual for erbauer erb807a jigsaw - Saws
Erbauer mitre saw instructions
Thats a marketing technical problem to read or search for aftersales parts and other things for that brand . its difficult
Thread Don buy Erbauer tools from Screwfix
But a manual i have here for you by the first search link by free instructions manuals .pdf Google
Mar 17, 2015 | Saws
How to fit blade in performer 350w jigsaw
There is a blade release that you have to push up while inserting blade. If this isn't the problem, there are many types of blades for different jigsaws. You need the one for your brand. Take an old blade with you when you purchase. Good luck
Oct 18, 2014 | Saws
Erbauer erb ms10 mitre saw relacement drive belt supplier
I GOOGLE the saw and cam up with nothing. So, measure the old belt. Length and approximate width and Thickness. Go to grainger.com or similar company and compare. If you have a Napa auto near you they can measure and find one for you.
Aug 15, 2014 | Saws
I need drawings or pictures to rebuild my Erbauer table saw ERB2504SE
Hi I own an erbauer ebr2504es also. I am now reaping the benifits of buying a low end piece of kit.I am realy interested to know where you got your motor repaired, as I cant seem to find anywhere.
Any suggestions would be helpful.
Many thanks.
Apr 07, 2013 | Saws
Manual for bosh pneumatic jigsaw need to rebuild a jigsaw
finally found it. go to "ereplacementparts.com" and on the left side click on Bosch tools. type in the number0607561118 and you can download a parts schematic for this tool. If I have helped you in anyway would you please vote accordingly and thank you.
Feb 11, 2011 | Bosch 7561118 Orbital Action Jig Saw...
Cannot remove blade as do not hve manual 4350FCT makita jig saw
Hello Aiden,
This Makita jigsaw does not use any set screw fasteners to secure the blade in the saw. It has a "tool-less" blade retainer, so all you need to do to remove (or install) the blades, is to twist the small knurled ring nearest the blade shank.
Be sure to unplug the jigsaw first and with the blade shaft fully away extended from the saw, (you can just pull it out by hand if needed) and then simply twist the round locking ring and then with your other hand, pull the blade out of the jigsaw.
I would suggest that you use a glove on the hand you're going to pull the blade out of the jigsaw with, as those blades can be very sharp with the jagged cutting edges, etc.
Here's a parts breakdown of the jigsaw, for your reference and for obtaining any replacement parts you might need in the future.
http://www.makita.com/en-us/Assets/images/Products/_PartsBreakdowns/PB_4350FCT.pdf
Makita doesn't have an owner's manual listed on their web site for this product. You will need to contact Makita directly to obtain a free replacement manual for your product. You can contact them at
1-800- 4MAKITA (462-5482) Hours: Monday through Friday 8am - 6pm (EST)
I hope you find this Very Helpful and best regards!
Dec 23, 2009 | Makita 4350FCT Top Handle Jig Saw w/...
Makita 4304T. jigsaw blade Do not know how to fasten it?
On the top of the Makita 4304T is a knob, (Top/Front)
This is the blade Installing Lever.
Viewing the jigsaw in the direction you would use it, the Installing Lever is turned towards the Right. Keeping it turned, you then install the jigsaw blade. Once you have the blade up in the Blade Holder, gently release the Installing Lever.
This is a PDF file of the Owners Manual for the Makita 4304T Jigsaw,
(From Makita - Products - Support)
http://www.makita.com/en-us/Assets/images/Products/4304T/owners_manuals/4304T.pdf
[Should the above direct link not work for you, this is Makita - Products -Support, and the download page,
http://www.makita.com/en-us/Modules/Tools/ToolSupport.aspx?ID=248
Left-click on Owners Manual next to the PDF file Icon]
Nov 04, 2009 | Makita Jigsaw Blade
Brought a table saw from ebay but no instructions how to build
Instruction manual here any help?
http://www.screwfix.com/search.do;jsessionid=XXJ1J3RFCCELWCSTHZPCFFI?_dyncharset=UTF-8&fh_search=erbauer+250mm&searchbutton.x=0&searchbutton.y=0&searchbutton=submit#
Apr 01, 2009 | Saws
Saws Logo
71 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
