Question about BlueFox BF-106 Bluetooth Headset with AC Charger
I can't turn my Bluetooth BF106 on? Is there a user guide available?
Just bought a Parrot Minikit. I have an iPhone 5S. I can't transfer my contacts because my iPhone doesn't have that capability. Is there an app that I can use to make this happen?
There doesn't appear to be an iphone app for that product. Checking the compatibility page Parrot USA Compatibility it notes that the 5S is compatible with phonebook synchronization. The user guides are available here Support Parrot MINIKIT Plus USA. You should read it,I see it notes that:
Sending contacts via Bluetooth:
If your phone does not support automatic synchronization, you can also use the Object Push function of your phone to send contacts from your mobile to the Parrot MINIKIT+ via Bluetooth. To do so :
1. Press the jogwheel and select Receive contacts.
2. Refer to your phones' user guide for more information about sending contacts via Object Push.
Nov 20, 2014 | Parrot MINIKIT Bluetooth Hands-Free Kit...
How to pair plantronics explorern240 with lg phone
On my LG phone under tools, is the bluetooth application -- turn this on. Once that is done, turn on your bluetooth, they should find each other. I have also included the directions from the user guide.
Plantronics Explorer 240 User's Guide
Good luck from Headsets Direct!
Nov 04, 2011 | Plantronics Explorer 240 Bluetooth Headset
How do i get into pairing mode?
is bluetooth available on the 2006 cadillac escalade
Oct 19, 2011 | Plantronics Explorer 220 Bluetooth Headset...
Need to pair with new phone. I followed allinstructions and the device cannot be located
Do not know what type of phone that you have, but following the basic instructions for a pair up it should be to turn your phone on to the bluetooth settings turn on your bluetooth and the find each other. Below is the link to the Explorer 230 User's Guide.
Plantronics Explorer 230 User's Guide
Jul 28, 2011 | Plantronics Explorer 240 Bluetooth Headset
Can't hook up the Plantronics 320 with my Pantech phone . Is the pass code 0000 ?
For all current Bluetooth headsets the passkey is 0000 (four zeros).
If the phone does not accept this code, please refer to your cell phone user's guide to ensure the proper setup procedure.
Note: Powering your cell phone off and on sometimes corrects this issue. You cannot change or personalize the PIN code/password of the Bluetooth headsets. It will always remain four zeros.
There is a link below to the Plantronics 320 User's Guide which may help you also.
Jun 25, 2011 | Plantronics Explorer 320 Wireless Headset
How can i connect my bluetooth headphones
Things You'll Need
  • Bluetooth capable phone
  • Bluetooth headphones
    • 1 Turn on your cell phone. Enable Bluetooth by accessing your phone's general or network settings. Your phone will search for Bluetooth signals in the area--they are usually denoted by a small icon displayed on the screen. If you don't know how to turn on Bluetooth or aren't sure whether your phone supports Bluetooth technology, refer to your phone's user guide.
    • 2 Turn on your Bluetooth headphones while near your cell phone. Turning on a Bluetooth-enabled device will usually put it in pairing mode, meaning it is actively searching for a device to connect to. Since your phone also is actively searching for a Bluetooth device, it should find it right away and prompt you to connect to it. It may ask for a password--refer to your headset's user manual for the default password and how to change it.
    • 3 Test your connection. Once your headset is paired, the phone will usually start sending calls and audio to it without any additional configuration. Some phones may prompt you and ask which device to use. Try making calls and/or playing music. If you hear music from only one ear, your phone may not support stereo Bluetooth. If you don't hear anything, re-pair the headphones. Power off your phone and headphones, then turn them back on and repeat steps 1 and 2.
Jun 12, 2011 | Cell Phones
How do I get bluetooth to work on my Acer Aspire 5742. Do I need to install a driver or something? Thanks Sam
Probably your laptop dosen't have bluetooth hardware in it.
Confirm it by following process
Right click on My computer and click Manage
then click on device manager on left panel
A list will appear which shows the hardware content of your laptop.
If the list dosen't contain bluetooth device then it is confirmed that your laptop dosent have bluetooth hardware.
Try using external USB bluetooth device for your laptop. Cost couple of dollars.
May 17, 2011 | Acer Aspire 5742Z-4200 Notebook
CAN I CONNECT A THIS TO A LAPTOP? IF I CAN HOW?
You can use the Plantronics Explorer 240 on your computer if your computer has Bluetooth built in. Just turn on the Bluetooth feature in the computer and pair up the headset. You can get a USB Bluetooth adapter if your pc doesn't have Bluetooth built in, then just pair the headset to the adapter. Here is a link for the 230 / 240 user guide, it will have the pairing instructions for the Explorer 240.
Plantronics Explorer User's Guide
Mar 17, 2011 | Plantronics Explorer 240 Bluetooth Headset
How do you turn off the led indicator light?
Below is the link for the Explorer 230 user guide. See Headset Controls in the user guide.
Feb 11, 2011 | Plantronics Explorer 230 Bluetooth Headset
How do i turn off the blinking led light?
BlueFox BF-106 Bluetooth Headset with AC Charger Logo
35 people viewed this question
Top BlueFox Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a BlueFox Radio Communication Expert? Answer questions, earn points and help others
