Question about Sas Institute JMP 4 Full Version for PC, Mac
Code activation JMP - Sas Institute JMP 4 Full Version for PC, Mac
It can't see display so how we go bios. it jumber setting problem i say how to jumber setting in the mother board. but how and where i don'nt know.
o enter the bios Press DELETE or F12 or the key displayted on the screen saying Press key to enter setup. Its the first screen you see when you turn the system on, if you see a logo you can press ESC to go to the display screen with the information..
the JMP is a 3 pin JMP close to the processor. The defaults should be fine, so you dont need to adjust the jmp settings.
Dec 30, 2012 | Computers & Internet
I have an old Marshall JMP Mk2 100 watt lead (serial number 09920L) and Im missing the logo. Not sure what Im looking at. Tell me about this amp please Now that I have to pick an expert I can tell...
Here's a website with info on the Marshall JMP. Scroll down til you find the JMP models. It should help you identify the amp better.
If it works and is in decent shape, looks like it could be valuable.
eBay has a couple for sell you can check to help identify yours.
The Vintage Marshall Guide
Dec 13, 2017 | Audio Players & Recorders
I don't have the manual for this receiver and I would like to hook up my hd tv to it. How do I acquire the user's manual? Thanks, jmp
Use a search engine for "Onkyo TX-SR501 manual"??
Hint: retrevo has it.
You might also hunt for the TV manual as IT is a player in the scenario, too.
Jul 24, 2011 | Onkyo TX-SR501 Receiver
Burnt a 110V mixer when plugged to a 230v european appliance. KitchenAid ref.:KSM150PSMC Thanks JMP
go to a technician and have the motor rewinded again. because your machine encountered a short circuit so the motor needs to have a new rewind. Hope the other parts are not affected.
Jun 18, 2011 | KitchenAid KSM90 Ultra Power Series Stand...
No sound on speakers
make sure the stereo (or whatever is sending the signal) is not muted, make sure the volume is turned up.
Make sure the connectors are both plugged in, contacts are clean, and you arent short circuiting the wires.
May 25, 2011 | Jensen JMP-50 Computer Speakers
Where do i plug in the jensen computer speaker from the signal ouput line
You will want to plug the speakers into the green port on your sound card.
Jun 22, 2010 | Jensen JMP-53 Computer Speakers
No sound microphone does not work
Check the audio drive maybe are lost when you change the sistem
Apr 23, 2010 | Jensen JMP-13A Consumer Microphone
Basically I just need a wire. Is that a
This looks like a fragmented answer. Are you hooking up speakers? Go to the Shack, get 22 gage wire with what ever type ends you need ...
Sep 07, 2009 | Jensen JMP-33 Computer Speakers
Jensen JMP 50 sounds like I am in a tunnel or well.
Have you powered up the speakers have you checked the sound drivers?? but remember the sound of the Jensen JMP-50s is a bit hollow and lacking in bass, and the speakers do lack bass and treble controls, which can often be found in other speakers in the same price range.
Aug 18, 2008 | Jensen JMP-50 Computer Speakers
Sas Institute JMP 4 Full Version for PC, Mac Logo
22 people viewed this question
Top Sas Computers & Internet Experts
ray gallant
JonSnell Electronic
JonSnell Electronic
Are you a Sas Computer and Internet Expert? Answer questions, earn points and help others
