Question about Toshiba Satellite A205-S4617 Notebook
How do I stop laptop letters repeating itself
If i press r or c or any letters it continue repeating itself
  • Toshiba Master
  • 32,281 Answers
Go to Control Panel - Keyboard - Speed tab and change the following
Repeat delay to a longer time
Repeat rate to a slower time
Posted on May 04, 2013
How to convert numbers to letters
Keep pressing on the number with the letter of choice at least every 1 second to go through the list of that button , when you get to the one you want stop pressing if you go too far continue pressing every 1 second as each button goes through a loop and repeats.if you make error just press the red button and it goes back one place.spaces are usually found on the 1 or 0 .
Sep 23, 2014 | Uniden Cordless Phone
Keyboard
Keyboards on Windows computers can repeat letters when key press sensitivity is too high. This problem can be rectified by adjusting your keyboard's repeat frequency. Once this is lowered, key presses will occur slower and you will not have the letters repeated instantly.
Click"Start," then "Control Panel." Click "Hardware and Sound," followed by "Keyboard." Move the "Repeat delay" slider further to the left below the "Character repeat" option. The further left the slider moves, the longer the delay will be before a character repeats.
Feb 04, 2013 | Vizio Silver 15.6" Thin Light CT15-A2...
Keyboard typing multiple letters/ numbers when pressing certain keys.
Feb 03, 2013 | Computers & Internet
Brightness laptop
Locate the Fn (Function) key on your keyboard. It may be on the bottom left side with dark blue letters. Locate the two "brightness" keys near the top of the keyboard. These will be in the "F" keys, possibly if F6 and F7. They should have little sun pictures or something similar to indicate brightness. Hold down the Fn key while pressing F7, or whichever "F" key your laptop uses to increase brightness. Tap F7 repeatedly until you reach the desired brightness. Fn must be held down as you continue to tap.
Jan 31, 2013 | Dell Inspiron Computers & Internet
Front loader stops mid cycle and blinks Er until start button is pressed, the cycle will continue, and sometimes repeats this scenerio three -four times each load. any thoughts anyone?
The control board has detected an error. Press any button to wake the machine then wait for 5 seconds. Press and hold the START/PAUSE and CANCEL buttons simultaneously then the failure code will appear in the display as an "E" followed by two numbers, a number and a letter or two letters as long as the buttons are held. The control will beep and the Door Lock, Wash, Rinse, and Final Spin indicator lights will flash. Post back the code for further advice.
Jan 11, 2011 | Frigidaire Washing Machines
How do I change the Name of the person at an extension on the Panasonic KX T7431
press the Program Button, then (**1234), and scroll counter-clockwise through the options with the volume circle. the option should say, "004 ext name set." to enter into that option to change, press the sp-phone button. continue pressing the sp-phone button until you find the extension number you would like to change. once you find it, press the transfer button and spell the designated name using the dial pad. For example, Mike (press 6 and use the volume circle to browse the letter you need from that assigned key- to get M) to continue spelling the name, continue using the dial pad and repeat to assign the designated letter. to store the name, press the "Auto Dial/Store" button and it will beep to confirm.
hope this helps, deanna
Jun 28, 2010 | Panasonic KX-T7431 Corded Phone
I NEED TO RE-PROGRAM PRESET NUMBERS, BUT DON'T HAVE MANUAL FOR CANON L350 FAX MACHINE?
Open panel cover Press DATA REGISTRATION Press V to display 2. TEL REGISTRATION Press SET twice Press V (if necessary) until an empty space appears Press SET twice Enter Fax number Press SET twice Enter name using number keys (e.g. 2 = A,B,C like a mobile phone) Press > to enter next letter Press SPACE to enter a space Press * to enter a numeric Press SET To continue press DATA REGISTRATION Repeat steps 5 to 10 To end press STOP
Feb 09, 2010 | Canon FAX-L350 Plain Paper Laser
Repeating letter on viewed webpages and while typing
install powerful antivirus, if not work change the keyboard
Nov 26, 2009 | HP Pavillion ZV6000 Notebook
R letter keeps coming on by itself
possibly stuck because of dirt or rubber kicker is torn. Try removing button cover to check cause. Suggested keyboard replacement. You can purchase one over the internet. There are a number of webpages showing how it can be replaced.
Nov 22, 2009 | Dell Latitude D620 Notebook
Buttonholes
Put on the C foot. Select the buttonhole stitch. The machine will start sewing in the bottom left corner of the the buttonhole. Sew the length that you need, press and release the reverse button and sew the right side of the buttonhole. When you get back to the bottom, press and release the reverse button again and the buttonhole will be finished and the thread will tie off and the machine will stop. If the buttonhole is what you want, press and release the Stop button and the machine will repeat this buttonhole as many times as you need until the machine is turned off or the Stop is pressed again. When repeating, you need not press the reverse. Just press down on the foot control and continue until the machine stops by itself.
If you don't like the first one, just sew another one using the reverse button to set the ends.
Jun 28, 2008 | Husqvarna Viking 1
Toshiba Satellite A205-S4617 Notebook Logo
66 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
