Question about Garden
Lawnmower hosing for the pull cord how do i get it off
  • 18,409 Answers
Pull cord won't pull on Snapper 6.75 exi
HOW TO Replace a Broken Lawnmower Pull Cord - YouTube
? 5:53
www.youtube.com/watch?v=G02OobT7fII
Oct 4, 2011 - Uploaded by donyboy73 Easy to follow video tutorial on how to repair a broken lawnmower pull cord. The procedure for this lawnmower ...
Sep 21, 2015 | Snapper Garden
Starter cord on lawnmower will not pull out
Hi Mary. You will need to remove the starter box on your mower. The coil box may be rusty or the pully may need fixing. Try using some oil spray and see if the pully now works. If the starter coil is clean the mower may be ceased.
Jul 27, 2013 | Garden
Pull cord on my lawnmower is inoperative
You need to take the Starter cord assembly off and see if the Nylon gearing that 'grabs' the centrifical wings is broken OR those wings are rusted in a way that they do not make contact with the nylon piecs of the Starter.
Dec 07, 2012 | Craftsman 55 Torque 158cc 22" Push Lawn...
The lawnmower won t start after pulling the start up cord . changed the spark plug it still won t start
try a touch of starting fluid right into the carburator by taking the air filter off. If it then starts but wont run or stay running, the reservoir below the carb should be removed to clean at and the pinhole in the intake tube above the bowl nut. This is the most common problem with lawnmower start problems, the pinhole can be unplugged with one wire from a wire brush. Be careful with the gas, at least pinch off the gas hose with a vise grips while removing the carb bowl.. Never use a droplight around gasoline.
Jun 27, 2010 | Craftsman 675 Torque 190 cc 21" Push Lawn...
Craftsman Walk behind lawnmower
usually theres just a few bolts to take off on the top, and the whole rip cord assembly will pull right out, allowing you to install the new one.
Jul 09, 2009 | Yard Machines 158cc Push Lawn Mower #11a...
Lawnmower
what do you mean doesn't engage? doesn't start, doesn't let you pull, doesn't cycle, what?
Jun 08, 2009 | Mtd 22" Yard Machine Push Mower
Pullcord violently retracting on Craftsman lawnmower
It is possible that the 'dogs' that engage the crankhaft were stuck in the out (engaged position). Once the engine started, it wound the rope in the opposite direction until the dogs slipped and retracted. Romve the top cover that includes the pull start unit. Check for smooth and sticky free operation while pulling on the cord. Try using a very light oil to lube if nessesary.
Apr 29, 2009 | Sport & Outdoor - Others
Lawnmower Starting Pull Cord Replaement
There will be a piece of casing that holds the starter mechanism in. Usually held by 4 screws (probably torx screws unless it's an old machine).
Undo these screws and you will find the cord carrier inside.
Observe how the starter dogs are located, and how it all goes together.
You may be able to remove & replace the cord without taking the carrier off the casing, but it is probably easier if you do.
Then you simply remove the old cord, thread a new cord through the hole & tie it. Reassemble the carrier onto the casing. Thread the cord out of the casing & through the handle, tie that end.
Then wind the cord around the cord carrier until there is a slight tension on the spring.
Screw the casing back on the mower and you're away.
Sep 20, 2008 | Garden
Garden Logo
22 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
