Question about Cell Phones
LG LS860 calls going directly to voicemail
270rexton
  • 762 Answers
SOURCE: Deactivating the voicemail on LG Shine
##002# (works in GSM networks in Europe).
Posted on May 30, 2009
toy_ladi
  • 484 Answers
SOURCE: my lg 410g phone does not ring
the reason the phone automatically goes to voice mail is simply because the phone has sim card has been set to do so.
The solution is for you to deactivate the voicemail.
That is when you will be able to receive your call properly.
To deactivate the voicemail, all you have to do is to dial ##002# and send.
it will deactivate the voicemail of your phone and you will be able to receive your calls aswell as your phone will also start to ring out.
take care
Posted on Jun 18, 2010
net2mani
  • 129 Answers
SOURCE: my incoming calls go directly
deactivate call forward option from setting your calls diverted to voice mail number
Posted on Apr 21, 2011
SOURCE: Tracfone LG 3100 handset. All calls go directly
I had the same problem with my LG100C. The tech support at Tracfone said that the person calling you must dial your area code too. Seems silly, but it worked for me.
Posted on May 09, 2011
  • 33 Answers
SOURCE: Incoming calls go directly to
There are no setting options to adjust how many times the phone will ring before going to voicemail. If it does not ring at all, this indicates you may be in an area with little to no service. Any time this happens, the first thing you should try is turning your phone off and leaving it off for one full minute then turning it back on. This may help your phone find a better signal.
You may also want to check the ringer volume. If the ringer is set to low, it may be ringing without you being able to hear it. With the phone on and open, look at the inside screen while reaching around to the outside of the phone to find the rubber volume button. You can press the top or bottom of this button to adjust the ringer volume and the inside screen will indicate the ringer volume setting.
If none of these solutions work, please call our Customer Service department for more assistance at (800) 733-6632. We are available 24/7.
Posted on May 18, 2011
My calls go to voice mail
How to stop iPhone calls going straight to voicemail - iOS 7 tip
www.macworld.co.uk/.../how-stop-iphone-calls-going-straight-voicemail...
May 28, 2014 - Do your iPhone calls go directly to voicemail? ... I don't remember setting my iPhone to Do Not Disturb, and it appears nor do most people ...
iPhone 5 calls go straight to voice mail ' Apple Support Communities
discussions.apple.com > Support > Apple Support Communities
Apple Inc.Dec 25, 2013 - Madman, your advice solved the problem on my wife's phone. It wouldgo to voice mail very often, seemingly for no reason. When I'd call again, ... iphone 6 going calls going directly to voice mail
Jul 20, 2015
My iPhone doesn't always ring, why?
Oct 28, 2013
calls going straight to voice mail
Feb 24, 2013
Calls going Straight To Voicemail
Jul 3, 2010
More results from discussions.apple.com
Troubleshooting Calls going straight to
Dec 30, 2015 | Cell Phones
L39c. How do I disable voicemail?
Sounds like you got your calls going to call forwarding or you need to turn up your volume on your phone if it is call forwarding it want to dial*73 and then hit your call icon button on your phone and that should disable any call forwarding that you have.
Oct 02, 2015 | LG Cell Phones
How do I unblock a recipient/sender for text messages and calling on my LG Mach?
Go to contact list and see if the number is listed. IF it is, press the number and hold, you should get a pop up with a menu that has block checked on it. Uncheck it.
Jul 07, 2014 | LG Mach sprint LS860
LG Mach LS860 won't connect to 4G
I alsohave a sprint service plan, it sucks but it works when it wants to. the issue with the 3g and 4g with sprint is this. wherever you friend is located and the towers that are around she will be able to get 4g signal, if not then the phone/ network will automaticaly go to 3g as a backup. this would explain why shecan still send and recieve txt and make calls still.
try going into system setting , under share and connect tap more then scroll down to mobile networks, she cant adjust the 4g settings because its automatic. She can then choose network mode and set it to to CDMA aka 3g. when she chooses this the phone will operate in 3g mode. The net will be a bit slower than 4g , but it'll work. now when she goes out of that dead zone into a area where 4g is available then she can repeat this process and switch back over.
LTE/CDMA is what the Sprint network is running on most of the time though. CDMA= 3g
LTE=4g
CDMA+LTE= 3g and 4g switching automaticaly.
good luck
Feb 16, 2014 | LG KM555 Cell Phone
Can't receive texts with certain numbers
go to contacts in the phone, go to your entry, press sub menu button, uncheck incoming calls (send calls directly to voicemail)
Jul 08, 2012 | Lg800g With 1200 Minutes And TripMinutes...
Calls wont go to voicemail,call voicemail and get a busy signal
are u dialing ur voicemail by using direct dialing icon?
If so, u need to contact ur service provider and get the voicemail number , put that number in again. Enjoy direct dialing.
Jul 25, 2010 | Motorola Cell Phones
My lg 410g phone does not ring when there's incoming call but goes directly to voicemail
take care
Jun 18, 2010 | LG Cell Phones
Feb 27, 2010 | Cell Phones
How do i retrive voice message from my lg rumour
Assuming that you have voicemail oh your service plan with this phone, there should be a voicemail number that you call to get your messages, Many phones assigen the number 1 for this function, but if in doubt, ask your service provider.
Jul 20, 2009 | LG RUMOR Cellular Phone
Cell Phones Logo
26 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
