Question about Mitsubishi VS-8087 80" Rear Projection Television
Mitsubishi tv repair
Takes a long time for picture to show and when it does very dark
How to Replace Color wheel of Mitsubishi WD-60638 Please guide me
Thanks
Lodhi
lodhi589@gmail.com
Posted on May 05, 2013
3 Suggested Answers
SD Tech
  • 14553 Answers
SOURCE: i was wondering if u know y my mitsubishi tv wasnt
This may be a model that has two mirrors. Mitsubishi could tell you if this is the case.
Some idiot had the bright idea to have optical unit shine picture into tiny mirror which puts it into large mirror in back; problem is tiny mirror if there is at bottom and facing up, dust or dirt get on it and picture brightness will diminish up to 70% or more.
If model you own does have two mirrors, the front of the set with the screens will have to be removed to clean it, not real hard and takes 15 minutes.
If you can confirm it has two mirrors I can tell you step by step how to remove screen unit and resolve problem. Usually if tiny mirror dirty it will happen over time, picture will gradually get darker and dull looking.
Let me know if want instructions, the set either has two mirrors or it does not.
SD TECH
Posted on Nov 03, 2010
  • 41 Answers
SOURCE: mitsubishi rear projection tv is too dark to see picture
This is a very common problem within your projection TV set there is a small red, green, and blue picture tube. On top of the tube there is a lens that focuses the video on the screen. Between the lens and the top of the tube there is a hollow chamber filled with a clear liquid. This fluid is specifically designed to keep the tube from overheating. After about 4-5 years the fluid will start to become cloudy and will will get worse over time. Tvrepairkits.com is a good place to get a repair kit to fix this condition yourself.
Posted on May 08, 2012
Mitsubishi rear projection tv is too dark to see picture
Dec 19, 2011 | Mitsubishi WD-62525 62" Rear Projection...
I was wondering if u know y my mitsubishi tv wasnt showing a clear picture i replaced the lamp with new one but it still shows a dark picture
SD TECH
Nov 03, 2010 | Mitsubishi WD-52725 52". Rear Projection...
I have a mitsubishi 60 inch tv model wd-60c9 and i purchased it this year ..aug 06 2010 and the picture has became very dark..i am using hdmi conection and purchased new and better cables..issue still dark
The tv projection lamp have problems,it shorting out some how.That why,u have a dim picture.Tries websites like Partstore.com,Ebay.com to buy a new projection lamp for the replacement.New tv,call mitsubishi for a warrenty repair.
Oct 18, 2010 | Mitsubishi WD-60C9 60" DLP HDTV
Dark pic on screen, unable to correct with regular means.
Regardless, my answer stands. It needs repair by a qualified technician. Rates vary by area. Make telephone inquires.
Jan 09, 2010 | Mitsubishi WS-55809 55" Rear Projection...
Picture is wavy, dark and displays only black, blue and red.
Yes, send to repair, the problem you are showing is not a big problem for any regular workshop. The tv needs now a regular "maintenance" some parts are old or some solder joints are old, in any sense a "good day of service" working this tv in the bench is not really expensive.
May 02, 2009 | Televison & Video
Dark picture problem
did you change the lamp with an original or bulb only - mitsubishi only sells the lamp and housing!!!
never use generic
Oct 06, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Vs-60607 brightness problems
This sounds like it is a problem with the tv. Mitsubishi does have a problem with filter caps in thier regulator circuits. A repair tech will have to fix it.
Mar 06, 2008 | Mitsubishi VS-60707 60" Rear Projection...
Picture is Rolling..stops after some warm-up
I have seen this many times. There is a 9 volt regulator on the small signal board that causes this. The regulator goes bad and the 9 volts starts dropping, especially at start-up when the regulator is cold. If the voltage is below 8 volts then the picture gets dark and the vertical becomes unstable, with the picture squeezing down and/or rolling. As the regulator warms up the voltage starts rising back towards 9 volts and the symptoms start clearing up. There are 3 regulators in a row on the board and the regulator in the middle is always the bad one. Replacing that regulator should cure your problems but it should be replaced by someone experienced in servicing Mitsubishi projection TV's because pulling the chassis out is quite tricky.
Aug 05, 2007 | Mitsubishi VS-45607 45" Rear Projection...
Ghostly vertical lines
you have done said it vertical lines then you will have to take your tv to a tech for repairs.good luck.
May 13, 2007 | Mitsubishi VS-45607 45" Rear Projection...
Televison & Video Logo
51 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
