Question about Lanzar HTG264 Car Audio Amplifier
I have a lanzar amp 1000w and there was no power to the amp. after changing all of the wires there is still no power. whats going on inside of it
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 49 Answers
Probably blown. Car audio places can test it for u. Maybe ur setup isnt right?
Posted on May 10, 2013
4 Suggested Answers
Duncan
  • 218 Answers
SOURCE: PROTECT LIGHT COMES ON WITH 2 SPEAKERS HOOKED UP
Go to this website page and see if any of this applies to your problem. http://www.caraudiobook.com/car_audio_amplifiers/car_audio_amplifiers.htm
Posted on Aug 12, 2007
  • 91 Answers
SOURCE: Not sure whats wrong with my LANZAR MXA242 AMPLIFER. Please help!
did you check the fuses on the side of the amp? put voltage meter on b+ should read 13v, take it to service center to have checked out, may have some prblems inside
Posted on May 05, 2009
djmaximus_87
  • 26 Answers
SOURCE: speaker wire colors
ITS ALL UNDER UR SPEAKER CABLE SIMPLE NEGATIVE GOES NAGATIVE . POSITIVE GOES TO POSITIVE K
Posted on Jun 04, 2009
Dropped me a red flashlight.The problem is ?
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty. Time to get yourself an old school Lanzar Opti Drive amp .A thumbs up would be greatly appreciated if this answer is helpful to you. dropped-me-red-flashlight-problem-shonxoarcym4awy4zl1imx4o-2-0.jpg Lanzar
Jun 26, 2011 | Lanzar Vibe 530 Car Audio Amplifier
What is wrong with my 1000w sony xplod amp?
need repairs on the inside usually when u see that fuse melt something else probably melted on the inside. something is grounding out the amp on the inside . get it checked
Jun 05, 2010 | Car Audio & Video
Car stereo w/ Lanzar amp
check rca wiring to the amp 2 c if it got pinched then try swapping radio with a known good unit if it still happens try swapping amps. or try un hooking the amp then chrank radio up n c if it still doz it if not its the amp.
Sep 26, 2009 | Lanzar 4CH 1000W VIBERANT AMP Car Audio...
I realy need help, pleas!!!
Your problem may be in your input rca connections not getting proper contact or in the wrong way , if the input is not rca lead and is hi end input,as in wireing off the back of your head unit to the amp it may be a short in the wireing, you will need to check all your wiring if so, also make sure all your earth leads are clean and are big enough to take the amp size.
May 27, 2009 | Lanzar 2H 1000W MOSFET AMP Car Audio...
May 03, 2009 | Lanzar MXA242 Car Audio Amplifier
Amplifier protect circut is on and wont shut off
ALL AMPS HAVE PROTECTION CURCUITS, U NEED 2 CHECK ALL YOUR WIRES THAT HAVE ANY POWER RUNNING THREW THEM, U PROBLY HAVE A PINCH IN A WIRE CHECK ALL UR CONNECTIONS.
Mar 20, 2009 | Lanzar 2H 1000W MOSFET AMP Car Audio...
Knocking noise with my kicker compvr 15"
comp VR 15s are rated @ 500W RMS 1000Peak.
The lanzar vibe amplifier is 2 x 600W RMS at 4 OHMS 2 x 1200W MAX at 4 OHMS 1 x 2400W MAX at 4 OHMS Bridged 2 x 1000W at 2 OHMS RMS.
Your subs are single 4 ohm subs.
If your subs are wired stereo, they both are seeing 600W. (more than the rated RMS)
Chances are, you have them wired parallel to a 2 ohm mono load - of which that amplifier is not rated. In theory, it will produce about 2000W @ 2 ohm mono for a short period of time.
Your amplifier is too powerful for your subs. Turn down the gain setting to 3/4 or purchase better subs. Also be sur the subs are inthe proper enclosure. It sounds as if they are excurting past their linear x-max and colliding with the rear bump plate. This will cause damage down the road if left as is.
Nov 26, 2008 | Kicker CompVR 05CVR84 Car Subwoofer
Audio bahn 1205n
sounds like your over working your amp 800 watt on a 2000 watt sub. might wanna upgrade your amp
Nov 28, 2007 | Lanzar 2H 1000W MOSFET AMP Car Audio...
Aug 11, 2007 | Lanzar HTG244 Car Audio Amplifier
Lanzar HTG264 Car Audio Amplifier Logo
Top Lanzar Car Audio & Video Experts
Chris Ward
Are you a Lanzar Car Audio and Video Expert? Answer questions, earn points and help others
