Question about Sony Handycam CCD-TRV416 8mm Analog Camcorder
Picture rolling my picture is rolling in record & playback
  • 169 Answers
The problem of your camera is the try to adjust the two tape guide and two small screw near at the video head is you can open your camera..doing these you should be careful cause your to close to the head or you may damage it..adjust the small screw first slowly...if is not work then the tape guide...
Posted on Aug 09, 2007
Problem with the tape transport mechanism; could be the rollers are not contacting the tape itself or it could be the springs in the transport. Sounds like an older model. Could clean the rollers with alcohol and swap and if you can open it a like observe what happens with the rollers when you place in playback. These are rather delicately adjusted machines. I would again 1) try cleaning as best you can and very light oil in moving joints/gears aferward. 2) check adjustment of springs when moving from stop to playback. Once you have that whipped the record mecanism may start working as well.
Apr 02, 2012 | RCA CC4393 VHS Analog Camcorder
Picture rolls on playback
Try cleaning the heads, but it seems like the heads may be faulty, you might need to replace the vcr, they don't cost much these days, the repair might cost more than a new vcr these days.
heres a cheap headcleaner, look for one at local shops, wallmart bestbuy and so on
Sep 24, 2008 | Panasonic PV-V4021 S-VHS VCR
Have a toshiba tp 61H95 proj TV- want to connect panasonic dvd recorder and toshiba vhs recorder so I can copy family videos to dvd- can't get hook ups set up for both to work.
Select AV-1 or some thing in TV and plug DVD recorder Video-Audio output in AV-1 input of TV, playback any DVD and confirm its picture and sound in TV. Press Stop button of DVD recorder to stop playback.
Now plug Video-Audio output of VCR in DVD recorder input and select AV Input in DVD recorder, insert VHS tape in VCR and playback it and confirm you get VHS picture and sound in TV via DVD recorder.
Hookup between TV, DVD recorder and VCR is completed.
Playback VHS tape in VCR, Insert blank DVD disc in DVD recorder and press Record while you see VHS tape picture in TV.
Hope this info will help you.
Feb 03, 2010 | Toshiba TP61H95 61" Rear Projection...
After recording a program using the Toshiba W522, the picture rolls and jumps up and down, while in playback mode. I have no problem with recording, its just when its time to actually watch the program,...
If the tapes are old or cheap, they may simply be no good. However, I found that the automatic tracking is the best thing to ensure perfect quality picture and sound.
Jun 22, 2009 | Toshiba W522 VHS VCR
There is no playback picture viewing a recording.
if you have the setting to avi it will not show up, you will get sound but know pic just a black screen, try the dvd setting and the the other dv setting.
Dec 03, 2008 | Ulead Videostudio 8 for PC
Rolling of picture
You camera is PAL and you are attaching with Ntsc TV or VCR. Both Pal and Ntsc are different systems and incompatible to each other.
If you want to see correct playback of your Camera, it requires Pal or Multi-System color TV.
Need further info, please let me know.
Oct 04, 2008 | Sony Handycam CCD-TRV68 Camcorder
Rolling picture on TV while playing back Hi8 tape on TRV460
Hello richiehere,
Check and correct Color System of your TV set. I think you have Multi-Color System TV set and Its not match with your camera system.
May 23, 2008 | Sony Handycam DCR-TRV460 Digital Camcorder
Vidio recorder when i record it wont play back what is recorded but it will play pre recorded tapes Is it campatable for LG television please model no VR550/07
If it plays back pre recorded tapes then there is nothing wrong with that section of the unit. Does it playback audio and not picture or does it not playback anything.
Also, when trying to playback a recording what is seen of the screen? Snow(black and white dots or wiggly picture?
The unit uses two separate circuits to record and playback tapes. Is any thing else connected to the unit while you are recording? If you are using anything plugged into other ports on the recorder it may not see the camera input causing it to not record anything..
Feb 03, 2008 | Dishwashers
Blue screen on playback on Sony DCR-HC40
You can see an image in a camcorder viewfinder any time the camera's actually on in record mode, whether or not the camcorder is actually recording. So that's no guarantee.
Assuming the obvious (you have the right kind of tapes, they're not in write-protect mode, you rewind before playing, etc). I recommend that you borrow a tape of the same kind from someone else and check it on playback in your camcorder. This should lead you know understand if you have a playback problem or a recording problem.
Jan 20, 2008 | Video Cameras
VCR recording
As with all tape related recording equiptment, the path the tape follows in your machine will collect debris which will interfere with the synchronizing playback signals originally recorded on our tape when first recorded. The "ROLLING" is the loss of those synchronizing signals and the "skewing" of the tape where the heads are now reading between the recorded information causing noise at the top or bottom or throughout the entire screen. SOLUTION for about 85% of machines exhibiting this problem is CLEANING and inspection of tape path alignment best done with a calibrated playback tape for accuracy. HOPE this helps . . . Jaszy
May 29, 2007 | Maxell 10 Pack T60 Blank VHS Tape PI PLUS...
Video Cameras Logo
176 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
