Question about HP DesignJet 750c plus InkJet Printer
System error 010060 - HP DesignJet 750c plus InkJet Printer
Error 010032 00070b18
SYSTEM ERROR 010060 is a Primer Motor sensor problem, Sensor might be bad, motor might not be turning, cable could have failed, or main PCA might be bad.
070020 Is a drop detect sensor error, the sensor is part of the service station.
The check cartridge path indicates that the carriage rails need lubrication, use a light silicone or synthetic lubricant, (it could be other things, but this is the most likely), you also might need to replace the belt.Hope It's resolve all Your Printer Problem,
Or Still having Problem Then follow Us For
HP Support
May 08, 2014 | HP DesignJet 750c plus InkJet Printer
Generac 010060 mf6500
THERE SHOULD BE A BOLT ON THE BOTTOM OF THE OIL SUMP THIS SHOULD BE ON THE SIDE TOWARD THE BOTTOM IT WILL LOOK LIKE THE COLOR OF BRASS TURN THE BOLT TO THE LEFT TO TAKE OUT LET THE MOTOR WARM UP BEFORE TAKING THE BOLT OUT THIS WILL THE OIL TO WARM UP. DRAIN THE OIL OUT AND REPLACE THE PLUG DONT OVER TIGHTIN THE PLUG . REPLACE THE OIL WITH 30 W OIL FOR SUMMER USE I HAVE A 10W 30 ALSO THIS WEIGH IS FOR SUMMER USE. USE A LIGHTER WEIGH OIL FOR WINTER USE.PLEASE TAKE OIL TO A RECYCLE PLACE . ALSO DONT OVER FILL THE MOTOR WITH OIL.
Jan 02, 2014 | Generac Electrical Supplies
Startup 6 beeps
Probable Causes
Error
Beep Codes
Defective system board.
Memory refresh failure.
Faulty DIMM or defective system board.
Error occurred in first 64 KB of main memory.
Faulty DIMM.
Read or write error occurred in first 64 KB of main memory.
Timer on system board malfunctioned.
Defective microprocesor.
Microprocessor error.
5
Gate A20 failure.
6
Defective microprocessor.
Microprocessor-execption interrupt error.
7
Missing or faulty video adapter.
Video memory read/write error.
8
Corrupted system BIOS program or defective system BIOS chip.
ROM checksum value does not match value encoded in system BIOS.
9
NVRAM shutdown register read/write error.
10
Defective microprocessor or cache card.
Cache memory error.
11
Faulty video adapter.
Video adapter failure.
12
Loose video cable connection or defective video cable.Faulty video adapter.
No monitor connected.
13
May 15, 2013 | Samsung NP-148 NP-150 N148 N150 N128 N145...
Long beep at startup
Probable Causes
Error
Beep Codes
Faulty DIMM.
5
Gate A20 failure.
6
7
8
9
10
Cache memory error.
11
12
13
14
May 09, 2013 | Lenovo 3000 N100 CoreDT2080 VB PC Notebook
Dell 4 beeps
POST Beep Codes
How to fix Dell BIOS 8 beep error.
Probable Causes
Error
Beep Codes
Faulty DIMM.
5
Gate A20 failure.
6
7
8
9
10
Cache memory error.
11
12
13
14
May 09, 2013 | Dell Inspiron 1018 Notebook
My computer has a critical error on the adress 0x3BC3, how do i solv it?
It might be a fake error message. Use this code 754-896-324-589-742 to unlock your computer. More information about this infections:
http://deletemalware.blogspot.com/2011/07/system-process-at-address-0x3bc3-have.html
Jun 26, 2011 | ASUS Eee PC 901 20G Notebook
Sir, there is an error i.e system error e225 in my canon mf 4350d machine please help me shut out this problem
Sir, there is an error i.e system error e225 in display my canon mf 4350d machine please help me shut out this problem
Apr 11, 2011 | Canon ImageCLASS MF4350d Laser All-in-One ...
What is this error mean that i get during boot up? 312.198 Eth0:(185488) System Error Occurred (0) 312.199 Eth0:(185489) System Error Occurred (0) 312.200 Eth0:(185490) System Error Occurred...
I think this is related to to the NIC (Ethernet port).
Go into the BIOS and set it to default settings, see if that resolves the problem.
Let me know how you get on.
Regards.
Jun 30, 2010 | MSI P4MAM2-V Motherboard
Error message 010060
There is no mention of a fuse in the index.
I just read the manual and the SYSTEM ERROR 010060 is a Primer Motor sensor problem, Sensor might be bad, motor might not be turning, cable could have failed, or main PCA might be bad.
I uploaded the manual for you, here is the link:
http://rapidshare.de/files/47323187/HP_DeskJet_70-75-755_Service_Manual.pdf.html
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 19, 2009 | Office Equipment & Supplies
HP DesignJet 750c plus InkJet Printer Logo
41 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
