Question about Samsung Bd-E8500 3D Smart Blu-Ray Disc Player With 500Gb Hdd And Built-In Wi-Fi New For 2012
Samsung Region Code - Samsung Bd-E8500 3D Smart Blu-Ray Disc Player With 500Gb Hdd And Built-In Wi-Fi New For 2012
Change Region Code Sumsung db-d 6500 AZ from Region Code A To B
You can't. Blu-ray region settings on Sony and Samsung models are not hackable.
Very few Blu-ray players from any manufacturer can be region-hacked, although on many the DVD region coding is often hackable.
Jul 06, 2011 | Samsung Televison & Video
Samsung dvd-85k unlock code
Samsung DVD-V8500K
1. The player should be powered on, the tray closed without any disc inside, the logo "DVD Video Samsung" visble on screen and the message No Disc must have already appeared.
2. Press the "Subtitle" key on the remote - "No Disc" should disappear.
3. Using the remote control, key in the code
"5, 3, 8, 1, 4"
4. A number should appear - this is the player's region number that was last programmed.
5. Press the number of the region you require, or 9 for region-free.
6. Press the "Subtitle" key on the remote - region number should disappear.
7. Press Standby on the remote control.
NOTE:
Origin of this player is Region 5 so it`s a default setting
If code "5, 3, 8, 1, 4" doesnt work try this codes:
Region 1 - 2, 9, 3, 3, 4
Region 2 - 3, 8, 7, 6, 7
Region 3 - 5, 6, 7, 3, 2
Region 4 - 7, 6, 8, 8, 4
Region 5 - 5, 3, 8, 1, 4
Region 6 - 2, 4, 4, 6, 2
please rate me. its most helpful
Nov 07, 2009 | Samsung DVD-V85K DVD Player / VCR Combo
Problems changing region code on Samsung DVD player VR 375
HELLO!
Give these a try!
Power ON
Press MENU
Enter code 57538
The current region code appears
For codefree/multi-region press 9
Press Open DVD door button
Power OFF and power ON
You could also try this!
Turn player on without disc inside Press MENU button
Enter your region code (See list below)
Highlighted 'region area number' will appear in the upper-left corner (on some players)
Press 9 to multi-region the machine
Turn machine off
Region 1 - 29334
Region 2 - 38767 (or 5 7 5 3 8)
Region 3 - 56732
Region 4 - 76884
Region 5 - 53814
Region 6 - 24462
Have a go and good luck! (:-)
Sep 11, 2009 | Samsung DVD-VR375 DVD Recorder/VCR
Multi region code for samsung dvd 5500
um there is a reason why there is differ region dvd's...no player will play multi unless u buy it that way....best bet is to convert your wrong region dvd's to non region
Dec 02, 2008 | Samsung Televison & Video
Region free code for Samsung RTSHE10T
Multiregion sansumg
Turn on
Press the repeat button
  • for Region 1 use 2, 9, 3, 3 and 4
  • for Region 2 use 3, 8, 7, 6 and 7
  • for Region 3 use 5, 6, 7, 3 and 2
  • for Region 4 use 7, 6, 8, 8 and 4
  • for Region 5 use 5, 3, 8, 1 and 4
  • for Region 6 use 2, 4, 4, 6 and 2
Press 9
Press Repeat Button
Turn off and on again
Nov 14, 2008 | Samsung DVD-V4600 DVD Player/VCR
Samsung code
1. Cold start the player, by holding down the PLAY and STOP buttons on the player.
2. You should see a set of language options. Release the PLAY and STOP buttons.
3. Select your language.
4. Press REPEAT (not the repeat A-B button) then the following codes for the required region the player is already set to (region you bought the player in):
5. A code will appear, indicating the region setting of your player.
6. Press 9 for region-free, or 1 for region 1, 2 for region 2, etc.
7. Press OPEN on the Player to open the disc tray.
8. Press STANDBY (POWER) on the remote control to close the tray. Next time the player is turned on it will set to the region specified.
Jul 05, 2008 | Samsung DVD-P244 DVD Player
Multizone code
icon_minipost.gifRegion code hack posted by Tiger1, May 24 2007:
Hi I live in Australia and added this model.
acknowledging: Region code hack posted by ZoidsGodzilla, November 22 2006: for the Samsung DVD-V5600
1. Press the DVD button on your remote (the Samsung logo appears)
2. Press the SUBTITLE button on your remote
3. With your remote enter the code: 76884
4. The current region is displayed on the top left corner of the screen. (e.g. 4)
5. Press 9 on your remote (Region free)
6. Again press the SUBTITLE button on your remote
7. Enjoy the Region free player
If your player is NOT Region 4 by default then you will need to Substitute the Numbers in Step 3 with the ones Below.
Region codes:
RC 1: 2, 9, 3, 3, 4
RC 2: 3, 8, 7, 6, 7 (or 5, 7, 5, 3, 8 )
RC 3: 5, 6, 7, 3, 2
RC 4: 7, 6, 8, 8, 4
RC 5: 5, 3, 8, 1, 4
RC 6: 2, 4, 4, 6, 2
For Example if your Player was Purchased in the usa ( Which is Region 1) then Step 3 would read :-
3. With your remote enter the code: 129334
Have Fun :0)
Mar 25, 2008 | Samsung DVD-V6700 DVD Player/VCR
Samsung Bd-E8500 3D Smart Blu-Ray Disc Player With 500Gb Hdd And Built-In Wi-Fi New For 2012 Logo
20 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
