Question about GE 29267GE3 Corded Phone
Manual es29267
How do i remove the the telephone cable in order to replace it? I cannot remove the cable from the back of the phone
Panasonic voice mail setup for model no. KX-TGA500W phone
Hello Lynda,
Trying to get the answer to turn off your BASE FEATURE...
KX-TGA500W appears to be a WIRELESS "remote"
handset that operates from your wired BASE...
A typical base will be KX-TG + (4 digits).
In ORDER to PULL an owners manual...
I am required to know the MODEL NUMBER of
your base station...
The ONE Panasonic PHONE that is connected with
a modular jack... (to the wall.. off to the central office
("CO")) and out to your friendly telephone network... via
telephone cables...
I need the BASE model number:
From thence I will be able to access your owners manual.
In the MEAN TIME:
I'd suggest that you PHONE HOME and let your phone
ring no less than 12 times... before you can say with CONVICTION... that you don't have VOICE MAIL.
It assumes a level of PHONE COMPANY
competence & skill... (I doubt).
Trust... but VERIFY.
I am here daily please comment me back... or repost your question with the BASE model number.
We can do this...
Carnac the Magnificent
Mar 20, 2017 | Panasonic Lands Phones
I have an HP 2510 printer. I cannot use it to fax because once I plug the phone jack into the printer I get a busy signal. If I plug the jack into a phone, it works fine. How do I get the printer to...
Hi irwinbadin,
HP fax products are designed so that other telephone equipment can be connected on the same line as the fax. The unit must be connected first using a two-conductor fax/phone cable like the one that shipped with the HP product. Using a four-conductor telephone cable may cause problems receiving faxes or calls.
There are two different types of phone cables. There are two-conductor phone cables like what originally shipped with the HP fax product and there are four-conductor cables. HP fax products are designed to work with a two-conductor phone cable. Look at the end of the cable and verify that it has only two copper leads or wires. Replace any four-conductor cables with a two-conductor cable. Only two-conductor phone cables should be used to connect the all-in-one to the phone line.
Figure 1: The difference between a two-conductor phone cable and a four-conductor phone cable
Step one: Connect the phone line to the fax
The fax will have two or three sockets (or jacks) for phone lines. Some of these may have a removable plastic plug in them. These sockets will be labeled with text, To Wall Jack , or with a graphic of the wall jack. See Figure 1 below.
Plug the two-conductor telephone cable that came with the HP product into the telephone wall jack. Then, plug it into this socket as shown below.
In areas with above ground telephone lines and electrical storms (lightning), it is a good idea to purchase a telephone line surge suppressor and connect it between the telephone wall jack and the fax. This will help prevent damage to the fax from a lightning-caused power surge on the phone line.
Step two: Add other phone-line devices
To connect other telephone devices, use the other socket (or sockets) on the fax. These are identified by text or with a graphic of a telephone and/or computer.
Connect a caller ID unit between the fax and the telephone.
Use the information below that matches the devices you need to connect.
Fax and telephone
Connect a single-line telephone to one of the added sockets on the fax. The telephone will share the same phone line as the fax. See the illustration below.
Fax, answering machine, and telephone
When a telephone answering machine and telephone are connected, connect the answering machine to the fax and then connect the telephone to the answering machine as shown below.
Fax and computer modem
To use a fax and a computer modem on the same phone line, connect the fax to the computer modem. The modem socket on the computer may be labeled Line or Wall jack .
Fax, computer modem, and telephone
To use a computer modem and a telephone with the fax, connect the computer modem to the fax. Then, connect the telephone into the second phone line connector on the computer modem or the third fax socket (if it is available). The image below shows how to connect a computer and a telephone to a fax with two sockets.
Fax, modem, answering machine, and telephone
The image below shows how to connect a computer modem, answering machine, and telephone to a fax. Connect the computer modem to the fax, then connect the answering machine to the computer, and finally, connect the telephone to the answering machine.
If the fax has three phone line sockets instead of two, some of the devices can be connected to the other phone socket on the fax.
Hope it helps.
Thank you for using FixYa.
Jun 27, 2011 | Office Equipment & Supplies
HP PSC 2210 - Printer sais: In conversation
Hi Pascal,
This looks to me like if the "fax" portion of the All-in-One was engaged.
Please try unplugging the telephone cable at the back of the printer.
Turn the printer off and then remove the power cable.
Leave it like this fro 10 seconds.
Reconnect the power cable and turn the printer “on”.
The message should have disappeared.
Now reconnect you telephone cable.
This might have happened if the printer “answered” te phone line and fro some reason it didn’t hang up.
Cheers,
Ed
PS1: If this worked for you, please com back and grade my answer.
You can also access the manual here:
English: http://h10032.www1.hp.com/ctg/Manual/c01176633.pdf
Dutch: http://h10032.www1.hp.com/ctg/Manual/c01176662.pdf
Nov 07, 2009 | HP PSC 2210 All-In-One InkJet Printer
Our AT&T 1725 has quit recognizing when the phone is ringing. The phone keeps own ringing instead of beign answered.
There are a couple of things to try. First is to check the cable & plug that connect the 1725 to the telephone line. Disconnect the phone line from the back of the answering machine, plug it into a known working telephone, using cell phone (or another land line) call the phone number and see if the phone rings.
If it doesn't, replace the line cord and try again.
If it does ring, check the optioning to make sure it is set for, say 2 rings.
Also, is the telephone line a regular telephone company POTS line or is it one that is being provided by a cable modem? If your phone service is being provided by a cable company, the media converter might not be putting out enough voltage for the answering machine to realize that the line is ringing.
If everything is correct, replace the answering machine.
Aug 18, 2009 | AT&T 1725 Answering Machine
GE MODEL 28112 DECT 6.0 CORDLESS PHONE
I contacted GE today and they told me how to get the caller ID to work on the additional handsets. You must follow these steps in the exact order given.
#1 - unplug the base phone
#2 - unplug the telephone line from the base phone
#3 - remove the battery packs from the phones
#4 - wait 10 minutes.
reverse the order when assembling. Put battery packs in phones, put the telephone line back in the base phone and lastly plug all phones back in. It takes about another 10 minutes after that before all phones start recognizing caller ID but it now works fine.
Mar 26, 2008 | GE 28112 Trio Cordless Phone
LUCENT 1872
Follow this link for your manual http://telephones.att.com/docMgt/public/art/175/1872_manual.pdf
Make sure you have adobe reader installed to view.
Hope this helps.
http://pchelpforanyone.blogspot.com
Mar 07, 2008 | Lucent 1872 Corded Phone
Caller ID Problem on the GE2811 Twin cordless phone system
How to get the caller ID to work on the additional GE DECT phone handsets. You must follow these steps in the exact order :
#4 - wait 10 minutes. reverse the order when assembling. Put battery packs in phones, put the telephone line back in the base phone and lastly plug all phones back in.
It takes about another 10 minutes after that before all phone handsets start recognizing caller ID.
Oct 23, 2007 | GE 28111 Cordless Phone
Display issue
This happens on our AT&T 962 & Lucent 965 telephones. The phones don't all do it at the same time and the only way to clear the trouble is to unplug the telephone, remove the batteries and then put everything back together again.
Oct 29, 2006 | Lucent AT&T 960 Corded Phone
GE 29267GE3 Corded Phone Logo
44 people viewed this question
Top GE Lands Phones Experts
Computer Repairing
Computer Repairing
Dudeman321
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
