Question about Gilmour Group #Xp20gt Green Thumb 2 Gallon Tank Sprayer
Green manual sprayer thumb - Gilmour Group #Xp20gt Green Thumb 2 Gallon Tank Sprayer
Want to order part for Green Thumb Model 65221gt sprayer. Where do I find. Nothing online
Sorry we do not have parts locators services here. Suggest you contact the manufacturer.
Sep 11, 2017 | Garden
Why does my Green thumb .5 gallon sprayer leaks when pressurized?
sounds like your your rubber seals have worn out,or one has broken fully or you have not put it back on properly
Jul 18, 2014 | Green Thumb HD Hudson 79142GT Gt 2L Hand...
Manual for 60000gt sprayer
Go online to company, customer service.
Jun 05, 2014 | Green Thumb HD Hudson 60000GT Gt...
I am not getting pressure in the sprayer. Any suggestions?
Generally, the problem is either a leak or a bad pump. If you listen carefully and you hear air escaping try making sure the top is on tight (don't go nuts because you will never get it off again) Also many tanks have a gasket or O-ring under the lid. This is often lost or gets out of place, and then crushed by the lip. There is also a gasket or stopper thing at the bottom of the pump cylinder, sometimes this gets loose or gets a piece of stuff in it. It also could be the pump piston itself. HERE is the manual with a section on troubleshooting.
Be careful if you have used hazardous chemicals in it before.
Hope this helps, If it does please rate it.
Jun 18, 2011 | Gilmour Group #Xp20gt Green Thumb 2 Gallon...
How do i fill my hudson sprayer
On the link below page 2 will tell you how to fill your sprayer.
http://www.hdhudson.com/PDF_files/poly-sprayer-instruction-sheet.pdf
Good Luck and please rate 4 thumbs up for the free answer.
Jun 27, 2010 | Eliminator Hudson Sprayer - 1 Gallon,...
When I pump up the Green Thumb two gallon sprayer, air escapes from the top in the center by the pump handle. Also why must I add oil to the holes in the top?
You add oil in the two holes to lubricate the seals around the pump shaft. Maybe the seals have dried up now and that is why the air leaks by.
May 26, 2010 | Gilmour No 2pgt Green Thumb 2 Gal Ld Tank...
Replace 0-ring
all I want to know is how I can get a replacement o-ring ASAP without paying to discuss my needphone number and person to call would be helpful.
Mar 23, 2009 | Gilmour & Spray Doc& Poly Tank Sprayer...
Gilmour Group #Xp20gt Green Thumb 2 Gallon Tank Sprayer Logo
Top Gilmour Garden Experts
cackelberry
Level 1 Expert
Charles T Nevin
Charles T Nevin
Are you a Gilmour Garden Expert? Answer questions, earn points and help others
